8_bit_jeremy Posted March 9, 2013 Share Posted March 9, 2013 (edited) Long story short, I bought a atari 2600 vader off ebay for $10. It said untested and turns out it doesn't work (which I sort of expected) The actual case is in beautiful shape so I figured if this was the case I could fix it up or just replace the insides completely as a little project. Is there any place online to buy one at a reasonable price thats totally intact and working (motherboard ready to go that is)? I don't seem to see anything on ebay. Basically it boots to a blank black screen. Some games, like q-bert I can see the game flash up for a split second and then reverts back to black. I tried cleaning the cartridge slot as well as wiggling things around and checking for damage but couldn't really find anything obvious. I also have a four switch woody and a jr that I tested a different power supply and video cable from but no dice. Thanks! Edited March 9, 2013 by 8_bit_jeremy Quote Link to comment Share on other sites More sharing options...
shadow460 Posted March 13, 2013 Share Posted March 13, 2013 Sounds like the RIOT isn't working. You might look at that screen a little closer. Usually when I have a console with a bad RIOT, there's a thin blue line on one side and a thin orange line on the other. Both lines run all the way from top to bottom of the screen. We know the power cable and RF cables are good because we're at least getting some output to the screen. The chip in question is located underneath the RF shield in both the 4 switch woody and the Vader. I'd try swapping the RIOT chips from console to console and see if the problem travels with one of the chips. If it does, the RIOT itself is an Atari 6532 IC. Several folks on here have them, so does Best Electronics. A RIOT chip should run you well under $10, even with shipping figured in. Quote Link to comment Share on other sites More sharing options...
Trinity Posted March 13, 2013 Share Posted March 13, 2013 Check the 7805 voltage regulator first. Should be five volt's DC output. Quote Link to comment Share on other sites More sharing options...
keoni29 Posted March 13, 2013 Share Posted March 13, 2013 Check the capacitors. If the capacitors are blown some lines get unstable and crash the game. This explains why some games pop on briefly before crashing. Quote Link to comment Share on other sites More sharing options...
shadow460 Posted March 14, 2013 Share Posted March 14, 2013 Check the 7805 voltage regulator first. Should be five volt's DC output. I forgot to mention this earlier. It's definitely putting out something, though, otherwise he'd have snow instead of a black screen. Quote Link to comment Share on other sites More sharing options...
keoni29 Posted March 14, 2013 Share Posted March 14, 2013 Checked those caps yet? Any broken address traces maybe? Sanded up the cartridge slot for a better connection? Any corrosion on socketed pins? Quote Link to comment Share on other sites More sharing options...
Trinity Posted March 14, 2013 Share Posted March 14, 2013 I forgot to mention this earlier. It's definitely putting out something, though, otherwise he'd have snow instead of a black screen. He mentioned, 'Some games, like q-bert I can see the game flash up for a split second and then reverts back to black.' I had the same symptom going on with my old VCS, And it was the regulator. Only out-putting 2.2 V DC. Swaped it out,,, Just like new! Quote Link to comment Share on other sites More sharing options...
8_bit_jeremy Posted March 14, 2013 Author Share Posted March 14, 2013 (edited) Thanks for the responses guys Looks like all my chips are soldered on so I'll have to get a desoldering thingy and I also need to find my multimeter. I will update if I end up getting anywhere Edited March 14, 2013 by 8_bit_jeremy Quote Link to comment Share on other sites More sharing options...
8_bit_jeremy Posted March 14, 2013 Author Share Posted March 14, 2013 The RIOT chip can be ruled out, as I swapped it out with my 4 switch woody. Accidently bent a pin on the woody one and it snapped off when I bent it back so I left the one from the vader in it. So yeah oops, So I'm thinking I'll have to get another one of those as well as getting a regulator and see if those two things will fix it. Quote Link to comment Share on other sites More sharing options...
8_bit_jeremy Posted March 16, 2013 Author Share Posted March 16, 2013 Actually i can probably fix the RIOT chip with a little soldering Thinking I will try the regulator.........would this one work? http://www.radioshack.com/product/index.jsp?productId=2062599&utm_source=Google&utm_medium=PPC&utm_term=2062599&utm_content=Exact&utm_campaign=PLA&cagpspn=pla&gclid=CKCwqMDYgbYCFSJ0MAodbzEAAA&gclsrc=ds Quote Link to comment Share on other sites More sharing options...
shadow460 Posted March 17, 2013 Share Posted March 17, 2013 That's the one. The one on the board should have continuity between one of the leads and ground. Of the other two leads you'll have around 5 volts DC on one and the other will have a value slightly higher than your power supply's rated voltage. Your power supply should be 9 volts. BTW, have you got an Atari brand power supply? Quote Link to comment Share on other sites More sharing options...
