+TheBF Posted April 19, 2022 Share Posted April 19, 2022 57 minutes ago, Lee Stewart said: Here is the next alpha of fbForth 2.1 (build #). In addition to the changes in build @, it adds the following: The cursor used by KEY is now the inverse of the character under the cursor. This is most apparent in the 40/80 column editor. Rewrote WLITERAL per discussion somewhere above. Rewrote zero-compare words, 0= , 0< , 0> , for efficiency. fbForth210_9.bin 32 kB · 1 download fbForth210_8.bin 32 kB · 1 download fbForth210.rpk 20.98 kB · 1 download ...lee That cursor with repeating keys is pretty slick Lee. 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 19, 2022 Author Share Posted April 19, 2022 12 hours ago, TheBF said: That cursor with repeating keys is pretty slick Lee. Adding an inverse-character cursor to KEY re-exposed a gotcha I had forgotten about. Initially, I used all of registers R0 – R7. This broke fbForth. I finally traced the problem to adding the use of R5. Fortunately, I could use CRU (R12) within the routine without any deleterious effect. Of course, I could not leave it there without knowing why I could not safely use R5. Using KEY in most situations is not a problem, but the infinite outer interpreter loop uses EXPECT to handle keyboard input and EXPECT calls KEY expecting R5 to be preserved. EXPECT uses R5 as a pointer to the current character position in the Terminal Input Buffer. Calling KEY with BL means that both EXPECT and KEY use the same workspace. The only indication this could be a problem was the comment, “R5 only safe reg”, I had added to my first use of R5 in the EXPECT code. For the terminally curious, the ALC for KEY follows in the spoiler: Spoiler ;[*== KEY routine CODE = -2 ================= * * Keyboard part of this routine uses all available Forth registers: * R0..R4, R6..R7, CRU * R5 is unavailable because EXPECT calls this routine expecting R5 * to be preserved! * KY MOV @$ALTI(U),R0 alternate input device? JEQ KEY0 jump to keyboard input if not * * R0 now points to PAB for alternate input device, the one-byte buffer * for which must immediately precede its PAB. PAB must have been set up * to read one byte. * CLR R7 prepare to zero status byte MOVB R7,@KYSTAT zero status byte INC R0 point R0 to Flag/Status byte BLWP @VSBR read it ANDI R1,>1F00 clear error bits without disturbing flag bits BLWP @VSBW write it back to PAB MOV R0,R1 Set up pointer... AI R1,8 ...to namelength byte of PAB MOV R1,@SUBPTR copy to DSR subroutine name-length pointer MOV R0,R3 save pointer (DSRLNK will trash it!) BLWP @DSRLNK get 1 byte from device DATA >8 MOV R3,R0 restore pointer DECT R0 point to one-byte VRAM buffer in front of PAB BLWP @VSBR read character SRL R1,8 move to LSB MOV R1,R0 copy to return register JMP BKLINK return to caller * * Input is coming from the keyboard. * * This routine has been modified to allow for key repeats by holding * a key down long enough. Repeats can be disabled by storing an odd * number at RH. User can do this by storing at DCT+16. Access to RL * is similarly at DCT+18, but should never be odd. * KEY0 INC @KEYCNT inc cursor/char blink count JNE KEY1 jump if re-entry MOV @CURPO$(U),R0 get cursor position BLWP @VSBR Read character at cursor position.. MOVB R1,@CURCHR ..and save it JMP KEY2A Place cursor character on screen * * Check for keystroke KEY1 BLWP @KSCAN check keyboard.. MOVB @KYSTAT,R0 ..for keystroke COC @H2000,R0 check status JEQ KEYX jump if key was pressed * * Check time for char blink LI R7,180 load time for char blink C @KEYCNT,R7 time to blink char? JNE KEY2 jump if not MOVB @CURCHR,R1 yes..get char to display JMP KEY3 and display it * * Check time for cursor blink KEY2 SLA R7,1 load time (360) for cursor blink C @KEYCNT,R7 time to blink cursor? JNE KEY4 jump if not CLR @KEYCNT yes..clear blink count for re-entry * * Cursor to Inverse of Current Character KEY2A MOVB @CURCHR,R0 ASCII of CURCHR to R0 SRL R0,8 get to LSB SLA R0,3 compute PDT offset of CURCHR pattern A @$PDT(U),R0 PDT position of CURCHR pattern in VRAM LI R1,CHRSAV CPU work area below LI R2,8 byte count to transfer BLWP @VMBR transfer bytes SETO R3 set R3 to all ones for XOR MOV R1,R4 copy CHRSAV address MOV R2,R6 copy byte count * * Pattern inversion loop... * ...using CRU (should be free to use here) because CRU is the * only available register left! KEY2LP MOV *R4,CRU copy pattern word to CRU XOR R3,CRU invert it MOV CRU,*R4+ copy inverted pattern back DECT R6 done? JNE KEY2LP invert another word if not done LI R0,>00F0 PDT offset of cursor char pattern A @$PDT(U),R0 PDT position of cursor char pattern in VRAM BLWP @VMBW write inverted pattern to cursor char pattern * * Continue cursor blink LI R1,>1E00 get cursor char KEY3 MOV @CURPO$(U),R0 get cursor position BLWP @VSBW display cursor or char * * Check for key, pressed or not KEY4 CB @KYCHAR,@HXFF00 no key? JNE KEY5 jump if we have a key MOV @RH,@RCNT reset repeat count JMP KEY6 re-enter via fbForth's KEY * * Repeat key processing KEY5 DECT @RCNT time to repeat key? JNE KEY6 jump if not yet time MOV @RL,@RCNT set repeat count to low count JMP KEYX process key * * Set up to re-enter via fbForth's KEY KEY6 MOV @INTACT,R7 Are we in user's ISR? JNE KEY7 Don't enable interrupts if so. LIMI 2 no..enable interrupts KEY7 DECT IP re-execute fbForth's KEY B *NEXT * * Return pressed/same key to caller KEYX SETO @KEYCNT -1 to reset re-entry indicator MOV @CURPO$(U),R0 Restore character at cursor location MOVB @CURCHR,R1 BLWP @VSBW MOVB @KYCHAR,R0 Put char in... SRL R0,8 ...LSB of R0 B @BKLINK return to caller * CHRSAV BSS 8 Work area for char inversion * ;]* ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 19, 2022 Share Posted April 19, 2022 You are pushing the old girl to the max. Your R0 comment is making me think about alternate in/out devices. I only recently realized that since EMIT and TYPE output to VDP RAM they could just as easily output to a PAB buffer. Duh! 