Chuck D. Head Posted August 30, 2012 Share Posted August 30, 2012 I know the best solution for this is one of Ax's custom three in one power adapters, and I will get one in a few paychecks, but..... I got my 32x out for the first time in ages and found that I did not have the correct power supply. WTF did it go, I have no clue. Anyway, the 32x was packed up with a spare Gen 1 and two of the same Genesis power supplies in the box. Ignoring the fact that the plug end was tight, I crammed it in the 32x and got the same collapsed ghost image as I would with just the power to the Genesis. Can someone tell me the power specs for the 32x wall wart, so maybe I can find something to at least test my 32x? PS: I found a donor Gamecube supply for Ax to make into my 3-way. For those who haven't seen it, here is the thread on his power supplies: http://www.atariage.com/forums/topic/201252-sega-cd32xgenesis-power-upgrade-no-more-wall-warts/page__st__25__hl__+ax%20+sega%20+power?do=findComment&comment=2577377 Quote Link to comment Share on other sites More sharing options...
Galeforcerm Posted August 30, 2012 Share Posted August 30, 2012 Im pretty sure its the same as a genesis 2. Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted August 30, 2012 Share Posted August 30, 2012 Yup, it's a Genny 2 / Game Gear power supply you would normally use there. The Genny 1 is a negative tip, and the 32x is a positive tip. The polarity is wrong, even if you get it to fit. The specs are correct though, other than the polarity issue. Quote Link to comment Share on other sites More sharing options...
Chuck D. Head Posted August 30, 2012 Author Share Posted August 30, 2012 Yup, it's a Genny 2 / Game Gear power supply you would normally use there. The Genny 1 is a negative tip, and the 32x is a positive tip. The polarity is wrong, even if you get it to fit. The specs are correct though, other than the polarity issue. yeah, it took quite a bit of KY to get it in there. I will use the adapter from the Gamegear, since I dont need to play GG tethered to the power supply anymore; since you modded it, my GG sips the power daintily (pinky extended) from the batteries!! Thanks for the info! 1 Quote Link to comment Share on other sites More sharing options...
the.golden.ax Posted August 30, 2012 Share Posted August 30, 2012 Yup, it's a Genny 2 / Game Gear power supply you would normally use there. The Genny 1 is a negative tip, and the 32x is a positive tip. The polarity is wrong, even if you get it to fit. The specs are correct though, other than the polarity issue. yeah, it took quite a bit of KY to get it in there. Quote Link to comment Share on other sites More sharing options...
