Dauber Posted January 6, 2013 Share Posted January 6, 2013 I got the 2600/7800 A/V mod kit from Vintage Gaming and More, followed the instructions to the letter, and...got no video signal. Audio works, but not video...and I really think the wire connecting the video is bad, especially as it broke off the motherboard three or four times, requiring a re-solder; the wire connecting the ground was also bad, as the thing broke into several pieces literally when I took it out of the bag, so I'm thinking maybe I'm not getting video because of bad cables; that would also explain why my sound (both POKEY and TIA) has a buzz... So I'm thinking it might be just the wires. I live walking distance from a Radio Shack, so I can just run over there and grab some wire. But what do I ask for?? Quote Link to comment Share on other sites More sharing options...
PSW Posted January 6, 2013 Share Posted January 6, 2013 (edited) I've done this mod twice - once from scratch using directions posted in this forum and the second time using the mod board from vintage gaming and more. In the "from scratch" method I discovered that my channel select switch on the motherboard was cutting off my video. Once I flipped the switch to the right channel, SHAZAM!, I got my video back. In my second install with the premade board, I failed to remove the sound resistors according to the instructions and I could "see" my sound in the video. Certain sounds would cause a distortion in the video. Once I pulled the resistors, the problem went away, and my video was clear as a bell. I'm not sure if any of these apply, but I hope this helps you in some way. Sorry, I failed to mention that I used solid hook up wire from Radio Shack for both installs, and I tinned the wire before install. Edited January 6, 2013 by PSW Quote Link to comment Share on other sites More sharing options...
Dauber Posted January 6, 2013 Author Share Posted January 6, 2013 I actually removed the channel selector completely. Quote Link to comment Share on other sites More sharing options...
Dauber Posted January 8, 2013 Author Share Posted January 8, 2013 OK, just to update...I invested in a multimeter (an analog - go ahead and yell at me, I don't care!), and found that I wasn't getting a good connection across the ground wires. I completely replaced it, and...*poof!* Solved the problem! Only thing now is that POKEY is barely audible. Not a huge deal because the only POKEY games I have are Beef Drop (which uses both POKEY and TIA) and Ball Blazer. I think I know what the problem is (I was impatient and used speaker wire and I think some of it frayed) but at least I have a playable 7800 again! And the difference between using the old RF modulator and RCA cables is HUGE....the clarity is great! Quote Link to comment Share on other sites More sharing options...