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 19, 2022 Share Posted April 19, 2022 1 hour ago, Lee Stewart said: Of course, I could not leave it there without knowing why I could not safely use R5. Using KEY in most situations is not a problem, but the infinite outer interpreter loop uses EXPECT to handle keyboard input and EXPECT calls KEY expecting R5 to be preserved. EXPECT uses R5 as a pointer to the current character position in the Terminal Input Buffer. Would you ever consider replacing a register or 2 with with some local space on the R stack? 9900 *RP access is till pretty quick. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 19, 2022 Author Share Posted April 19, 2022 2 hours ago, TheBF said: Would you ever consider replacing a register or 2 with with some local space on the R stack? 9900 *RP access is till pretty quick. Surely. But, when writing ALC, I would just need to be very careful the return stack was cleared of local stuff before any possible exits (there are two)—except ABORT , of course. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 21, 2022 Author Share Posted April 21, 2022 (edited) fbForth has four different joystick words: JKBD for handling input from both the keyboard and the joysticks JCRU for reading only the CRU bits for the joysticks JOYST for calling JKBD ( JMODE = 0 ) or JCRU ( JMODE ≠ 0 ) JMODE for controlling behavior of JOYST I have rewritten the joystick routine ( JKBD ) that processes keyboard/joystick input via KSCAN. It recovers some space by using a smaller (16 bytes) lookup table (was 48 bytes) and doing away with MPY. I have included the code for your delectation. The old routine is in the first spoiler and the new routine (along with all of the above joystick words) is in the second spoiler: Spoiler *++ JTBL ++* table of values (chr, xstat & ystat) for JKBD *** JTBL BYTE >00,>00,>FC ; chr = >00 BYTE >00,>00,>00 ; chr = >01 (illegal) BYTE >02,>FC,>00 ; chr = >02 BYTE >03,>04,>00 ; chr = >03 BYTE >04,>FC,>04 ; chr = >04 BYTE >05,>00,>04 ; chr = >05 BYTE >06,>04,>04 ; chr = >06 BYTE >00,>00,>00 ; chr = >07 (illegal) BYTE >00,>00,>00 ; chr = >08 (illegal) BYTE >00,>00,>00 ; chr = >09 (illegal) BYTE >00,>00,>00 ; chr = >0A (illegal) BYTE >00,>00,>00 ; chr = >0B (illegal) BYTE >00,>00,>00 ; chr = >0C (illegal) BYTE >00,>00,>00 ; chr = >0D (illegal) BYTE >0E,>04,>FC ; chr = >0E BYTE >0F,>FC,>FC ; chr = >0F ;] ;[*** JKBD *** ( kbd --- chr xstat ystat ) * DATA MGFY_N * JKBD_N DATA 4+TERMBT*LSHFT8+'J','KB','D '+TERMBT JKBD DATA $+2 JKBDP MOVB @1(SP),@>8374 ; set keyboard mode LIMI 0 ; interrupts will be re-enabled when next routine returns BL @QKY ; get 0 or key to R0 (will be ignored) MOVB @>8375,@1(SP) ; get code from >8375 to right byte of top of stack MOV *SP,R1 ; also, to R1 DECT SP ; reserve stack space CLR *SP ; zero top of stack for byte transfer DECT SP ; reserve stack space CLR *SP ; zero top of stack for byte transfer CI R1,>0012 ; fire button? JEQ FBJOY CI R1,>00FF ; joystick? JEQ FBJOY CI R1,>000F ; legal joystick key? JLE JKBD01 LI R1,1 ; set to illegal chr JKBD01 ANDI R1,>000F ; strip all but last byte LI R0,3 ; load multiplier MPY R1,R0 ; multiply by 3 AI R1,JTBL ; get entry into JTBL MOVB *R1+,@5(SP) ; STACK: (from JTBL-->) chr 0 0 MOVB *R1+,@3(SP) ; STACK: (from JTBL-->) chr xstat 0 MOVB *R1,@1(SP) ; STACK: (from JTBL-->) chr xstat ystat JMP JKBDEX ; we're outta here FBJOY MOVB @>8377,@3(SP) ; STACK: 12h|FFh xstat 0 MOVB @>8376,@1(SP) ; STACK: 12h|FFh xstat ystat JKBDEX CLR R1 MOVB R1,@>8374 ; restore keyboard mode B *NEXT Spoiler * __ __ _ __ _ __ __ * __ / /__ __ _____ / /_(_)___/ /__ | | /| / /__ _______/ /__ * / // / _ \/ // (_-</ __/ / __/ '_/ | |/ |/ / _ \/ __/ _ (_-< * \___/\___/\_, /___/\__/_/\__/_/\_\ |__/|__/\___/_/ \_,_/___/ * /___/ ;[*++ JTBL ++* table of values (xstat & ystat) for JKBD *** ** Byte is a composite of the 2 bytes, xstat and ystat, for ** each left (1) or right (2) keyboard character from 0..>0F. ** Each nybble maps to an x|y-stat byte value as follows: ** Nybble x|y-stat ** ------ -------- ** >0 >00 ** >4 >04 ** >C >FC * JTBL BYTE >0C ; chr = >00 BYTE >00 ; chr = >01 (illegal) BYTE >C0 ; chr = >02 BYTE >40 ; chr = >03 BYTE >C4 ; chr = >04 BYTE >04 ; chr = >05 BYTE >44 ; chr = >06 BYTE >00 ; chr = >07 (illegal) BYTE >00 ; chr = >08 (illegal) BYTE >00 ; chr = >09 (illegal) BYTE >00 ; chr = >0A (illegal) BYTE >00 ; chr = >0B (illegal) BYTE >00 ; chr = >0C (illegal) BYTE >00 ; chr = >0D (illegal) BYTE >4C ; chr = >0E BYTE >CC ; chr = >0F ;] ;[*** JKBD *** ( kbd --- chr xstat ystat ) * DATA MGFY_N * JKBD_N .name_field 4, 'JKBD ' JKBD DATA $+2 JKBDP MOVB @1(SP),@>8374 ; set keyboard mode LIMI 0 ; disable interrupts BLWP @KSCAN ; get key MOV @INTACT,R7 ; Are we in user's ISR? JNE JKBD00 ; Don't enable interrupts if so LIMI 2 ; enable interrupts JKBD00 MOVB @>8375,@1(SP) ; get code from >8375 to