iesposta Posted May 19, 2012 Share Posted May 19, 2012 Replacement switches are back in stock: http://www.mouser.com/ProductDetail/E-Switch/TL1100BF160Q/?qs=YXf4ACKMM4wV6OVIdTqWS6m9KnK%252b7QDYLo2ZJSsh%2fxE%3d Just received mine in the mail. I destroyed two capacitors pictured with needle nose pliers while removing the reset switch. Anyone know offhand what they do? I replaced one with the same color bands as shown, but the other one I used was from other tech. The ones I broke are: brown, black, red, black, silver The other I used is: brown, black, brown, gold, silver If they go to the joystick ports, paddles and joysticks tested fine. The picture shows replaced switches and replaced capacitors. I just wanted to know what they connect to ground... Everything seems to work fine. Quote Link to comment Share on other sites More sharing options...
31336haxx0r Posted May 19, 2012 Share Posted May 19, 2012 Those are tiny capacitors, even though they look like resistors. Google for something like capacitor color bands or something to find out their values and replace them accordingly. They don't have to have the exact same housing. Just make sure there's enough space for them to fit inside the case. Quote Link to comment Share on other sites More sharing options...
