walter_J64bit Posted November 4, 2012 Share Posted November 4, 2012 I've just bought two 5200 joysticks from goodwill not working but anyway I've opened them up to do the pencil eraser thing what did see someone before my had did the aluminium foil dot tip to the joysticks. Anyway I need get this joysticks back in order working. Quote Link to comment Share on other sites More sharing options...
sqoon Posted November 4, 2012 Share Posted November 4, 2012 Are you asking for repair tips? The aluminum foil dot trick is very effective. Basically, use a paper punch to create a bunch of dots from a sheet of foil, then use a small dot of superglue on the non-shiny side to secure to each and every carbon dot on the 5200 controller buttons. Allow glue to dry good for about 1/2 hour before reassembling and your controller buttons will work good as new. As for the eraser technique, be careful because older flex circuits can be brittle with age. If you accidentally crack a trace, all is lost. I actually recommend a light spraying of the entire flex circuit with Deoxit or Radio Shack electronic parts cleaner over the eraser technique for that reason. BTW: If either controller pot isn't functioning quite right, just spray a good amount of parts cleaner solution down into the pot stem, rotate back and forth a few times, and your problems should be solved. Nice find to pick up 5200 controllers at Goodwill. Quote Link to comment Share on other sites More sharing options...
