+Lee Stewart Posted February 21, 2022 Author Share Posted February 21, 2022 On 2/19/2022 at 12:21 PM, Lee Stewart said: maybe it’s time to make this fbForth 3.0? Perhaps, I will make it fbForth 2.1. Also, I need some thoughts about my last-posted question. Anybody? ...lee Quote Link to comment Share on other sites More sharing options...
HOME AUTOMATION Posted February 21, 2022 Share Posted February 21, 2022 On 2/19/2022 at 12:21 PM, Lee Stewart said: I can manage the address calculations at startup if necessary, but I would rather not. Does anyone know whether these addresses are , indeed, constant? Better safe than sorry. -HA 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 21, 2022 Share Posted February 21, 2022 15 minutes ago, Lee Stewart said: Perhaps, I will make it fbForth 2.1. Also, I need some thoughts about my last-posted question. Anybody? ...lee I have no direct knowledge but given that it's a 42 (?) year old design my money is on, it's not changing. It's just a feeling mind you. (There's always a smartass) 1 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 21, 2022 Share Posted February 21, 2022 (edited) Following Edited February 21, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted February 21, 2022 Share Posted February 21, 2022 13 hours ago, Lee Stewart said: Perhaps, I will make it fbForth 2.1. Also, I need some thoughts about my last-posted question. Anybody? ...lee TI created a lot of abstractions like the XMLLNK table that would have made changing the memory map possible on a future system. But if you are content with 4A compatibility, the silence suggests it is safe to assume the same console ROM in all. There is clearly a design intention for there to be various compatible versions of the console ROM. But proving the absence of something ever existing is never really satisfying. I should build a small cart that checksums the console ROM, as a diagnostic / identifier. Maybe a direct message to Jim 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted February 21, 2022 Share Posted February 21, 2022 There's maybe a difference on the v2 console (where they disabled cart ROM scanning). But that ROM is available in classic 99 so easily verified. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 21, 2022 Author Share Posted February 21, 2022 58 minutes ago, Willsy said: There's maybe a difference on the v2 console (where they disabled cart ROM scanning). But that ROM is available in classic 99 so easily verified. Just checked and the Floating Point XML table references are, indeed, the same—WooHoo! ...lee 3 Quote Link to comment Share on other sites More sharing options...
GDMike Posted February 21, 2022 Share Posted February 21, 2022 Wouldn't that be cool to have FPL used this way and making it easy to access. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 Ok...I am gearing up to produce fbForth 2.1. The first thing I am dong is adding auto-repeat to the keyboard. Here is the original code inherited from TI Forth: Spoiler KEY0 MOV @KEYCNT,R7 INC R7 JNE KEY1 MOV @CURPO$(U),R0 BLWP @VSBR Read character at cursor position... MOVB R1,@CURCHR ...and save it LI R1,>1E00 Place cursor character on screen BLWP @VSBW * KEY1 BLWP @KSCAN MOVB @KYSTAT,R0 COC @H2000,R0 check status JEQ KEY2 JMP if key was pressed * CI R7,100 No key pressed JNE KEY3 MOVB @CURCHR,R1 JMP KEY5 * KEY3 CI R7,200 JNE KEY4 CLR R7 LI R1,>1E00 Cursor char KEY5 MOV @CURPO$(U),R0 BLWP @VSBW KEY4 MOV R7,@KEYCNT MOV @INTACT,R7 Are we in user's ISR? JNE KEY6 Don't enable interrupts if so. LIMI 2 KEY6 DECT IP This will re-execute KEY B *NEXT KEY2 SETO @KEYCNT Key was pressed MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 B @BKLINK and here is my new code with auto-repeat: Spoiler * This routine has been modified to allow for key repeats by holding * a key down long enough. Repeats can be disabled by storing an odd * number at RH. User can do this by storing at DCT+16. Access to RL * is similarly at DCT+18, but should never be odd. * KEY0 INC @KEYCNT inc cursor/char blink count JNE KEY1 jump if re-entry MOV @CURPO$(U),R0 get cursor position BLWP @VSBR Read character at cursor position.. MOVB R1,@CURCHR ..and save it LI R1,>1E00 Place cursor character.. BLWP @VSBW ..on screen * * Check for keystroke KEY1 BLWP @KSCAN check keyboard.. MOVB @KYSTAT,R0 ..for keystroke COC @H2000,R0 check status JEQ KEY8 jump if key was pressed * * Check time for char blink LI R7,180 load time for char blink C @KEYCNT,R7 time to blink char? JNE KEY2 jump if not MOVB @CURCHR,R1 yes..get char to display JMP KEY3 and display it * * Check time for cursor blink KEY2 SLA R7,1 load time (360) for cursor blink C @KEYCNT,R7 time to blink cursor? JNE KEY4 jump if not CLR @KEYCNT yes..clear blink count for re-entry LI R1,>1E00 get cursor char KEY3 MOV @CURPO$(U),R0 get cursor position BLWP @VSBW display cursor or char * * Check for key, pressed or not KEY4 CB @KYCHAR,@HXFF00 no key? JNE KEY5 jump if we have a key MOV @RH,@RCNT reset repeat count JMP KEY6 re-enter via fbForth's KEY * * Repeat key processing KEY5 DECT @RCNT time to repeat key? JNE KEY6 jump if not yet time MOV @RL,@RCNT set repeat count to low count JMP KEY8 process key * * Set up to re-enter via fbForth's KEY KEY6 MOV @INTACT,R7 Are we in user's ISR? JNE KEY7 Don't enable interrupts if so. LIMI 2 no..enable interrupts KEY7 DECT IP re-execute fbForth's KEY B *NEXT * * Return pressed/same key to caller KEY8 SETO @KEYCNT -1 to reset re-entry indicator MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 JMP BKLINK Let me know if you have any improvements to the code. The next thing I will be working on is changing the FPL (Floating Point Library) to use the console ROM routines for FMUL,FDIV,FADD,FSUB,FCOM,CSN,CFI. This should be faster than my current ROM routines because they are on the 16-bit bus. I will then work on the remaining FPL routines to accommodate the console routines where they can be used (rounding, etc.). Any feedback will be appreciated. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2022 Share Posted March 8, 2022 That's a nice addition. How does a character get from R0 to top of stack? 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 1 hour ago, TheBF said: That's a nice addition. How does a character get from R0 to top of stack? The high-level KEY calls kEY , which gets to the system routine (via “BL *LINK”) that branches to the routine I posted. It is when that returns that R0 is pushed to the stack via code that duplicates what is commented out at the end of kEY : ;[*** KEY *** ( --- 7-bit-char ) * DATA KE__N * KEY__N .name_field 3, 'KEY' KEY DATA DOCOL DATA KE,LIT,>7F,_AND,SEMIS * ;]* ;[*** kEY *** ( --- char ) * DATA NCLS_N * KE__N .name_field 3, 'kEY' KE DATA $+2 LI R1,-2 MOV @$SYS(U),LINK BL *LINK JMP R02STK ; space-saving JMP [R02STK must be within 254 bytes] * DECT SP * MOV R0,*SP * B *NEXT * ;]* ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2022 Share Posted March 8, 2022 I don't understand the details of your trampoline or implications of it but could you replace R0 with *SP, by doing a DECT SP before you start the whole thing? (Maybe R0 is in another workspace?) 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 8 minutes ago, TheBF said: I don't understand the details of your trampoline or implications of it but could you replace R0 with *SP, by doing a DECT SP before you start the whole thing? (Maybe R0 is in another workspace?) Perhaps (it is, in fact, in the Forth workspace), but I would need to analyze everything that calls that system code. Most (all?) of those system routines pass values back and forth via registers. It is basically straight from TI Forth and there is likely a lot that could be optimized. Once I work through the FPL stuff, there will be some room in bank 3 to work with. I might be able to hoist quite a bit of stuff out of low RAM, but I would need to weigh the effects of trampolining in and out of bank 3. As things stand now, the system calls do not need trampoline code—they are in low RAM. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2022 Share Posted March 8, 2022 (edited) I am sure it would work just fine as is. It just seems that since the output needs to get there and the machine can reference memory real well that there could be some space saving by using [ EDIT *SP ] right out of the gate. I am also eyeballing KEYCNT ? and wondering about keeping it on the Rstack to save another variable. Edited March 8, 2022 by TheBF TYPO 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 7 hours ago, TheBF said: I am also eyeballing KEYCNT ? and wondering about keeping it on the Rstack to save another variable. That would be difficult to effect considering the use of KEY7 DECT IP re-execute fbForth's KEY B *NEXT to re-execute KEY because KEYCNT must persist through all re-entries until it gets reset to -1. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2022 Share Posted March 8, 2022 Ah. That is a wrinkle. So this not very Forthy but might save memory. Build a small stack frame for your variables on the data stack and reference them with indexed addressing and collapse it on the way out? Not sure if you'd eat more space with code than you do now with variables because indexed addressing eats up extra bytes too. I find the 9900 does not surrender to optimization without a fight. