Houdini Posted August 10, 2023 Share Posted August 10, 2023 On 12/28/2012 at 11:55 PM, Diskwiz said: No problem! Here it is. Oh also...it has the mod where if you hold the left shift button while hitting reset, it cold boots. Highspeed SIO patch V1.30 by Matthias Reichl. Could I ask at what offset the Left Shift coldstart routine resides? I would like to add it to my "Lite Touch" OS. Then it would be perfect to use with real drives. 😀 Quote Link to comment Share on other sites More sharing options...
Houdini Posted August 11, 2023 Share Posted August 11, 2023 I have a candidate for the XL/XE operating system "Lite Touch" version 2.0. This is a standard XL operating system with 2 important differences. The Option key is reversed so the computer defaults to basic off. Also it is patched with a Left-Shift and RESET coldstart feature. It seems to work fine on a real 130XE and Altirra. If anyone else could test that would be great. The LS-RESET code is Copyright (c) 2006 Matthias Reichl <hias@horus.com>, and can be found in the "Highspeed SIO patch V1.20 for Atari XL/XE OS and MyIDE OS" release. XL_LT2_Option Rev_LS_Coldstart.ROM Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 11, 2023 Share Posted August 11, 2023 some of these OS patches people do break the normal ability for software to control cartridges and internal basic and other rom packs. When making such changes always make sure that the setting is affected but not the programming mechanism/routine itself. That code should still function as normal, just the flags/control for boot should be changed. Don't reverse the logic. Quote Link to comment Share on other sites More sharing options...
kkrys Posted August 11, 2023 Share Posted August 11, 2023 (edited) XL/XE OS ver. 1.03, HiSpeed Hias, Reverse Option, Control Sum OK, Shift + Reset = Cold Start (as in QMEG) REV03 (HiSpeed) reverse Option.BIN Edited August 11, 2023 by kkrys Quote Link to comment Share on other sites More sharing options...
Houdini Posted August 11, 2023 Share Posted August 11, 2023 17 hours ago, _The Doctor__ said: some of these OS patches people do break the normal ability for software to control cartridges and internal basic and other rom packs. When making such changes always make sure that the setting is affected but not the programming mechanism/routine itself. That code should still function as normal, just the flags/control for boot should be changed. Don't reverse the logic. Agreed Doctor. I would not recommend burning ANY of the files in this thread to a real EPROM and soldering it into your Atari. Only use them if you have a device that can select an O.S. at will such as U1MB or SYSCHECK etc... Quote Link to comment Share on other sites More sharing options...
reifsnyderb Posted August 12, 2023 Share Posted August 12, 2023 19 hours ago, _The Doctor__ said: some of these OS patches people do break the normal ability for software to control cartridges and internal basic and other rom packs. When making such changes always make sure that the setting is affected but not the programming mechanism/routine itself. That code should still function as normal, just the flags/control for boot should be changed. Don't reverse the logic. One of my early goals, when compiling a new Atari OS (https://forums.atariage.com/topic/347696-compiling-a-new-atari-os/#comment-5205268), was to reverse the option key function. Unfortunately, I discovered this created some incompatibilities. So, I decided not to reverse the option key. 1 Quote Link to comment Share on other sites More sharing options...
