Atari the Jedi Posted September 27, 2012 Share Posted September 27, 2012 So I've got a cart that is coming up as a black screen. When I got it it was dusty but noting major. I cleaned it l Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted September 27, 2012 Author Share Posted September 27, 2012 Is it dead ? How many times do I try it before I call it a goner! Quote Link to comment Share on other sites More sharing options...
shadow460 Posted September 27, 2012 Share Posted September 27, 2012 Not necessarily. The only thing that really kills a cart, IMO, is there's enough damage that the owner decides not to fix it. I draw the line after cleaning and sanding the contacts and reflowing the board inside. If it's something rare, you could get a board made to mount inside it. Quote Link to comment Share on other sites More sharing options...
Cap5750 Posted September 27, 2012 Share Posted September 27, 2012 When you say you cleaned it, I'm assuming it was with a q-tip, etc? Also, you might try wiggling the cart around a bit before turning it back on. I have a couple of games where the cart needs to sit in the console at a funky angle because the contacts are bent or something. I've also seen where it would work fine on one type of console (like the jr) but not another (like a vader). Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 27, 2012 Share Posted September 27, 2012 i suggest using some 600 grit wet dry on the contacts before you trash it i had a star trek that up and died on me though Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted September 28, 2012 Author Share Posted September 28, 2012 I have been able to bring up the title screen but wording is messed up and the game then freezes after a few seconds Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted September 28, 2012 Author Share Posted September 28, 2012 I am not that savvy to do sanding or cracking a cart open but I'm still getting a flatline:( Quote Link to comment Share on other sites More sharing options...
shadow460 Posted September 28, 2012 Share Posted September 28, 2012 5200 carts aren't too hard to open. You will need to experiment to find out just how to squeeze the shell once the screws are out. If the name of the game is showing up, the ROM is probably alive. Quote Link to comment Share on other sites More sharing options...
bohoki Posted September 28, 2012 Share Posted September 28, 2012 you just need to use something flat to get the little door open on the front i often use a paperclip then with some 600 grit folded over a ruler just rub back and forth on the contacts then clean it with a cloth wrapped on the ruler slap it in the machine Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted September 28, 2012 Author Share Posted September 28, 2012 What is a grip? This is an activision cart I'm working on; though I also have a missile command doIng the same Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted September 28, 2012 Author Share Posted September 28, 2012 Oh grit is sand paper Quote Link to comment Share on other sites More sharing options...
Atari the Jedi Posted September 28, 2012 Author Share Posted September 28, 2012 So after playing dr. Frankenstein last night I did it! It's alive! I revived a copy of H.E.R.O. It now oddly skips the title screen. Isn't that true to the 5200's just won't die:) Quote Link to comment Share on other sites More sharing options...
shadow460 Posted September 30, 2012 Share Posted September 30, 2012 You might have more work to do on it, though. If it wasn't skipping the title screen before, the fact that it does now could indicate that it's going to lock up at some in opportune time, like 5 points before you set a new personal high score. Quote Link to comment Share on other sites More sharing options...
82atari5200 Posted October 4, 2012 Share Posted October 4, 2012 I've only every had 1 cart die. It was Qix. And it was definitely dead. But out of close to 300 carts I had at one time not a bad percentage. Quote Link to comment Share on other sites More sharing options...