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 14 hours ago, Lee Stewart said: Ok...I am gearing up to produce fbForth 2.1. The first thing I am dong is adding auto-repeat to the keyboard. So far, it works! Now, I should modify the 40/80- and 64-column editors to remove their separate key routines. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2022 Share Posted March 8, 2022 Makes me wonder if I could shoe-horn repeating keys into my kernel. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 50 minutes ago, TheBF said: Makes me wonder if I could shoe-horn repeating keys into my kernel. Don’t know why not! ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 8, 2022 Share Posted March 8, 2022 Well... at the moment I play this game of keeping the thing inside the 8K limit. Might have to break that or oh... I don't know ... build a cartridge! It's on the stack now. For the moment I am shaming myself with this MachForth compiler. Oh and I owe you a thank you. I completely forgot about the COC instruction until I read your code. 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 8, 2022 Author Share Posted March 8, 2022 I now have auto-repeat working for the kernel’s keyboard routine, as well as using it successfully for the 40/80-column editor. This added 34 bytes to bank 1 (removing that same amount from the free space for the return stack in low RAM, but removed 202 bytes from the editor (also in bank 1), netting 168 more bytes in bank 1, which leaves 354 free bytes for mayhem in bank 1. I will worry about the 64-column editor later because it is not part of the cartridge code. Next, I think I will focus on reworking the FPL to use the console routines for FMUL,FDIV,FADD,FSUB,FCOM,CSN,CFI. Immediately after that, I will need to patch the remaining math routines where they use those same console routines: INT,^,SQR,EXP,EXP10,LOG,LOG10,COS,SIN,TAN,ATN, etc. If anyone would like to try out fbForth 2.1 as it is so far, I will try to get around to posting an alpha copy later today. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 9, 2022 Author Share Posted March 9, 2022 (edited) Before I get down and dirty with the FPL, I decided to add a feature to VOCABULARY that will take the responsibility from the programmer of making the definitions of new vocabularies IMMEDIATE : HEX : VOCABULARY ( --- ) ( IS:<vocabulary name> --- ) <BUILDS \ store precedence bit in NF of newly defined vocabulary 4000 LATEST +! \ make immediate \ initially point vocabulary link to PNF of previous vocabulary CURRENT @ 2+ , 81A0 , \ pseudo-name field HERE VOC-LINK @ , \ chronological link VOC-LINK ! \ update to point at above field DOES> CONTEXT ! ; It did add 8 bytes to bank 0, which now has only 28 bytes left. ...lee Edited March 9, 2022 by Lee Stewart correction Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 9, 2022 Author Share Posted March 9, 2022 Here is the first alpha build of fbForth 2.1 (build @) for you to try, along with a minimally updated FBLOCKS (none of the BLOADs will work) : fbForth210_8.bin fbForth210_9.bin fbforth210.rpk FBLOCKS ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 9, 2022 Author Share Posted March 9, 2022 DATA[ ... ]DATA in the above alpha release of fbForth 2.1 now can manage the line comment, \ . The three words that can be sprinkled amongst the list of numbers are ( ) <----inline comment \ <----rest-of-line comment --> <----next block loader (allows for multiblock number arrays) ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 9, 2022 Share Posted March 9, 2022 12 hours ago, Lee Stewart said: Before I get down and dirty with the FPL, I decided to add a feature to VOCABULARY that will take the responsibility from the programmer of making the definitions of new vocabularies IMMEDIATE : HEX : VOCABULARY ( --- ) ( IS:<vocabulary name> --- ) <BUILDS \ store precedence bit in NF of newly defined vocabulary 4000 LATEST +! \ make immediate \ initially point vocabulary link to PNF of previous vocabulary CURRENT @ 2+ , 81A0 , \ pseudo-name field HERE VOC-LINK @ , \ chronological link VOC-LINK ! \ update to point at above field DOES> CONTEXT ! ; It did add 8 bytes to bank 0, which now has only 28 bytes left. ...lee I have dim memories of arguments on this matter in 20th century. I can't remember the pros and cons. I the only negative implication I can think of is that you have to use [COMPILE] if you want to make a word that changes a vocabulary along with other stuff which is not too serious. Quote Link to comment Share on other sites More sharing options...