LSB of top of stack MOV *SP,R1 ; also, to R1 DECT SP ; reserve stack space CLR *SP ; zero top of stack for byte transfer DECT SP ; reserve stack space CLR *SP ; zero top of stack for byte transfer CI R1,>0012 ; fire button? JEQ FBJOY CI R1,>00FF ; joystick? JEQ FBJOY CI R1,>000F ; possibly legal joystick key? JLE JKBD01 LI R1,1 ; nope..set to illegal chr JKBD01 ANDI R1,>000F ; strip all but last nybble MOVB @JTBL(R1),R2 ; copy byte (xstat,ystat) from JTBL to R2 JNE JKBD02 ; if not 0, skip zeroing chr CLR R1 ; zero chr for stack copy JMP JKBD03 ; STACK: [8375] 0 0 JKBD02 SRA R2,4 ; shift (with sign bit) MS nybble 1 nybble right MOVB R2,@3(SP) ; STACK: [8375]|0 xstat 0 SLA R2,8 ; shift ystat nybble to MSN SRA R2,4 ; shift (with sign bit) MSN 1 nybble right MOVB R2,@1(SP) ; STACK: [8375]|0 xstat ystat JKBD03 MOV R1,@4(SP) ; STACK: chr xstat ystat JMP JKBDEX ; we're outta here FBJOY MOVB @>8377,@3(SP) ; STACK: 12h|FFh xstat 0 MOVB @>8376,@1(SP) ; STACK: 12h|FFh xstat ystat JKBDEX CLR R1 MOVB R1,@>8374 ; restore keyboard mode B *NEXT * HEX * : JKBD ( kbd --- chr xstat ystat ) * 8374 C! * ?KEY DROP * 8375 C@ DUP ( STACK: chr chr) * 12 = ( chr=12h? [fire button] STACK: chr flag1) * OVER 0FF = ( chr=FFh? [joystick] STACK: chr flag1 flag2) * OR ( STACK: chr flag1 OR flag2) * IF ( fire button or joystick activated) * 8377 C@ 8376 C@ ( STACK: 12h|FFh xstat ystat) * ELSE ( key depressed) * DUP ( STACK: chr chr) * CASE * 4 OF 0FC 4 ENDOF * 5 OF 0 4 ENDOF * 6 OF 4 4 ENDOF * 2 OF 0FC 0 ENDOF * 3 OF 4 0 ENDOF * 0 OF 0 0FC ENDOF * 0F OF 0FC 0FC ENDOF * 0E OF 4 0FC ENDOF * DROP DROP 0 0 0 0 ( illegal key STACK: 0 0 0 0) * ENDCASE ( STACK: 0 0 0, if it gets here) * THEN ( STACK: chr xstat ystat) * 0 8374 C! ; ( restore previous full keyboard mode) ;] ;[*** JCRU *** ( joystick# --- value ) * Code for JCRU is courtesy of Mark Wills and was ported from his * TurboForth code for JOYST. * * DATA JKBD_N * JCRU_N .name_field 4, 'JCRU ' JCRU DATA $+2 JCRUP MOV *SP,R1 ; get unit number AI R1,5 ; use keyboard select 6 for #1, 7 for #2 SWPB R1 ; get keyboard select to MSB LI CRU,>0024 ; point to joystick/keyboard LDCR R1,3 ; strobe relevant joystick/keyboard line LI CRU,6 ; point to keyboard outputs STCR R1,5 ; store 5 bits SWPB R1 ; get to LSB INV R1 ; convert each strobe to 1 ANDI R1,>001F ; insure we have only the 5 bits of interest MOV R1,*SP ; push to stack for decoding by user CLR @>83D6 ; defeat auto screen blanking without KSCAN B *NEXT ;] ;[*** JMODE *** ( --- addr ) *++ User Variable contains 0 for TI Forth or ~0 for CRU) * DATA JCRU_N * JMDE_N .name_field 5, 'JMODE' JMODE DATA DOUSER ; get address of user variable JMODE to stack DATA $JMODE ;] ;[*** JOYST *** ( kbd|joyst --- [chr xst yst]|n ) * DATA JMDE_N * JOY__N .name_field 5, 'JOYST' JOYST DATA $+2 MOV @$JMODE(U),R0 ; test JMODE JEQ JKBDP ; JKBD, if JMODE = 0 JMP JCRUP ; JCRU, if JMODE = ~0 * : JOYST ( kbd|joyst --- [chr xst yst]|n ) * JMODE @ * IF * JCRU * ELSE * JKBD * THEN ; ;] ...lee Edited April 21, 2022 by Lee Stewart Added attribution for JCRU code 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21, 2022 Share Posted April 21, 2022 Is delectation legal in your state? ? 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21, 2022 Share Posted April 21, 2022 That's seem like a nice improvement. I don't fully understand the table. Does it translate joystick outputs to equivalent keyboard values? I have a very simple JOYST word which I have never used. I think I looked at Mark's code to figure something out. I see it looks very much like your JCRUP. \ HEX Outputs in TOS register \ 01 = Fire \ 02 = Left \ 04 = Right \ 08 = Down \ 10 = Up HEX CODE JOYST ( joystick# -- value ) \ #0 = joyst1, #1 = joyst2 0224 , 0006 , \ TOS 06 AI, \ joyst# to real CRU adress 06C4 , \ TOS SWPB, \ 020C , 0024 , \ R12 24 LI, \ joystick i/o address 30C4 , \ TOS 03 LDCR, \ write 3 bits to enable joysticks 020C , 0006 , \ R12 06 LI, \ select column 6 3544 , \ TOS 05 STCR, \ get 5 bits from joystick 06C4 , \ TOS SWPB, \ swap byte 0544 , \ TOS INV, \ change to positive logic 0244 , 001F , \ TOS 01F ANDI, \ mask off the junk 04E0 , 83D6 , \ 83D6 @@ CLR, \ reset screen timeout NEXT, ENDCODE Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 21, 2022 Author Share Posted April 21, 2022 (edited) 9 hours ago, TheBF said: I think I looked at Mark's code to figure something out. I see it looks very much like your JCRUP. That’s because I’m reasonably sure that’s where I got it. I should have credited @Willsy in the code. I will correct that tomorrow. [done] ...lee Edited April 21, 2022 by Lee Stewart 3 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 21, 2022 Author Share Posted April 21, 2022 1 hour ago, TheBF said: That seems like a nice improvement. I don't fully understand the table. Does it translate joystick outputs to equivalent keyboard values? Pretty much. The table covers the possible key-value range, 0 – 15 (0 – >F), and contains the corresponding equivalent of the directional joystick x and y bytes collapsed to two nybbles in one byte for each key value, obviating the need to calculate the table offset—the key value is the table offset. The illegal, i.e., non-joystick, key values ( 1, 7 – 13 ) are all returned as zeroes. The code is read into the MSB of R2 to be manipulated for the stack by a 4-bit arithmetic right shift that converts the left nybble to the x byte in the MSB. After copying