Rabbit 2600 Posted December 5, 2012 Author Share Posted December 5, 2012 Major updates! 1. I fixed a few things up. When you run out of lives you now go to a propper gameover screen. 2. When the dragons passes the player you lose a life. 3. Sped up the player to be able to keep up with the dragons. Quote Link to comment Share on other sites More sharing options...
SmasherImp Posted December 5, 2012 Share Posted December 5, 2012 Good work on this so far! I like the lives implementation. RT is a beaut is he not :B Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 5, 2012 Author Share Posted December 5, 2012 Yeah, he's great. He's very good at explaining complicated things in a simple way =) Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 6, 2012 Share Posted December 6, 2012 Yeah, he's great. He's very good at explaining complicated things in a simple way =) Me and R.T. spend our days explaining simple things in complicated ways so customers bugger off while we get work done. Be thankful you caught him off duty 1 Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 6, 2012 Author Share Posted December 6, 2012 A new issue has surfaced. I'm atempting to get the player to go to screen 2 after killing a certain number of dragons. And I wrote this up but I get a syntax error, what am I doing wrong? if _Kill_Counter= 20 then _Kill_Counter= 0 _Kill_Counter = _Kill_Counter +1 if _Kill_Counter = 20 : then goto __Boss_Screen_Loop end The whole code set tv pal set romsize 4k rem **************************************************************** rem **************************************************************** rem * rem * Fixes it so "then goto" is usually unnecessary. rem * set smartbranching on rem **************************************************************** rem **************************************************************** rem * rem * Create aliases for variables. rem * rem **************************************************************** rem ` rem ` (You can have more than one alias for each variable.) rem ` rem ```````````````````````````````````````````````````````````````` rem ```````````````````````````````````````````````````````````````` rem ` rem ` Enemy Animation Counter rem ` rem ```````````````````````````````````````````````````````````````` rem ` dim _Enemy_Anim_Counter = f dim _Player_Anim_Counter = b dim _Kill_Counter = a rem ```````````````````````````````````````````````````````````````` rem ```````````````````````````````````````````````````````````````` rem ` rem ` BitOp variables 01 (controls all 8 bits). rem ` rem ```````````````````````````````````````````````````````````````` rem ` dim _BitOp_01 = q rem ```````````````````````````````````````````````````````````````` rem ` rem ` Debounce fire button (first of 8 bits). rem ` rem ```````````````````````````````````````````````````````````````` rem ` dim _Bit0_Debounce_Fire = q rem ```````````````````````````````````````````````````````````````` rem ` rem ` Debounce reset switch (second of 8 bits). rem ` rem ```````````````````````````````````````````````````````````````` rem ` dim _Bit1_Debounce_Reset = q rem ```````````````````````````````````````````````````````````````` rem ` Makes better random numbers. rem ` rem ```````````````````````````````````````````````````````````````` rem ` dim rand16 = z rem **************************************************************** rem **************************************************************** rem * rem * Enable pfscore bars. rem * rem **************************************************************** rem * const pfscore=1 rem **************************************************************** rem **************************************************************** rem * rem * rem * Program Start/Restart rem * rem * Clears and sets up variables (among other things). rem * rem * rem **************************************************************** rem **************************************************************** __Start_Restart rem **************************************************************** rem * rem * Clears most variables, except for z. rem * rem ```````````````````````````````````````````````````````````````` rem ` for temp5 = 0 to 24 : a[temp5] = 0 : next rem **************************************************************** rem * rem * Makes sure sprites are off the screen. rem * rem ```````````````````````````````````````````````````````````````` rem ` player0y = 255 : player1y = 255 rem **************************************************************** rem * rem * Missile setup. rem * rem ```````````````````````````````````````````````````````````````` rem ` missile0height = 4 : missile0y = 255 missile1height = 4 : missile1y = 255 rem **************************************************************** rem * rem * Ball setup. rem * rem ```````````````````````````````````````````````````````````````` rem ` ballheight = 4 : ballx = 255 : bally = 255 CTRLPF = $21 rem **************************************************************** rem * rem * Score setup. rem * rem ```````````````````````````````````````````````````````````````` rem ` score = 0 : scorecolor = $20 rem **************************************************************** rem * rem * Misc. setup. rem * rem ```````````````````````````````````````````````````````````````` rem ` NUSIZ0 = $00 m = 0 rem **************************************************************** rem * rem * Title screen playfield data. rem * rem ```````````````````````````````````````````````````````````````` rem ` playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX X..............................X X...XXXXX.XXX.XXXXX.X....XXXX..X X.....X....X....X...X....X.....X X.....X....X....X...X....X.....X X.....X....X....X...X....XXX...X X.....X....X....X...X....X.....X X.....X....X....X...X....X.....X X.....X...XXX...X...XXXX.XXXX..X X..............................X XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end rem **************************************************************** rem * rem * Player sprite data. rem * rem ```````````````````````````````````````````````````````````````` rem ` player0: %01100110 %00100100 %00100100 %01011000 %01011000 %00100111 %00011000 %00011000 end rem **************************************************************** rem * rem * Enemy sprite data. rem * rem ```````````````````````````````````````````````````````````````` rem ` player1: %00010100 %01011101 %00101010 %00011100 %01111111 %00011100 %00111110 %01000001 end __Title_Screen_Loop rem **************************************************************** rem * rem * Playfield colors. rem * rem ```````````````````````````````````````````````````````````````` rem ` COLUBK = 0 : COLUPF = $30 rem **************************************************************** rem * rem * Draws the screen. rem * rem ```````````````````````````````````````````````````````````````` rem ` drawscreen rem **************************************************************** rem * rem * If fire button pressed, leave title screen loop. rem * rem ```````````````````````````````````````````````````````````````` rem ` if joy0fire || joy1fire then goto __Setup_for_Main_Loop goto __Title_Screen_Loop __Setup_for_Main_Loop rem **************************************************************** rem * rem * Turns on debounce bits. rem * rem ```````````````````````````````````````````````````````````````` rem ` _Bit0_Debounce_Fire{0} = 1 _Bit1_Debounce_Reset{1} = 1 rem **************************************************************** rem * rem * Puts sprites on the screen. rem * rem ```````````````````````````````````````````````````````````````` rem ` player0x = 75 : player0y = 85 player1x = (rand/1) + 20 : player1y = 0 rem **************************************************************** rem * rem * Sets up number of lives. rem * rem ```````````````````````````````````````````````````````````````` rem ` pfscore1 = %10101010 rem **************************************************************** rem * rem * Game playfield data. rem * rem ```````````````````````````````````````````````````````````````` rem ` playfield: X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X end rem **************************************************************** rem **************************************************************** rem * rem * rem * Main Loop rem * rem * rem **************************************************************** rem **************************************************************** __Main_Loop rem **************************************************************** rem * rem * Sets colors. rem * rem ```````````````````````````````````````````````````````````````` rem ` COLUP1 = $52 : COLUP0 = $06 COLUPF = $40 : COLUBK = $00 pfscorecolor = $06 rem **************************************************************** rem * rem * Draws the screen. rem * rem ```````````````````````````````````````````````````````````````` rem ` drawscreen rem **************************************************************** rem * rem * Enemy sprite animation data. rem * rem ```````````````````````````````````````````````````````````````` rem ` _Enemy_Anim_Counter = _Enemy_Anim_Counter + 1 if _Enemy_Anim_Counter = 10 then player1: %00011000 %00111100 %00011000 %01111110 %11111111 %00011000 %10011000 %01110000 end if _Enemy_Anim_Counter = 20 then player1: %00011000 %00111100 %00011000 %00111100 %01111110 %10011001 %00011000 %11110000 end if _Kill_Counter= 20 then _Kill_Counter= 0 _Kill_Counter = _Kill_Counter +1 if _Kill_Counter = 20 : then goto __Boss_Screen_Loop end rem **************************************************************** rem * rem * Player sprite animation data. rem * rem ```````````````````````````````````````````````````````````````` rem ` _Player_Anim_Counter = _Player_Anim_Counter + 1 if _Player_Anim_Counter = 10 then player0: %00100000 %01100100 %00100110 %00011100 %10011000 %01100110 %00011001 %00011000 end if _Player_Anim_Counter = 20 then player0: %00000100 %00100110 %01100100 %00111100 %00011001 %01100110 %10011000 %00011000 end if _Player_Anim_Counter= 20 then _Player_Anim_Counter = 0 rem **************************************************************** rem * rem * Debounce fire button. rem * rem ```````````````````````````````````````````````````````````````` rem ` rem ` If fire button not pressed, clear debounce bit. rem ` if !joy0fire then _Bit0_Debounce_Fire{0} = 0 rem **************************************************************** rem * rem * Restarts game when 1-ups are depleted.. rem * rem ```````````````````````````````````````````````````````````````` rem ` if pfscore1 = 0 then goto __Game_Over_Screen_Loop rem **************************************************************** rem * rem * If enemy and player position are the same, restart enemy. rem * rem ```````````````````````````````````````````````````````````````` rem ` if player1y = player0y then player1x = (rand/2) + 20 : player1y = 0 : pfscore1 = pfscore1/4 rem **************************************************************** rem * rem * Check enemy missile. rem * rem ```````````````````````````````````````````````````````````````` rem ` rem ` If enemy missile isn't on or has gone too far, skip. rem ` rem ```````````````````````````````````````````````````````````````` rem ` if missile1y > 200 then goto __Skip_Enemy_Missile_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` Move enemy missile down the screen and skip enemy fire. rem ` rem ```````````````````````````````````````````````````````````````` rem ` missile1y = missile1y + 2 : goto __Skip_Enemy_Fire __Skip_Enemy_Missile_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` If enemy missile isn't moving, randomly put the missile on rem ` the screen (fire missile). rem ` rem ```````````````````````````````````````````````````````````````` rem ` if rand < 100 then missile1y = player1y : missile1x = player1x + 4 __Skip_Enemy_Fire rem **************************************************************** rem * rem * Check player missile. rem * rem ```````````````````````````````````````````````````````````````` rem ` rem ` If player missile isn't on or has gone too far, skip. rem ` rem ```````````````````````````````````````````````````````````````` rem ` if missile0y > 240 then goto __Skip_Missile_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` Move player missile up the screen and skip fire button. rem ` rem ```````````````````````````````````````````````````````````````` rem ` missile0y = missile0y - 2 : goto __Skip_Fire __Skip_Missile_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` If player missile isn't moving and fire button is pressed rem ` and debounce bit is not on, put the missile on the screen rem ` (fire missile). rem ` rem ```````````````````````````````````````````````````````````````` rem ` if joy0fire && !_Bit0_Debounce_Fire{0} then missile0y = player0y - 2 : missile0x = player0x + 4 __Skip_Fire rem **************************************************************** rem * rem * Check Enemy. rem * rem ```````````````````````````````````````````````````````````````` rem ` rem ` If enemy isn't on or has gone too far, skip. rem ` rem ```````````````````````````````````````````````````````````````` rem ` if player1y > 200 then goto __Skip_Player1_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` Move enemy down the screen and skip new ball drop. rem ` rem ```````````````````````````````````````````````````````````````` rem ` player1y = player1y + 1 : goto __Skip_Player1_Drop __Skip_Player1_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` If enemy isn't moving, randomly drop ball. rem ` rem ```````````````````````````````````````````````````````````````` rem ` if rand < 50 then player1x = (rand/2) + 22 : player1y = 0 : if player1x > 114 then player1x = 114 - (rand/4) __Skip_Player1_Drop rem **************************************************************** rem * rem * Check ball. rem * rem ```````````````````````````````````````````````````````````````` rem ` rem ` If ball isn't on or has gone too far, skip. rem ` rem ```````````````````````````````````````````````````````````````` rem ` if bally > 200 then goto __Skip_Ball_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` Move ball down the screen and skip new ball drop. rem ` rem ```````````````````````````````````````````````````````````````` rem ` bally = bally + 1 : goto __Skip_Ball_Drop __Skip_Ball_Movement rem ```````````````````````````````````````````````````````````````` rem ` rem ` If ball isn't moving, randomly drop ball. rem ` rem ```````````````````````````````````````````````````````````````` rem ` if rand < 50 then ballx = (rand/2) + 22 : bally = 0 : if ballx > 114 then ballx = 114 - (rand/4) __Skip_Ball_Drop rem **************************************************************** rem * rem * If player missile hit enemy, add to score and reset enemy. rem * rem ```````````````````````````````````````````````````````````````` rem ` if collision(missile0,player1) then score=score + 10 : player1x = (rand/2) + 20 : player1y = 0 : missile0y=255 : _Kill_Counter + 1 rem **************************************************************** rem * rem * If player touches enemy, subtract from score and reset enemy. rem * rem ```````````````````````````````````````````````````````````````` rem ` if collision(player0,player1) then player1x = (rand/2) + 20 : player1y = 0 : pfscore1 = pfscore1/4 rem **************************************************************** rem * rem * If enemy missile hits player, subtract from score and reset rem * missile. rem * rem ```````````````````````````````````````````````````````````````` rem ` if collision(missile1,player0) then missile1y=255 : pfscore1 = pfscore1/4 rem **************************************************************** rem * rem * If ball touches player, subtract from score and remove ball. rem * rem ```````````````````````````````````````````````````````````````` rem ` if collision(player0,ball) then bally = 255 : pfscore1 = pfscore1/4 rem **************************************************************** rem * rem * If ball touches missile, remove missile. rem * rem ```````````````````````````````````````````````````````````````` rem ` if collision(missile0,ball) then missile0y = 255 rem **************************************************************** rem * rem * REMed out playfield collision since it's only being used to rem * keep the player from going too far left or right. rem * rem ```````````````````````````````````````````````````````````````` rem ` rem if !collision(player0,playfield) then goto __Skip_PF_Collision rem if m = 1 then player0y = player0y + 1 : goto __Skip_Move rem if m = 2 then player0x = player0x + 1 : goto __Skip_Move rem if m = 3 then player0y = player0y - 1 : goto __Skip_Move rem if m = 4 then player0x = player0x - 1 : goto __Skip_Move rem goto __Skip_Move __Skip_PF_Collision rem **************************************************************** rem * rem * If joystick moved left, do that and point player that way. rem * rem ```````````````````````````````````````````````````````````````` rem ` if joy0left then player0x = player0x - 2 : goto __Skip_Move rem **************************************************************** rem * rem * If joystick moved right, do that and point player that way. rem * rem ```````````````````````````````````````````````````````````````` rem ` if joy0right then player0x = player0x + 2 : m = 4 : goto __Skip_Move __Skip_Move rem **************************************************************** rem * rem * Keep the player from going too far left or right. rem * rem ```````````````````````````````````````````````````````````````` rem ` if player0x > 134 then player0x = 134 if player0x < 20 then player0x = 20 rem **************************************************************** rem * rem * Reset Program: rem * rem * Any Atari 2600 program should restart when the reset switch rem * is pressed. It is part of the usual standards and procedures. rem * rem ```````````````````````````````````````````````````````````````` rem ` if !switchreset then _Bit1_Debounce_Reset{1} = 0 : goto __Skip_Reset rem ```````````````````````````````````````````````````````````````` rem ` If Reset is pressed, but debounce bit is on, skip. rem ` if _Bit1_Debounce_Reset{1} then goto __Skip_Reset rem ```````````````````````````````````````````````````````````````` rem ` Reset the program. rem ` goto __Start_Restart __Skip_Reset goto __Main_Loop __Game_Over_Screen_Loop rem **************************************************************** rem * rem * Playfield colors. rem * rem ```````````````````````````````````````````````````````````````` rem ` COLUBK = 0 : COLUPF = $30 ballx = 255 : bally = 255 player0x = 255 : player0y = 255 player1x = 255 : player1y = 255 missile0x = 255 : missile0y = 255 missile1x = 255 : missile1y = 255 rem **************************************************************** rem * rem * Draws the screen. rem * rem ```````````````````````````````````````````````````````````````` rem ` playfield: ......XXXX..X...X.X..XXXX....... ......X....X.X.X.X.X.X.......... ......X.XX.XXX.X.X.X.XXXX....... ......X..X.X.X.X.X.X.X.......... ......XXXX.X.X.X.X.X.XXXX....... ................................ .......XX..X..X.XXXX.XXX........ ......X..X.X..X.X....X..X....... ......X..X.X..X.XXXX.XXX........ ......X..X..X.X.X....X..X....... .......XX....X..XXXX.X..X....... end drawscreen COLUP0 = $00 rem **************************************************************** rem * rem * If fire button pressed, leave title screen loop. rem * rem ```````````````````````````````````````````````````````````````` rem ` if joy0fire || joy1fire then goto __Start_Restart goto __Game_Over_Screen_Loop __Boss_Screen_Loop rem **************************************************************** rem * rem * Playfield colors. rem * rem ```````````````````````````````````````````````````````````````` rem ` COLUBK = 0 : COLUPF = $40 rem **************************************************************** rem * rem * Draws the screen. rem * rem ```````````````````````````````````````````````````````````````` rem ` playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X X..............................X end drawscreen Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 6, 2012 Share Posted December 6, 2012 One of the problems you keep introducing is adding random ENDs everywhere. There are specific things that end with END and those are the only times where you use it. Read this little section: http://www.randomter...mmands.html#end There are two problems that I see right away here: if _Kill_Counter = 20 then _Kill_Counter= 0 _Kill_Counter = _Kill_Counter +1 if _Kill_Counter = 20 : then goto __Boss_Screen_Loop The last line has a colon before THEN. You never want to put a colon there. Once you fix the last line, the program will never go to __Boss_Screen_Loop. Every time _Kill_Counter equals 20, you have it equal zero. You probably want to move your last line above the first one. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 6, 2012 Author Share Posted December 6, 2012 Yeah, I haven't learned where to put ends really, so I might overuse them. But I will learn in time =) Hm, I think I understand it better now, generally, when a command ends with : that's when an end command is used? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 6, 2012 Share Posted December 6, 2012 Yeah, I haven't learned where to put ends really, so I might overuse them. But I will learn in time =) Hm, I think I understand it better now, generally, when a command ends with : that's when an end command is used? (I also added more to my post above.) You really don't have to learn where to put ENDs. If you are using Visual batari Basic to make your playfields and sprites, it always includes the END for you. You don't have to add a bunch of random ENDs everywhere. It's only used for data-related stuff like this: player0: %00100010 %01110111 %01111111 end playfield: X.X...X..XX..X.XX.X....XX..X.X.. X.X....XX..X.X..X.X...X..XX..X.X end lives: %01000100 %11111110 %11111110 %01111100 %00111000 %00010000 %00010000 %00010000 end data _My_Data 200, 43, 33, 93, 255, 54, 22 end All of that kind of stuff is data. END tells batari Basic when to stop reading the data. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 6, 2012 Author Share Posted December 6, 2012 Ah, thanks for clearing that up =) Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 6, 2012 Author Share Posted December 6, 2012 Another question, how do I save the game as a .bin? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 7, 2012 Share Posted December 7, 2012 Another question, how do I save the game as a .bin? If you are using Visual batari Basic, your program is saved as a .bin when you compile it: www.youtube.com/watch?v=BklFnEGaB-w http://www.youtube.com/watch?v=BklFnEGaB-w There will be a folder in your project folder called bin where all of your .bin files for that project will be saved. You can't see it from VbB; you have to use a normal Windows Explorer folder. You can right click on the name of a project in VbB's Project Explorer and select Open Folder in Windows Explorer. Then you'll be able to see the bin folder. Your .bin files will end in .bas.bin. I always edit out the .bas part before I attach it to a post. It just looks better. Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 7, 2012 Author Share Posted December 7, 2012 Ahh, okay =) Now I have reinstalled windows and things are working much better. I'm finaly able too continue working on the project =) 1 Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 7, 2012 Author Share Posted December 7, 2012 Hm, it seems I have deleted the .bin. when I have compiled and test the program in Stella I get an error saying "Could not locate dragon_slayer.bas.bin and could not recompile" How do I fix this one? <_< Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted December 7, 2012 Share Posted December 7, 2012 Hm, it seems I have deleted the .bin. when I have compiled and test the program in Stella I get an error saying "Could not locate dragon_slayer.bas.bin and could not recompile" How do I fix this one? <_< If you have stripped the crap out of your computer and removed registry entries and all that good stuff, you'll need to make sure the settings are still there. Uncheck the boxes for Add bB Environment Variable and Add bB Compiler to System Path, click on those two check boxes again (so there are little check marks in the boxes), then click on the Save button. Close VbB, then open it again. If you're still getting the error, check the troubleshooting section: http://www.randomter...troubleshooting If you can't find an answer there, try this: http://www.randomter...tml#install_vbb Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted December 7, 2012 Author Share Posted December 7, 2012 (edited) Managed too fix it, thanks =D Edited December 7, 2012 by Rabbit 2600 Quote Link to comment Share on other sites More sharing options...
