orion1052003 Posted March 14, 2013 Share Posted March 14, 2013 I have the 2 port 5200. I read that there are differences in capabilities between the earlier and later models, besides the amount of ports being 2 or 4. I think lower serials numbers of the 2 port vs. the later 2 port models also have some different capabilities or something. Does anybody know the details? What does EP 268 mean? What is the significance of the serial number 124653? This must be the correct power adaptor? I don't want to fry it. It says for use with 5200 right on it, so I'm figuring it must be. Didn't want to use an old atari computer adaptor and blow it up if this is actually a computer power adaptor. It is big like one you would expect on a computer, and I bought the adaptor separately from the 5200 unit, at a goodwill. What do people typically use for a controller? A Wico controller with the 5200 cable and the original controller in the other port for START and PAUSE? orion Quote Link to comment Share on other sites More sharing options...
sqoon Posted March 14, 2013 Share Posted March 14, 2013 2-port and 4-port models use the same power pak. The only difference is that it plugs into the RFU on the 4-port and plugs into the console on the 2-port. Other difference I know if is that the early 4-port consoles will not play VCS games via the adapter add-on, while later 4-port and 2-port models do. Also, 2-port 5200's do not play all 5200 games in the original library while 4-port 5200's do. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 15, 2013 Share Posted March 15, 2013 2-port and 4-port models use the same power pak. The only difference is that it plugs into the RFU on the 4-port and plugs into the console on the 2-port. Other difference I know if is that the early 4-port consoles will not play VCS games via the adapter add-on, while later 4-port and 2-port models do. Also, 2-port 5200's do not play all 5200 games in the original library while 4-port 5200's do. I thought all 4 ports were not usable with the vcs adapter. If not then how do I tell if I have a late or early model. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted March 15, 2013 Share Posted March 15, 2013 I thought all 4 ports were not usable with the vcs adapter. If not then how do I tell if I have a late or early model. It should have either a + or * in the serial number, though not all of them do. Early 2port systems have the original BIOS that plays all of the games and not the revised BIOS that has compatibility problems with three games. Mitch Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 15, 2013 Share Posted March 15, 2013 It should have either a + or * in the serial number, though not all of them do. Early 2port systems have the original BIOS that plays all of the games and not the revised BIOS that has compatibility problems with three games. Mitch So you're saying some 4 ports without + or * can still use the vcs adapter?? 1 Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted March 15, 2013 Share Posted March 15, 2013 So you're saying some 4 ports without + or * can still use the vcs adapter?? Yes, I have one of those. Any 4 port can be modified to use the adapter, and I believe Atari Service did a number of them back in the day. Quote Link to comment Share on other sites More sharing options...
bohoki Posted March 15, 2013 Share Posted March 15, 2013 i wish you luck with your new adventure ,dont give up, dont panic,take it slow do you have a game? to get the best output to channel 3 i suggest a straight rca-female to f-connector-male they used to have them at radio shack i havent been there since they pretty much turned into a cell phone store mine is a 4 port that does not work with the 2600 adapter which i have ive made and adapted probably more controllers than anybody check previous posts for the games that are most fun you can often get a game lot cheap on the ebay they will always come with pacman since it was the pack in game for most systems (mine came with superbreakout) as far as i can tell the only 4 player games are superbreakout and tennis the games that require analog controls are superbreakout,kaboom,gorf,missle command,star wars a few other games make use of analog but you can get by without the wico stick is neat but it pretty much doesnt solve the problem people have which is non working start buttons so if you get a controller that wont press start there are a few games that start with a fire button (robotron,mr do) 2 games are dual stick optimized robotron,space dungeon if you have basic soldering skills i can walk you through adapting a 2600 controller or a pc gameport jjoystick or pad or if you have a little money i could send you a gamepad with an adapter for like $25 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 15, 2013 Share Posted March 15, 2013 Yes, I have one of those. Any 4 port can be modified to use the adapter, and I believe Atari Service did a number of them back in the day. So yours was serviced also? Or it came like that form the factory like that and works with the 2600 adapter with out the + or * in the serial number? Mine doesn't have a + or * either. So I need a better way to tell if mine can use the adapter or not. Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted March 15, 2013 Share Posted March 15, 2013 So yours was serviced also? Or it came like that form the factory like that and works with the 2600 adapter with out the + or * in the serial number? Mine doesn't have a + or * either. So I need a better way to tell if mine can use the adapter or not. I'm guessing that it was serviced, but I don't know for sure. Most 4-ports without the + or * won't work with the adapter, but if you really want to know (short of just plugging one in), you could try opening it up and looking for the mod. I don't believe there's a 4 port motherboard that will work with the adapter without it (but I could be wrong about that... Someone please correct me if I am.) I was indeed wrong about this... Corrected info below. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 15, 2013 Share Posted March 15, 2013 I don't have any mods. But there must be a better way to tell. What exactly is it that makes 2 ports palyable?? Why did they design different?? Is it the same exact motherboard except 2 ports versus 4?? Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted March 15, 2013 Share Posted March 15, 2013 I don't know the answers to these questions but the below link has schematics of the different motherboards and instructions for installing the mod if you want to dig into it. Just taking a quick look, I do see that the asterisk systems did have another motherboard with its own part #... CA018087 (4-Port Original) CA020108 (4-Port "Universal") So if your mobo's part # is CA020108, you're good to go! If it's CA018087 and there is no mod installed, then you're out of luck. http://console5.com/wiki/Atari_5200 Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 15, 2013 Share Posted March 15, 2013 (edited) Where on the motherboard is the part number listed?? And I don't want to risk opening it up and breaking it. Zylon fixed it so he might know. Otherwise I'll just buy one and see if I can ebay a cheap one. Edited March 15, 2013 by 0078265317 Quote Link to comment Share on other sites More sharing options...