that byte to the stack, two arithmetic shifts, 8 bits left followed by 4 bits right, isolate and convert the right nybble to the y byte in the MSB, which is subsequently copied to the stack. Allowable directional byte values are >00, >04, >FC. For the table, the left nybble of these bytes is simply dropped and the table byte composed of the remaining x and y nybbles. A retrieved table byte is processed by insuring that each nybble is the MSN (Most Significant Nybble) before right-shifting it into its proper position for transfer. This will fill the left nybble with the sign bit. Of course, this only matters for >C, which is changed from >C to >FC by the right arithmetic shift. I’ll stop talking now.... ...lee 3 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 21, 2022 Author Share Posted April 21, 2022 I am considering changing the bootup state of fbForth 2.1’s ISR. Currently, the ISR is enabled at bootup so that the fbForth speech and sound routines are processed by default. This does, unnecessarily, slow the interpreter down a touch. I suspect that the host of fbForth users out there are not very often availing themselves of the relatively new fbForth speech and sound routines. Servicing those and the user’s own ISR(s) is the only reason for enabling fbForth 2.1’s ISR. What do you think? ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21, 2022 Share Posted April 21, 2022 44 minutes ago, Lee Stewart said: I am considering changing the bootup state of fbForth 2.1’s ISR. Currently, the ISR is enabled at bootup so that the fbForth speech and sound routines are processed by default. This does, unnecessarily, slow the interpreter down a touch. I suspect that the host of fbForth users out there are not very often availing themselves of the relatively new fbForth speech and sound routines. Servicing those and the user’s own ISR(s) is the only reason for enabling fbForth 2.1’s ISR. What do you think? ...lee I think I remember some time back where I compared some benchmarks on FbForth with ISR running/not running and there was not a measurable difference. (I might have done it wrong) Back of the napkin, I would guess that entering the interrupt every 16mS and returning, after doing nothing, would not be much compared to the time spent in the inner interpreter. I think this is a good case for testing your hypothesis. 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 21, 2022 Author Share Posted April 21, 2022 5 hours ago, TheBF said: I think I remember some time back where I compared some benchmarks on FbForth with ISR running/not running and there was not a measurable difference. (I might have done it wrong) Back of the napkin, I would guess that entering the interrupt every 16mS and returning, after doing nothing, would not be much compared to the time spent in the inner interpreter. I think this is a good case for testing your hypothesis. I wrote some Forth words (see the spoiler below) to exercise the interpreter with ( +ISR ) and without ( -ISR ) the ISR hook enabled: Spoiler HEX : ZEROTIMER 0 83D6 ! \ zero screen timeout timer ; : TICKS ( -- ticks ) 83D6 @ \ read double ticks from timer 1 SRL \ convert to ticks ; DECIMAL : DOSTUFF ZEROTIMER CURPOS @ \ get cursor position 30001 1 DO \ loop 30000 times I 1000 MOD 0= IF \ every 1000 MODs DUP CURPOS ! \ reset cursor I . \ print loop index over last one THEN LOOP DROP \ clean up CR TICKS . ." ticks" CR \ result ; HEX : +ISR INTLNK @ 83C4 ! DOSTUFF ; : -ISR 0 83C4 ! DOSTUFF ; DECIMAL Each word runs DOSTUFF to loop a MOD calculation 30000 times, printing every 1000th iteration. When done, the number of timer ticks (60ths of a second) is displayed: Word Ticks ---- ----- +ISR 1559 -ISR 1547 As you can see the ISR was only ~0.8 % slower. Still.... ...lee 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21, 2022 Share Posted April 21, 2022 I stand corrected. So I guess it comes down to any other ramifications or inconvenience that disabling interrupts may cause. If I understand correctly you are just disabling your code on the USER interrupt. The screen timer etc. will still be running normally? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 21, 2022 Author Share Posted April 21, 2022 7 minutes ago, TheBF said: I stand corrected. So I guess it comes down to any other ramifications or inconvenience that disabling interrupts may cause. If I understand correctly you are just disabling your code on the USER interrupt. The screen timer etc. will still be running normally? Yes. Interrupts are not disabled. Rather, setting the ISR hook at >83C4 to 0, prevents the fbForth ISR from running every time the console ISR runs. Unless you really know what you are doing, user ISRs should never be installed at >83C4. That should be reserved for the address of the fbForth ISR contained in the INTLNK user variable. A user ISR’s cfa should be copied to the ISR user variable to be run by the enabled fbForth ISR. This is all explained in excruciating detail in Chapter 10 of fbForth 2.0: A File-Based Cartridge Implementation of TI Forth. ...lee 3 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21, 2022 Share Posted April 21, 2022 I am not surprised by the fastidiousness of the author. (Phd's don't come without it I am told) 1 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 27, 2022 Author Share Posted April 27, 2022 (edited) I finally got around to running the console