bust3dstr8 Posted October 9, 2012 Share Posted October 9, 2012 (edited) I would like to use some Jedec fusemaps with a target device PALCE. I have a lot of GALs on sac boards and would like to use those up if possible. Is it possible to convert the fusemaps to use for GAL chips? Edited October 9, 2012 by bust3dstr8 Quote Link to comment Share on other sites More sharing options...
+batari Posted October 11, 2012 Share Posted October 11, 2012 Jedec fusemaps are plain text and a good burner should be able to intetpret them for a wide range of pin-compatible devices in most cases. If not, post the files and let us have a look. It may require just a few small changes. Quote Link to comment Share on other sites More sharing options...
bust3dstr8 Posted October 11, 2012 Author Share Posted October 11, 2012 I don't use PLD to often, but this looks pretty much the same as the GAL16V8 fusemaps I have used before. I forgot what the QV13 is for though. Part mode PALCE16V8Q * QP20* QF2194* QV13* F0* L00000 11111111111111111111111111111111* L00032 11111111111111111111111111111111* L00064 00000000000000000000000000000000* L00096 00000000000000000000000000000000* L00128 00000000000000000000000000000000* L00160 00000000000000000000000000000000* L00192 00000000000000000000000000000000* L00224 00000000000000000000000000000000* L00256 11111111111111111111111111111111* L00288 11110111111111111111111111111111* L00320 00000000000000000000000000000000* L00352 00000000000000000000000000000000* L00384 00000000000000000000000000000000* L00416 00000000000000000000000000000000* L00448 00000000000000000000000000000000* L00480 00000000000000000000000000000000* L00512 11111111111111111111111111111111* L00544 11111111111111101001101110111111* L00576 11111111111111011010101110111111* L00608 00000000000000000000000000000000* L00640 00000000000000000000000000000000* L00672 00000000000000000000000000000000* L00704 00000000000000000000000000000000* L00736 00000000000000000000000000000000* L00768 00000000000000000000000000000000* L00800 00000000000000000000000000000000* L00832 00000000000000000000000000000000* L00864 00000000000000000000000000000000* L00896 00000000000000000000000000000000* L00928 00000000000000000000000000000000* L00960 00000000000000000000000000000000* L00992 00000000000000000000000000000000* L01024 00000000000000000000000000000000* L01056 00000000000000000000000000000000* L01088 00000000000000000000000000000000* L01120 00000000000000000000000000000000* L01152 00000000000000000000000000000000* L01184 00000000000000000000000000000000* L01216 00000000000000000000000000000000* L01248 00000000000000000000000000000000* L01280 00000000000000000000000000000000* L01312 00000000000000000000000000000000* L01344 00000000000000000000000000000000* L01376 00000000000000000000000000000000* L01408 00000000000000000000000000000000* L01440 00000000000000000000000000000000* L01472 00000000000000000000000000000000* L01504 00000000000000000000000000000000* L01536 00000000000000000000000000000000* L01568 00000000000000000000000000000000* L01600 00000000000000000000000000000000* L01632 00000000000000000000000000000000* L01664 00000000000000000000000000000000* L01696 00000000000000000000000000000000* L01728 00000000000000000000000000000000* L01760 00000000000000000000000000000000* L01792 11111111111111111111111111111111* L01824 11111111111111111111111111011111* L01856 00000000000000000000000000000000* L01888 00000000000000000000000000000000* L01920 00000000000000000000000000000000* L01952 00000000000000000000000000000000* L01984 00000000000000000000000000000000* L02016 00000000000000000000000000000000* L02048 11000001000011001000110010101100* L02080 10000010000001000000010000000100* L02112 00000100111111111111111111111111* L02144 11111111111111111111111111111111* L02176 111111111111111101* V00001 ï C2D87* Quote Link to comment Share on other sites More sharing options...
