keoghjacob Posted June 6, 2012 Share Posted June 6, 2012 I've got some rough sketches and skematics of a design that I've been thinking of building for quite a while. A 2600 gaming centre. It's kind of be like a bartop arcade machine, except implimenting a REAL arcade joystick, a compatible paddle and driving controller device w/ buttons, along with drop-in modules for other controllers. The 2600 system would slide in through a side flap and be hooked up to built-in connections (compatible power supply, ex) via a door behind the center. How do you think persuing the design and building one sounds? I want your input. Thanks, Jacob Keogh Quote Link to comment Share on other sites More sharing options...
Ataritard Posted June 6, 2012 Share Posted June 6, 2012 I would go for it. Do you plan to use a harmony cart or change out carts? Will it be one player or two? What do you mean by drop-in modules for other controllers? How big of a tv do you picture using? Quote Link to comment Share on other sites More sharing options...
keoghjacob Posted June 7, 2012 Author Share Posted June 7, 2012 (edited) It is designed around having a cartrige insert at the front of the unit, so It would be compatible with harmony, and with normal cartridges. It will be centered around 1 player gameplay with a plug on the side for an external controller for 2 player. The drop in modules would be a square enclosure containing the controller with the cord coiled up inside the enclosure with the plug on the bottom so you can insert the enclosure into a port on the controller area. The "telivision" in this design is currently a computer monitor. Tell me what you think I should improve upon! Edited June 7, 2012 by keoghjacob 1 Quote Link to comment Share on other sites More sharing options...