ROM’s XML FMULT routine against fbForth 2.1’s F* in ROM3. The code is in the spoiler below: Spoiler HEX : ZEROTIMER 0 83D6 ! \ zero screen timeout timer ; \ One tick is 1/60 second : TICKS ( -- ticks ) 83D6 @ \ read double ticks from timer 1 SRL \ convert to ticks ; DECIMAL \ Test fbForth 2.1 ROM3 FP multiply : F*TEST1 ( fp1 fp2 -- ) ZEROTIMER 10000 0 DO FOVER FOVER F* \ fbForth 2.1 ROM3 FP multiply FDROP LOOP FDROP FDROP TICKS CR ." Done! " . ." ticks" ; HEX 834A CONSTANT FAC 835C CONSTANT ARG 0E88 CONSTANT FMULT 83E0 CONSTANT GPLWS 8300 CONSTANT FORTHWS \ Forth Assembler version of call to console ROM XML FMULT ASM: FXML* ( fp1 fp2 -- fp3 ) \ stack to ARG R0 ARG LI, *SP+ *R0+ MOV, *SP+ *R0+ MOV, *SP+ *R0+ MOV, *SP+ *R0 MOV, \ stack to FAC R0 FAC LI, *SP+ *R0+ MOV, *SP+ *R0+ MOV, *SP+ *R0+ MOV, *SP *R0 MOV, SP -6 AI, \ restore last FP top of stack \ call XML FMULT in console ROM GPLWS LWPI, \ change to GPL workspace FMULT @@ BL, \ call console FMULT FORTHWS LWPI, \ back to Forth workspace \ FAC to stack R0 FAC LI, *R0+ *SP+ MOV, *R0+ *SP+ MOV, *R0+ *SP+ MOV, *R0 *SP MOV, SP -6 AI, \ restore last FP top of stack ;ASM DECIMAL \ Test the console ROM XML FMULT routine : F*TEST2 ( fp1 fp2 -- ) ZEROTIMER 10000 0 DO FOVER FOVER FXML* \ console ROM XML FMULT FDROP LOOP FDROP FDROP TICKS CR ." Done! " . ." ticks" ; ASM: F2DROP ( fp1 fp2 -- ) SP 16 AI, \ pop 8 bytes from stack ;ASM \ Test the loop without FP multiply : FTEST ( fp1 fp2 -- ) ZEROTIMER 10000 0 DO FOVER FOVER F2DROP LOOP FDROP FDROP TICKS CR ." Done! " . ." ticks" ; F*TEST1 runs F* in a loop 10000 times. F*TEST2 runs FXML* in the same loop. Finally, FTEST runs the same loop, as a control, without any FP multiply. FTEST took 3.7 seconds. After accounting for that, F*TEST2 took 10.3 seconds, handily beating F*TEST1 's 17 seconds! F* and FXML* are running pretty much the same code. The time difference is entirely due to the console ROM running on the 16-bit bus over the fbForth ROM on the 8-bit bus. ...lee Edited April 28, 2022 by Lee Stewart ADDITIONAL COMMENT 5 Quote Link to comment Share on other sites More sharing options...
GDMike Posted April 27, 2022 Share Posted April 27, 2022 And eloquently Done I might add Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 13, 2022 Author Share Posted November 13, 2022 (edited) I did some work on the fbForth TMS9900 Assembler to attempt to reduce its footprint and to divine explanations for the words. I managed only a 90-byte reduction from 3208 to 3118. The explanations could probably use some work, but this is a start. So far, the only testing I have done is to confirm that it compiles successfully. The code is in the spoiler: Spoiler \ fbForth ASSEMBLER ..from TI Forth 12JUL82 LCT \ ..modified by Lee Stewart 12DEC2013 and 12NOV2022 HEX ASSEMBLER DEFINITIONS \ Helper word to test whether the operand includes an address? : ADDR? ( {addr} operand -- flag ) DUP 1F > SWAP \ S:operand>1F operand 30 < AND ; \ S:(operand>1F)&(operand<30) \ GOP' ..helper word to compile General address operand \ and OPcode. : GOP' ( {addr} operand opcode -- ) \ compute instruction and compile it OVER + , \ S:{addr} opnd ADDR? \ S:{addr} (opnd>1F)&(opnd<30) IF \ S:addr , \ compile addr ENDIF ; \ GROP' ..helper word to compile General address src and \ Register dst operands and OPcode. : GROP' ( {addr1} operand1 opcode operand2 -- ) 6 SLA + \ shift operand2 and add to opcode GOP' ; \ compute instruction..compile it and any address \ GOP ..define word to compile instruction with single General \ address operand and OPcode. : GOP ( opcode -- ) ( IS:<instruction name> ) <BUILDS , DOES> ( {addr} operand pfa -- ) @ \ S:{addr} operand opcode GOP' ; 0440 GOP B, 0680 GOP BL, 0400 GOP BLWP, 04C0 GOP CLR, 0700 GOP SETO, 0540 GOP INV, 0500 GOP NEG, 0740 GOP ABS, 06C0 GOP SWPB, 0580 GOP INC, 05C0 GOP INCT, 0600 GOP DEC, 0640 GOP DECT, 0480 GOP X, \ GROP ..define word to compile instruction with General \ address src and Register dst operands and OPcode. : GROP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( {addr1} operand1 operand2 pfa -- ) @ \ S:{addr1} operand1 operand2 opcode SWAP \ S:{addr1} operand1 opcode operand2 GROP' ; 2000 GROP COC, 2400 GROP CZC, 2800 GROP XOR, 3800 GROP MPY, 3C00 GROP DIV, 2C00 GROP XOP, \ GGOP ..define word to compile instruction with General \ address src and General address dst operands and OPcode. : GGOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( {{addr1} operand1 {addr2} operand2 pfa -- ) \ S:{ad} rop pfa @ SWAP DUP ADDR? \ S:{ad} rop opcd IF \ operand2 is a symbolic or indexed address ROT >R \ get addr2 to return stack GROP' R> , \ process instruction, ending by compiling addr2 ELSE \ operand2 is register-based GROP' \ process instruction (no addr2) ENDIF ; A000 GGOP A, B000 GGOP AB, 8000 GGOP C, 9000 GGOP CB, 6000 GGOP S, 7000 GGOP SB, E000 GGOP SOC, F000 GGOP SOCB, 4000 GGOP SZC, 5000 GGOP SZCB, C000 GGOP MOV, D000 GGOP MOVB, \ 0OP ..define word to compile instruction with 0 operands \ plus OPcode. : 0OP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( pfa -- ) @ , ; \ get opcode and compile instruction 0340 0OP IDLE, 0360 0OP RSET, 03C0 0OP CKOF, 03A0 0OP CKON, 03E0 0OP LREX, 0380 0OP RTWP, \ ROP ..define word to compile instruction with single \ Register operand and OPcode. : ROP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( reg pfa -- ) @ + , ; \ get opcode, add reg and compile