marialisar Posted March 15, 2013 Share Posted March 15, 2013 Attached complete 2 port / 4 port / trackball service manual :-) Atari_5200_Field_Service_Manual.pdf Quote Link to comment Share on other sites More sharing options...
shadow460 Posted March 15, 2013 Share Posted March 15, 2013 I don't have any mods. But there must be a better way to tell. What exactly is it that makes 2 ports palyable?? Why did they design different?? Is it the same exact motherboard except 2 ports versus 4?? The 4 port system requires the special switchbox in order to even power up. Well, mine doesn't, but that's another thread. . The 2 port models still need a way of hooking up to the TV, but they can use any manual switchbox or an adapter. The power is provided through the dedicated cable from the power anvil (it's an anvil, not just a brick), whereas the 4 port gets power fed to it from the special switch box through the RF line. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 16, 2013 Share Posted March 16, 2013 The 4 port system requires the special switchbox in order to even power up. Well, mine doesn't, but that's another thread. . The 2 port models still need a way of hooking up to the TV, but they can use any manual switchbox or an adapter. The power is provided through the dedicated cable from the power anvil (it's an anvil, not just a brick), whereas the 4 port gets power fed to it from the special switch box through the RF line. So what does have to do with the vcs adapter working or not? Its still powered and the vcs is using power from the 5200. So what does it matter if it is the box on the 4 port or straight to the wall? Quote Link to comment Share on other sites More sharing options...
shadow460 Posted March 17, 2013 Share Posted March 17, 2013 So what does have to do with the vcs adapter working or not? Its still powered and the vcs is using power from the 5200. So what does it matter if it is the box on the 4 port or straight to the wall? The BIOS is also different in the two systems, and there are a few other changes to the motherboard besides that and the power circuit. Power modding the 4 port system sinply means you don't need the switchbox. If you wanna use the 2600 adapter you have to do another mod. I never looked into it since I've got more 2600s than I know what to do with. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 17, 2013 Share Posted March 17, 2013 (edited) I see. Well then will have to just buy one and see. Also just found one on ebay with a white slot. I can see the slot in the pic close up. Is the white cart connector more rare. Or did all vcs adapters have white slots. Edited March 17, 2013 by 0078265317 Quote Link to comment Share on other sites More sharing options...
bohoki Posted March 17, 2013 Share Posted March 17, 2013 the reason the 2600 adapter wont work on my 5200 is that it was not considered when it was created but later on they realized they could just use a couple unused lines of the cartridge plug to pass through audio and video so that is what the mod did so if you really want to go crazy you could make an adapter out of an old cart for anything with av out but that would just be using your 5200 as an rf modulator so it really gets quite silly Quote Link to comment Share on other sites More sharing options...
Retro Rogue Posted March 17, 2013 Share Posted March 17, 2013 the reason the 2600 adapter wont work on my 5200 is that it was not considered when it was created The 2600 adapter was planned from the beginning and was supposed to be ready for the launch. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 17, 2013 Share Posted March 17, 2013 I see thanks. But I'm not opening up mine and risking it. Maybe I'll just the the white slot vcs adapter. Anyone know if the white slot is more rare or were they all white. Quote Link to comment Share on other sites More sharing options...
+DamonicFury Posted March 17, 2013 Share Posted March 17, 2013 The 2600 adapter was planned from the beginning and was supposed to be ready for the launch. I don't doubt you, but why then do the early 5200's need to be modified? Quote Link to comment Share on other sites More sharing options...
Retro Rogue Posted March 18, 2013 Share Posted March 18, 2013 I don't doubt you, but why then do the early 5200's need to be modified? Because the way it wound up being done was different then what was originally planned. Remember, all expansion was originally planned to be through the expansion port on the 4-port. You can read more about the evolution of the 2600 adapter here. Quote Link to comment Share on other sites More sharing options...
0078265317 Posted March 20, 2013 Share Posted March 20, 2013 Nobody knows if the white ones are more rare?? Quote Link to comment Share on other sites More sharing options...
robertski Posted April 7, 2013 Share Posted April 7, 2013 The way I would recommend, is to use a Atari 5200 4-port with as low a serial number that you can get.. I have two. No mods.. Even though I want to do the power mod like crazy, I just dont. And use an original Atari 2600. DOnt use the 2600-adapter. It just looks too weird for me. Even though I have an adapter and cant use it, I may sell the thing on eBay one day.(but I cant test it out). Keep everything original.. THat's what I recommend. Quote Link to comment Share on other sites More sharing options...
