Ataritard Posted May 31, 2012 Share Posted May 31, 2012 I don't know if it was dropped or if these are just prone to go bad. It used to work. I took it apart and poked around on it but didn't find anything obviously wrong with it. Any help or advise would be appreciated. It's the kind that has two jacks on it. One for video and one for audio. I am not optimistic about getting this working again but I figure asking the hardware crowd here is my best shot. I can take pictures of it taken apart if you think it will help. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted May 31, 2012 Share Posted May 31, 2012 Quite possible that there's a bad solder connection on the audio jack. I'd check that out first. Then maybe look for bad capacitors, assuming there's anymore more than a black blob on the PCB. Quote Link to comment Share on other sites More sharing options...
Ataritard Posted June 1, 2012 Author Share Posted June 1, 2012 Quite possible that there's a bad solder connection on the audio jack. I'd check that out first. Then maybe look for bad capacitors, assuming there's anymore more than a black blob on the PCB. Thanks Rex. That's good advise. I will try that. Quote Link to comment Share on other sites More sharing options...
Ataritard Posted June 2, 2012 Author Share Posted June 2, 2012 Well, I succeeded... in breaking it further. Oh well, I have another one that works. I can use the one that I broke for parts for some other project. Quote Link to comment Share on other sites More sharing options...