instruction 02C0 ROP STST, 02A0 ROP STWP, \ IOP ..define word to compile instruction with Immediate \ value operand and OPcode. : IOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( n pfa -- ) @ , , ; \ get opcode..compile instruction and value 02E0 IOP LWPI, 0300 IOP LIMI, \ RIOP ..define word to compile instruction with Register \ and Immediate value operands and OPcode. : RIOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( reg n pfa -- ) @ ROT + , \ get opcode..add reg..compile instruction , ; \ compile immediate value 0220 RIOP AI, 0240 RIOP ANDI, 0280 RIOP CI, 0200 RIOP LI, 0260 RIOP ORI, \ RCOP ..define word to compile instruction with Register \ operand and shift Count value and OPcode. : RCOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( reg n pfa -- ) @ SWAP 4 SLA + + \ get opcode..add reg..add shift count , ; \ compile instruction 0A00 RCOP SLA, 0800 RCOP SRA, 0B00 RCOP SRC, 0900 RCOP SRL, \ DOP ..define word to compile instruction with signed-byte \ jump Distance (in 16-bit words) and OPcode. The last \ 3 CRU instructions are included here because they \ have the same format but with the CRU bit value \ instead of jump distance. : DOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( n pfa -- ) @ \ get opcode SWAP 00FF AND OR \ force n to byte and OR to opcode LSB , ; \ compile instruction 1300 DOP JEQ, 1500 DOP JGT, 1B00 DOP JH, 1400 DOP JHE, 1A00 DOP JL, 1200 DOP JLE, 1100 DOP JLT, 1000 DOP JMP, 1700 DOP JNC, 1600 DOP JNE, 1900 DOP JNO, 1800 DOP JOC, 1C00 DOP JOP, 1D00 DOP SBO, 1E00 DOP SBZ, 1F00 DOP TB, \ GCOP ..define word to compile instruction with General address \ and number-of-Cru-bits operands and OPcode. : GCOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( {addr} operand n pfa -- ) @ \ get opcode SWAP 000F AND \ force n to 0-15 GROP' ; \ process remainder of instruction 3000 GCOP LDCR, 3400 GCOP STCR, 00 CONSTANT R0 01 CONSTANT R1 02 CONSTANT R2 03 CONSTANT R3 04 CONSTANT R4 05 CONSTANT R5 06 CONSTANT R6 07 CONSTANT R7 08 CONSTANT R8 09 CONSTANT R9 0A CONSTANT R10 0B CONSTANT R11 0C CONSTANT R12 0D CONSTANT R13 0E CONSTANT R14 0F CONSTANT R15 08 CONSTANT UP 09 CONSTANT SP 0A CONSTANT W 0D CONSTANT IP 0E CONSTANT RP 0F CONSTANT NEXT \ Addressing modes 020 CONSTANT @() ( addr -- addr 020 ) : *? 010 + ( reg -- reg+010 ) ; : *?+ 030 + ( reg -- reg+030) ; : @(?) 020 + ( addr reg -- addr reg+020 ) ; : @(R0) R0 @(?) ; : *R0 R0 *? ; : *R0+ R0 *?+ ; : @(R1) R1 @(?) ; : *R1 R1 *? ; : *R1+ R1 *?+ ; : @(R2) R2 @(?) ; : *R2 R2 *? ; : *R2+ R2 *?+ ; : @(R3) R3 @(?) ; : *R3 R3 *? ; : *R3+ R3 *?+ ; : @(R4) R4 @(?) ; : *R4 R4 *? ; : *R4+ R4 *?+ ; : @(R5) R5 @(?) ; : *R5 R5 *? ; : *R5+ R5 *?+ ; : @(R6) R6 @(?) ; : *R6 R6 *? ; : *R6+ R6 *?+ ; : @(R7) R7 @(?) ; : *R7 R7 *? ; : *R7+ R7 *?+ ; : @(R8) R8 @(?) ; : *R8 R8 *? ; : *R8+ R8 *?+ ; : @(R9) R9 @(?) ; : *R9 R9 *? ; : *R9+ R9 *?+ ; : @(R10) R10 @(?) ; : *R10 R10 *? ; : *R10+ R10 *?+ ; : @(R11) R11 @(?) ; : *R11 R11 *? ; : *R11+ R11 *?+ ; : @(R12) R12 @(?) ; : *R12 R12 *? ; : *R12+ R12 *?+ ; : @(R13) R13 @(?) ; : *R13 R13 *? ; : *R13+ R13 *?+ ; : @(R14) R14 @(?) ; : *R14 R14 *? ; : *R14+ R14 *?+ ; : @(R15) R15 @(?) ; : *R15 R15 *? ; : *R15+ R15 *?+ ; : @(UP) UP @(?) ; : *UP UP *? ; : *UP+ UP *?+ ; : @(SP) SP @(?) ; : *SP SP *? ; : *SP+ SP *?+ ; : @(W) W @(?) ; : *W W *? ; : *W+ W *?+ ; : @(IP) IP @(?) ; : *IP IP *? ; : *IP+ IP *?+ ; : @(RP) RP @(?) ; : *RP RP *? ; : *RP+ RP *?+ ; : @(NEXT) NEXT @(?) ; : *NEXT NEXT *? ; : *NEXT+ NEXT *?+ ; \ Addressing modes in Wycove syntax 020 CONSTANT @@ \ equivalent to @() : ** *? ; : *+ *?+ ; : () @(?) ; ( DEFINE JUMP TOKENS ) \ constants are 2 bytes cheaper 01 CONSTANT GTE 02 CONSTANT H 03 CONSTANT NE 04 CONSTANT L 05 CONSTANT LTE 06 CONSTANT EQ 07 CONSTANT OC 08 CONSTANT NC 09 CONSTANT OO 0A CONSTANT HE 0B CONSTANT LE 0C CONSTANT NP 0D CONSTANT LT 0E CONSTANT GT 0F CONSTANT NO 10 CONSTANT OP : CJMP ?EXEC CASE LT OF 1101 , 0 ENDOF GT OF 1501 , 0 ENDOF NO OF 1901 , 0 ENDOF OP OF 1C01 , 0 ENDOF DUP 0< OVER 10 > OR IF 19 ERROR ENDIF DUP ENDCASE SWPB 1000 + , ; : IF, ?EXEC [COMPILE] CJMP HERE 2- 42 ; IMMEDIATE : ENDIF, ?EXEC 42 ?PAIRS HERE OVER - 2- 1 SRL SWAP 1+ C! ; IMMEDIATE : ELSE, ?EXEC 42 ?PAIRS 0 [COMPILE] CJMP HERE 2- SWAP 42 [COMPILE] ENDIF, 42 ; IMMEDIATE : BEGIN, ?EXEC HERE 41 ; IMMEDIATE : UNTIL, ?EXEC SWAP 41 ?PAIRS [COMPILE] CJMP HERE - 1 SRL 00FF AND HERE 1- C! ; IMMEDIATE : AGAIN, ?EXEC 0 [COMPILE] UNTIL, ; IMMEDIATE : REPEAT, ?EXEC >R >R [COMPILE] AGAIN, R> R> 2- [COMPILE] ENDIF, ; IMMEDIATE : WHILE, ?EXEC [COMPILE] IF, 2+ ; IMMEDIATE : THEN, [COMPILE] ENDIF, ; IMMEDIATE ( ENDIF, synonym ) \ : NEXT, *NEXT B, ; <---now in kernel \ RT pseudo-instruction : RT, *R11 B, ; FORTH DEFINITIONS : A$$M ; Comments and questions are encouraged! ...lee [Note: More modifications 2 posts down.] Edited November 13, 2022 by Lee Stewart ASSEMBLER MOD NOTE 2 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 13, 2022 Share Posted November 13, 2022 Since your new code is well commented and you are looking for space savings, you might consider commenting this section out, since the E/A manual tells us not to use these instructions except for RTWP. : 0OP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( pfa -- ) @ , ; \ get opcode and compile instruction 0340 0OP IDLE, 0360 0OP RSET, 03C0 0OP CKOF, 03A0 0OP CKON, 03E0 0OP LREX, 0380 0OP RTWP, I commented it out in my version and replaced it with: : RTWP, 