+Stephen Posted May 7, 2012 Share Posted May 7, 2012 This question is mainly for the Dark Lord. I have successfully connected to several telnet BBSes using my 520ST. I am using a Lantronix UDS-10 device set to modem simulation mode. I have tried using 9600 and 19200 baud rates. The device is set to 8-bits per character, no parity, 1 stop bit, and no flow control. When typing on Darkforce, every character has j' inserted. I log in and issue menu commands, but I cannot type or save messages. It does not matter if I set Darkforce to ASCII, VT-52, or ANSI. I am not having this issue on any of the other telnet BBSes. Has anybody encountered this? Stephen Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 7, 2012 Share Posted May 7, 2012 Not sure Stephen, it seems like somewhere (in the dim, primordial mists of my mind) that someone had this problem before. I don't remember exact details at the moment, or what they did to fix it (if they did). I would start by turning half-duplex off/on (even though that just usually echo's characters), and things like that. Sadly, I don't have my 8bit setup yet to test this with. I don't think its DarkForce itself sending out a "j". I've logged in remotely with various versions of Windows, and Linux with no problems at all. The vast majority of callers have no problems so its probably just some setting somewhere. Does it do this with all the comms programs you've tried? Try different ones if you haven't and see what that does. I know Doc Clu uses an 8bit setup to call - hopefully we can get his attention and see what he has to say... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 7, 2012 Author Share Posted May 7, 2012 This only happens when using my ST. It doesn't matter if I use the VT100 terminal emulator cart, or TAZ to connect. My 8-bit Atari connects fine. I have not tried using the Lantronix with the A8 though, so I don't know if that is causing the problem. It seems odd though - the Lantronix connects to everything else OK. I am trying to make it connect to my PC so I can see exactly what characters it is sending. I'll keep playing. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 7, 2012 Share Posted May 7, 2012 Yeah, sorry Stephen - just got up, worked last night, missed the part about it being your ST. I picked up an extra UDS from a guy at AtariForum, if I can find one of my extra universal power supplies, I'll try to hook it up to my STacy and go across my LAN to see what TAZ and the STacy does here. Quote Link to comment Share on other sites More sharing options...
thgill Posted May 7, 2012 Share Posted May 7, 2012 (edited) I am looking to pick up one of the Lantronix devices here soon. I can also test it then from my ST to see how it behaves. edit: Are pretty much all the Lantronix devices essentially the same in regards to functionality on machines like the ST? Edited May 7, 2012 by thgill Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 7, 2012 Author Share Posted May 7, 2012 The main difference is the MSS can do DNS lookup, while the UDS-10 cannot. It's a bit of a pain in the ass having to know IP and port numbers to connect, since my ST is on the opposite side of the room as my PC. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 8, 2012 Share Posted May 8, 2012 Argh, can't find all the right cables - have to wait until I get it sorted out. I've got the UDS10, a universal power supply, just can't find a serial port cable at the moment - I know I've got one stuck away somewhere. Could take the one off the BBS, but that kinda defeats the purpose. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 9, 2012 Share Posted May 9, 2012 Hmm, I've never setup a Lantronix device for calling out before, come to think of it. I've only set them up for *incoming* calls with my BBS. What settings are you using Stephen? Thanks. I see from your original post that you've got 19200, N 1, no flow control. Try turning linefeeds off and on, as well. (and in TAZ) Speaking of TAZ, have you tried both the ST and IBM char sets? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 9, 2012 Author Share Posted May 9, 2012 I'll have to get you the settings when I get home. I want to say that communication type was set to D6 (modem, full duplex, echo characters). I believe I have tried both IBM and ST character sets, but I will try both options again this evening. I have definitely tried both linefeed options. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 9, 2012 Share Posted May 9, 2012 That's fine Stephen, no rush. I got TAZ running, UDS10 up (at least diagnostic lights seem to be indicating its OK) with a universal P/S, jury rigged modem/serial port cable, etc,...I still need to logon to the UDS - I don't know what the original owner had it set to. Gotta read the docs again, been awhile. My UDS1100 settings I know by heart. BTW, what dial string are you using in TAZ? Something like ATDT ip address port? I guess it seems really strange (well, it does to me!) that I've never actually called in to my own BBS with an Atari, 8bit or ST... Oddly enough, it just never came up with an ST and I still don't quite have my 800XL back up to par yet. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 10, 2012 Author Share Posted May 10, 2012 Yeah - since the IDS-10 cannot do DNS, I do ATDT ##.##.##.##,## (IP address, then a comma, then port. No spaces). Let me know if you need help getting the UDS-10 up and running. It took me hours, but I could do the next one in a few minutes. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 10, 2012 Share Posted May 10, 2012 Well, I'm like that with my UDS10 I had before, and the UDS1100 I've got now, as far as setting it up for my BBS. It's a no brainer now. Here is what I'm facing right now - I don't know what the former owner had this used UDS10 set to, as far as IP address, etc, etc,.... At work last night, I used a stand-alone Win95 comp to try and access it. I set the comps com1 to 9600 N 1 no flow, and then I tried to reset the UDS10. I used the reset button on back, I tried the "xxx", and all that. I set it to 19200 N 1 no flow, no difference either. I'm just trying at the moment to get it reset to the factory default of 0.0.0.0, 9600 N 1, no flow so I can access it to change the settings to what I need. Haven't made it there yet. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 12, 2012 Share Posted May 12, 2012 Okay, I finally got into the UDS10, using the old stand-alone XP comp with a true serial port at work last night. Used Hyperterminal. Now, when I start TAZ, it correctly does the: atz OK like its supposed to. Unfortunately, I put the wrong IP address range in. It was supposed to be 192.168.1.102, but I put 192.168.0.102 instead. I'll change that the next night I work and try again. Slow progress, but progress. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 15, 2012 Share Posted May 15, 2012 Okay, round 3 (or is it 4?)... I'm starting to get bugged with this UDS10... As far as I can tell, using the serial port connection, I've got this UDS10 setup identical to my UDS1100. However, while I can access my UDS1100 by telnet and by web browser, I can not get that to work with the UDS10. Stephen, if you don't mind, when its convenient for you, could you post what settings you are using to call out with in TAZ and your Lantronix device? Thanks. I"m sure its just a matter of getting the settings sorted out. I'm used to setting one up for incoming calls, not outgoing... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 15, 2012 Author Share Posted May 15, 2012 Okay, round 3 (or is it 4?)... I'm starting to get bugged with this UDS10... As far as I can tell, using the serial port connection, I've got this UDS10 setup identical to my UDS1100. However, while I can access my UDS1100 by telnet and by web browser, I can not get that to work with the UDS10. Stephen, if you don't mind, when its convenient for you, could you post what settings you are using to call out with in TAZ and your Lantronix device? Thanks. I"m sure its just a matter of getting the settings sorted out. I'm used to setting one up for incoming calls, not outgoing... Sure thing. I haven't been home since Thursday night. I will finally be there tonight. I'll take some screenshots (literally) and post them up. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 15, 2012 Share Posted May 15, 2012 That sounds great - I have to work tonight, but I'll be off the next couple of days. Thanks Stephen! Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 16, 2012 Author Share Posted May 16, 2012 OK - info posted in the other thread. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 16, 2012 Share Posted May 16, 2012 Okay, some progress. Not sure exactly what I did, but between google, odd msgs I had saved, docs, and your snapshot Stephen, I can now logon to the UDS10 by telnet or by using a web browser. When I start TAZ, it responds with: atz OK on the screen. However, so far, I've been unable to dial out from the UDS10 to anything else. Whenever I do a "ATDT xxx.xxx.xxx.xxx" it always *immediately* responds with: NO CARRIER I'll keep plugging away at it... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 16, 2012 Author Share Posted May 16, 2012 Well, that's a step in the right direction. At least the device is echoing back to the terminal, so you know it is communicating. If you are getting the NO CARRIER, it may be that you do not have the subnet or gateway set properly. Is it possible you have a firewall blocking? I know when you are accessing the setup menu via the telnet protocol you can have the UDS-10 ping an IP. Try that - if you are not able to ping with it, you have no connection. Added some scans from the manual showing how to use the PING command : Here are the diagnostic LED readouts : Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 16, 2012 Author Share Posted May 16, 2012 ALSO - you must specify the port when trying to connect. There is a setting for the default port to use buried somewhere in the options. I find it easiest to just specify it via "ATDT xxx.xxx.xxx.xxx,pp". No spaces anywhere, use a comma in between the IP and port. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 17, 2012 Share Posted May 17, 2012 Okay, again not sure exactly what *one* thing it was, but I'm connecting to DarkForce now, and like you, I'm getting a "j'" in front of every character I type. Now to work on that... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 17, 2012 Author Share Posted May 17, 2012 Great - glad it is sorted and it's not just me seeing it. Thanks for spending the time on this! Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 17, 2012 Share Posted May 17, 2012 Great - glad it is sorted and it's not just me seeing it. Thanks for spending the time on this! No problem, its aggravating, to be sure. Oddly enough, you can still use the BBS like that, its just kinda maddening to have to look at it. BTW, I was trying to get through to Marius's BBS - I've got his quad IP address but not his port number. I tried no port and port 23, but no go. Do you know what he is using? Thanks! Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 17, 2012 Share Posted May 17, 2012 Well, Hyperterminal under Windows is having the same problem. Also, both TAZ and Hyperterminal will not let the backspace key work either... To be continued... Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 17, 2012 Author Share Posted May 17, 2012 Well, Hyperterminal under Windows is having the same problem. Also, both TAZ and Hyperterminal will not let the backspace key work either... To be continued... There is a setting for destructive backspace. Both terminals give the same result which leads me to believe it is a hardware issue of some sort. I have not yet been able to make the ST+UDS-10 telnet into my Windows PC so that I can directly analyze the data being sent. Quote Link to comment Share on other sites More sharing options...
