sensato kuro Posted March 4, 2013 Share Posted March 4, 2013 I've got a 5200 system with no sound here. After reading the following post: http://www.atariage....-5200-no-sound/ I tried swapping the pokey chip as well as both 820pF polystirene caps (with another system which is fully working)... still no sound. Any clue what I should check next? I'm thinking about chekcing/replacing the pokey chip socket... I've checked the schematics (http://www.atariage...._5200_High.html) but I'm don't know what to do next. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
PSW Posted March 4, 2013 Share Posted March 4, 2013 Not sure if this will help you are not, but I also had a 5200 with no sound. Rather than fiddle with resistors and caps and what not, I installed an a/v mod made by AtariAge member low_budget. As it turns out, the a/v mod bypasses the on-board sound circuit, so after I installed the mod board, I had sound. However, without knowing exactly what is causing your problem, this is not guaranteed to fix your problem. Might be worth a shot to PM low_budget for advice. Quote Link to comment Share on other sites More sharing options...
sensato kuro Posted March 5, 2013 Author Share Posted March 5, 2013 Thanks for the input! I forgot to mention that I already have an A/V mod installed on this 5200 (low_budget v1.2 I believe. Sound doesn't come out from that either. I'll keep thinking about this in my spare times I guess. Quote Link to comment Share on other sites More sharing options...