0380 , ; 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted November 13, 2022 Author Share Posted November 13, 2022 4 hours ago, TheBF said: Since your new code is well commented and you are looking for space savings, you might consider commenting this section out, since the E/A manual tells us not to use these instructions except for RTWP. : 0OP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( pfa -- ) @ , ; \ get opcode and compile instruction 0340 0OP IDLE, 0360 0OP RSET, 03C0 0OP CKOF, 03A0 0OP CKON, 03E0 0OP LREX, 0380 0OP RTWP, I commented it out in my version and replaced it with: : RTWP, 0380 , ; Yeah—I did think of that, but got distracted by trying to decipher what those cryptic word names meant. I think I got all of those. Per your poke ( thanks! ), I have replaced 0OP and its defined words with the single RTWP, definition. This brings the fbForth Assembler down to 3040 bytes (down 168 bytes). Probably can’t get much lower. It is curious that TI allowed those warned-against instructions to be assembled for the TI-99/4A, unless the E/A Assembler was intended to assemble code that could be run elsewhere—the TI-990 minicomputer, perhaps. I do not think there is much utility for these discouraged words in this Forth Assembler—which should only be assembling code snippets, anyway. Here is the updated fbForth Assembler: Spoiler \ fbForth ASSEMBLER ..from TI Forth 12JUL82 LCT \ ..modified by Lee Stewart 12DEC2013 and 12NOV2022 HEX ASSEMBLER DEFINITIONS \ Helper word to test whether the operand includes an address? : ADDR? ( {addr} operand -- flag ) DUP 1F > SWAP \ S:operand>1F operand 30 < AND ; \ S:(operand>1F)&(operand<30) \ GOP' ..helper word to compile General address operand \ and OPcode. : GOP' ( {addr} operand opcode -- ) \ compute instruction and compile it OVER + , \ S:{addr} opnd ADDR? \ S:{addr} (opnd>1F)&(opnd<30) IF \ S:addr , \ compile addr ENDIF ; \ GROP' ..helper word to compile General address src and \ Register dst operands and OPcode. : GROP' ( {addr1} operand1 opcode operand2 -- ) 6 SLA + \ shift operand2 and add to opcode GOP' ; \ compute instruction..compile it and any address \ GOP ..define word to compile instruction with single General \ address operand and OPcode. : GOP ( opcode -- ) ( IS:<instruction name> ) <BUILDS , DOES> ( {addr} operand pfa -- ) @ \ S:{addr} operand opcode GOP' ; 0440 GOP B, 0680 GOP BL, 0400 GOP BLWP, 04C0 GOP CLR, 0700 GOP SETO, 0540 GOP INV, 0500 GOP NEG, 0740 GOP ABS, 06C0 GOP SWPB, 0580 GOP INC, 05C0 GOP INCT, 0600 GOP DEC, 0640 GOP DECT, 0480 GOP X, \ GROP ..define word to compile instruction with General \ address src and Register dst operands and OPcode. : GROP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( {addr1} operand1 operand2 pfa -- ) @ \ S:{addr1} operand1 operand2 opcode SWAP \ S:{addr1} operand1 opcode operand2 GROP' ; 2000 GROP COC, 2400 GROP CZC, 2800 GROP XOR, 3800 GROP MPY, 3C00 GROP DIV, 2C00 GROP XOP, \ GGOP ..define word to compile instruction with General \ address src and General address dst operands and OPcode. : GGOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( {{addr1} operand1 {addr2} operand2 pfa -- ) \ S:{ad} rop pfa @ SWAP DUP ADDR? \ S:{ad} rop opcd IF \ operand2 is a symbolic or indexed address ROT >R \ get addr2 to return stack GROP' R> , \ process instruction, ending by compiling addr2 ELSE \ operand2 is register-based GROP' \ process instruction (no addr2) ENDIF ; A000 GGOP A, B000 GGOP AB, 8000 GGOP C, 9000 GGOP CB, 6000 GGOP S, 7000 GGOP SB, E000 GGOP SOC, F000 GGOP SOCB, 4000 GGOP SZC, 5000 GGOP SZCB, C000 GGOP MOV, D000 GGOP MOVB, \ RTWP ( compiled by RTWP, ) is the only one of the six \ TMS9900 control instructions implemented here. : RTWP, 0380 , ; \ ROP ..define word to compile instruction with single \ Register operand and OPcode. : ROP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( reg pfa -- ) @ + , ; \ get opcode, add reg and compile instruction 02C0 ROP STST, 02A0 ROP STWP, \ IOP ..define word to compile instruction with Immediate \ value operand and OPcode. : IOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( n pfa -- ) @ , , ; \ get opcode..compile instruction and value 02E0 IOP LWPI, 0300 IOP LIMI, \ RIOP ..define word to compile instruction with Register \ and Immediate value operands and OPcode. : RIOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( reg n pfa -- ) @ ROT + , \ get opcode..add reg..compile instruction , ; \ compile immediate value 0220 RIOP AI, 0240 RIOP ANDI, 0280 RIOP CI, 0200 RIOP LI, 0260 RIOP ORI, \ RCOP ..define word to compile instruction with Register \ operand and shift Count value and OPcode. : RCOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( reg n pfa -- ) @ SWAP 4 SLA + + \ get opcode..add reg..add shift count , ; \ compile instruction 0A00 RCOP SLA, 0800 RCOP SRA, 0B00 RCOP SRC, 0900 RCOP SRL, \ DOP ..define word to compile instruction with signed-byte \ jump Distance (in 16-bit words) and OPcode. The last \ 3 CRU instructions are included here because they \ have the same format but with the CRU bit value \ instead of jump distance. : DOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( n pfa -- ) @ \ get opcode SWAP 00FF AND OR \ force n to byte and OR to opcode LSB , ; \ compile instruction 1300 DOP JEQ, 1500 DOP JGT, 1B00 DOP JH, 1400 DOP JHE, 1A00 DOP JL, 1200 DOP JLE, 1100 DOP JLT, 1000 DOP JMP, 1700 DOP JNC, 1600 DOP JNE, 1900 DOP JNO, 1800 DOP JOC, 1C00 DOP JOP, 1D00 DOP SBO, 1E00 DOP SBZ, 1F00 DOP TB, \ GCOP ..define word to compile instruction with General address \ and number-of-Cru-bits operands and OPcode. : GCOP ( opcode -- ) ( IS:<instruction name>) <BUILDS , DOES> ( {addr} operand n pfa -- ) @ \ get opcode SWAP 000F AND \ force n to 0-15 GROP' ; \ process remainder of instruction 3000 GCOP LDCR, 3400 GCOP STCR, 00 CONSTANT R0 01 CONSTANT R1 02 CONSTANT R2 03 CONSTANT R3 04 CONSTANT R4 05 CONSTANT R5 06 CONSTANT R6 07 CONSTANT R7 08 CONSTANT R8 09 CONSTANT R9 0A CONSTANT R10 0B CONSTANT R11 0C CONSTANT R12 0D CONSTANT R13 0E CONSTANT R14 0F CONSTANT R15 08 CONSTANT UP 09 CONSTANT SP 0A CONSTANT W 0D CONSTANT IP 0E CONSTANT RP 0F CONSTANT NEXT \ Addressing modes 020 CONSTANT @() ( addr -- addr 020 ) : *? 