BydoEmpire Posted July 27, 2012 Share Posted July 27, 2012 I found one cheap, but it's sold "as-is." What are my odds? I've never heard anyone express particular concern over the trak-balls, but I'm a bit skeptical as I usually read "as-is" to mean "broken." Quote Link to comment Share on other sites More sharing options...
boxpressed Posted July 27, 2012 Share Posted July 27, 2012 I've purchased two as-is models and gotten them both to work. If you buy this one, be prepared for the cue ball and/or bearings to dislodge during shipment. (The seller might be able to prevent this by taping the ball to the case prior to shipment.) If this happens, the ball won't spin right--you'll be able to tell pretty quickly--and you'll have to open it up. However, you'll want to open it up anyway to lube the bearings. Buy a can of 3-in-One oil and use a drop or two per bearing. It will spin better than new. The bearings have to be positioned just so for everything to spin properly. The fire buttons can be touchy as well. They are dome buttons like the 2600's, but they can still make so-so contact. Strangely, the Start/Pause/Reset and keypad buttons are like those on the 5200 controller (conductive dot), but they all work just fine for me. Quote Link to comment Share on other sites More sharing options...
stringfellow Posted July 28, 2012 Share Posted July 28, 2012 Like he said. I got one as is and the ball didn't roll worth a darn. After I opened it up and lubed up the seized bearings it works great. If you are using extension cables keep in mind that not all work with the trak ball. Quote Link to comment Share on other sites More sharing options...
AtariBrian Posted July 28, 2012 Share Posted July 28, 2012 I believe you can also buy all the buttons from best electronics if you have any problems with them... 20 dollar minimum though, so buy a few things... Quote Link to comment Share on other sites More sharing options...
BrutallyHonestGamer Posted July 28, 2012 Share Posted July 28, 2012 got mine and it was fine other than just some cleaning to the ball. works good. good luck. Quote Link to comment Share on other sites More sharing options...