010 + ( reg -- reg+010 ) ; : *?+ 030 + ( reg -- reg+030) ; : @(?) 020 + ( addr reg -- addr reg+020 ) ; : @(R0) R0 @(?) ; : *R0 R0 *? ; : *R0+ R0 *?+ ; : @(R1) R1 @(?) ; : *R1 R1 *? ; : *R1+ R1 *?+ ; : @(R2) R2 @(?) ; : *R2 R2 *? ; : *R2+ R2 *?+ ; : @(R3) R3 @(?) ; : *R3 R3 *? ; : *R3+ R3 *?+ ; : @(R4) R4 @(?) ; : *R4 R4 *? ; : *R4+ R4 *?+ ; : @(R5) R5 @(?) ; : *R5 R5 *? ; : *R5+ R5 *?+ ; : @(R6) R6 @(?) ; : *R6 R6 *? ; : *R6+ R6 *?+ ; : @(R7) R7 @(?) ; : *R7 R7 *? ; : *R7+ R7 *?+ ; : @(R8) R8 @(?) ; : *R8 R8 *? ; : *R8+ R8 *?+ ; : @(R9) R9 @(?) ; : *R9 R9 *? ; : *R9+ R9 *?+ ; : @(R10) R10 @(?) ; : *R10 R10 *? ; : *R10+ R10 *?+ ; : @(R11) R11 @(?) ; : *R11 R11 *? ; : *R11+ R11 *?+ ; : @(R12) R12 @(?) ; : *R12 R12 *? ; : *R12+ R12 *?+ ; : @(R13) R13 @(?) ; : *R13 R13 *? ; : *R13+ R13 *?+ ; : @(R14) R14 @(?) ; : *R14 R14 *? ; : *R14+ R14 *?+ ; : @(R15) R15 @(?) ; : *R15 R15 *? ; : *R15+ R15 *?+ ; : @(UP) UP @(?) ; : *UP UP *? ; : *UP+ UP *?+ ; : @(SP) SP @(?) ; : *SP SP *? ; : *SP+ SP *?+ ; : @(W) W @(?) ; : *W W *? ; : *W+ W *?+ ; : @(IP) IP @(?) ; : *IP IP *? ; : *IP+ IP *?+ ; : @(RP) RP @(?) ; : *RP RP *? ; : *RP+ RP *?+ ; : @(NEXT) NEXT @(?) ; : *NEXT NEXT *? ; : *NEXT+ NEXT *?+ ; \ Addressing modes in Wycove syntax 020 CONSTANT @@ \ equivalent to @() : ** *? ; : *+ *?+ ; : () @(?) ; ( DEFINE JUMP TOKENS ) \ constants are 2 bytes cheaper 01 CONSTANT GTE 02 CONSTANT H 03 CONSTANT NE 04 CONSTANT L 05 CONSTANT LTE 06 CONSTANT EQ 07 CONSTANT OC 08 CONSTANT NC 09 CONSTANT OO 0A CONSTANT HE 0B CONSTANT LE 0C CONSTANT NP 0D CONSTANT LT 0E CONSTANT GT 0F CONSTANT NO 10 CONSTANT OP : CJMP ?EXEC CASE LT OF 1101 , 0 ENDOF GT OF 1501 , 0 ENDOF NO OF 1901 , 0 ENDOF OP OF 1C01 , 0 ENDOF DUP 0< OVER 10 > OR IF 19 ERROR ENDIF DUP ENDCASE SWPB 1000 + , ; : IF, ?EXEC [COMPILE] CJMP HERE 2- 42 ; IMMEDIATE : ENDIF, ?EXEC 42 ?PAIRS HERE OVER - 2- 1 SRL SWAP 1+ C! ; IMMEDIATE : ELSE, ?EXEC 42 ?PAIRS 0 [COMPILE] CJMP HERE 2- SWAP 42 [COMPILE] ENDIF, 42 ; IMMEDIATE : BEGIN, ?EXEC HERE 41 ; IMMEDIATE : UNTIL, ?EXEC SWAP 41 ?PAIRS [COMPILE] CJMP HERE - 1 SRL 00FF AND HERE 1- C! ; IMMEDIATE : AGAIN, ?EXEC 0 [COMPILE] UNTIL, ; IMMEDIATE : REPEAT, ?EXEC >R >R [COMPILE] AGAIN, R> R> 2- [COMPILE] ENDIF, ; IMMEDIATE : WHILE, ?EXEC [COMPILE] IF, 2+ ; IMMEDIATE : THEN, [COMPILE] ENDIF, ; IMMEDIATE ( ENDIF, synonym ) \ : NEXT, *NEXT B, ; <---now in kernel \ RT pseudo-instruction : RT, *R11 B, ; FORTH DEFINITIONS : A$$M ; Any further improvement will likely have to await my jamming it into ROM. 😇 ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted November 13, 2022 Share Posted November 13, 2022 I wondered about those instructions myself. It could just have been a zealous young engineer trying to be thorough. Not sure if this will actually net out smaller but you could try this code but add the traditional Fig-Forth ?PAIRS compiler testing for compatibility. The word AJUMP could be replaced with 0 CJMP I think. However adding the compiler tests might eat up any space savings. Repeat is 10 bytes smaller when done this way. CR .( Simplified branching and looping) : AJUMP, ( token --) >< 1000 + , ; \ >1000+token makes a jump instruction : RESOLVE ( 'jmp offset --) 2- 2/ SWAP 1+ C! ; \ compile offset into 'jmp' : <BACK ( addr addr' -- ) TUCK - RESOLVE ; : IF, ( addr token -- 'jmp') HERE SWAP AJUMP, ; : ENDIF, ( 'jmp addr --) HERE OVER - RESOLVE ; : ELSE, ( -- addr ) HERE 0 JMP, SWAP ENDIF, ; : BEGIN, ( -- addr) HERE ; : WHILE, ( token -- *while *begin) IF, SWAP ; : AGAIN, ( *begin --) HERE 0 JMP, <BACK ; : UNTIL, ( *begin token --) HERE SWAP AJUMP, <BACK ; : REPEAT, ( *while *begin -- ) AGAIN, ENDIF, ; 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 1, 2023 Author Share Posted January 1, 2023 I finally finished (I think!) debugging the font editor. There was more wrong with it than I thought!: CTRL-D, Load File, was corrupting the input file and forcing it to 12 KiB from 4 – 8 KiB. CTRL-X, Cut character pattern to clipboard, was acting like a normal character—bad test for function keys. Other piddling corrections I will post the next beta alpha (fbForth 2.1:$) later tonight. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted January 1, 2023 Author Share Posted January 1, 2023 Here is the promised alpha ( fbForth 2.1:$ ) fbForth210_8.bin fbForth210_9.bin fbForth210.rpk ...lee 3 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted January 2, 2023 Share Posted January 2, 2023 I got FBforth installed in MAME. Easy-peasy! So far, I haven't encountered any problems or errors. 2 Quote Link to comment Share on other sites More sharing options...
