+Lee Stewart Posted February 9 Author Share Posted February 9 Here is the promised build H: fbForth300_8_Ha.bin @Reciprocating Bill, please note that RL has been changed from 60 ticks to 100 ticks. You may, of course, prefer it slower yet. Let me know. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 10 Author Share Posted February 10 It was never clear to me why the TI programmers of TI Forth defined the word DSRLNK to presume its use for only Level 3 file handling. I am seriously considering changing the fbForth word DSRLNK (inherited from TI Forth) to require an argument of 8 for Level 3 file handling and 10 for Level 1 and 2 subprograms, just as its ALC counterpart. This will obviously require any TI Forth code ported to fbForth to put 8 on the stack before DSRLNK is executed. Thoughts? ...lee 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 10 Share Posted February 10 9 minutes ago, Lee Stewart said: It was never clear to me why the TI programmers of TI Forth defined the word DSRLNK to presume its use for only Level 3 file handling. I am seriously considering changing the fbForth word DSRLNK (inherited from TI Forth) to require an argument of 8 for Level 3 file handling and 10 for Level 1 and 2 subprograms, just as its ALC counterpart. This will obviously require any TI Forth code ported to fbForth to put 8 on the stack before DSRLNK is executed. Thoughts? ...lee I think it's a great idea. I have been meaning to do something like that for a long time. I just hate touching the DSRLNK because my life goes on hold for awhile when I do. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 14 Author Share Posted February 14 (edited) I have changed the word DSRLNK to expect 8 or 10 on the stack rather than presuming 8. This breaks DIR and CAT and “TI Forth disk browser/copier” on FBLOCKS, which I will correct in the next rewrite of FBLOCKS. After a confab with @atrax27407, I have added the option of toggling case sensitivity for (FIND) with a new word: CSEN 0 CSEN \ sets case sensitivity OFF 1 CSEN \ sets case sensitivity ON (this is the default) Current beta: fbForth300_8_Ia.bin <<====faulty case-insensitive function...see next beta posted later!! ...lee Edited February 15 by Lee Stewart corrections 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted February 14 Share Posted February 14 Thanks, Lee😄 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 15 Author Share Posted February 15 The last beta had a faulty case-insensitive function—too quick on the draw, alas. Here is a better beta: fbForth300_8_Ja.bin Here is the ALC of (FIND) for the terminally curious (see an example of X usage): Spoiler ;[*** (FIND) *** ( addr nfa --- false | pfa b true ) * String at addr should be padded with at least 1 blank at the end!! * * * DATA DIGI_N * PFIN_N .NAME_FIELD 6, '(FIND) ' * * PFIND DATA $+2 * BL @BLF2A * DATA _PFIND->6000+BANK2 * * This part must remain in bank 2 with headers to accommodate * searching without bank-switching! * * Register usage: * R0: work..argument to subroutines * R1: work..nfa running pointer * R2: work * R3: string buffer running pointer * R4: nfa pointer (constant per name) * R5: string buffer pointer (constant) * R6: work * R7: object of "X" instruction * W (R10): nfa count byte management * _PFIND MOV *SP,R4 ; nfa to R4 JEQ PFIND4 ; top of dictionary? *++ Set up R7 for case sensitivity jump... *++ "X R7" = "JMP PFIN2B" = "JMP PFIND1" LI R7,PFIN2B-PFIN2A/2-1+>1000 ;assume case sensitive search MOV @CASENS,R0 ;case sensitive? JNE PFIND0 ;yup.."JMP PFIN2B" LI R7,>1000 ;nope...."JMP $" = "NOP" *++ Copy search string to CHRBUF (>83A0) PFIND0 MOV @2(SP),R0 ;string source address LI R1,CHRBUF ;destination buffer address MOV R1,R5 ;save buffer address LI R2,32 ;unconditionally copying 32 bytes (max nf size) PFIN0A MOVB *R0+,*R1+ ;copy next byte DEC R2 ;done? JNE PFIN0A ;not yet *++ Set CHRBUF address for PFIN0B to avoid unnecessary NOP at PFIN2A MOV R5,R1 ;buffer address to R1 *++ "JMP PFIND1" /must/ be same distance as "JMP PFIN2B"!!! X R7 ;jump to PFIND1 if case-sensitive..else NOP *++ Make CHRBUF string uppercase if case-sensitivity is off PFIN0B MOVB *R1+,R2 ;string length to counter SRL R2,8 ;get to LSB, clearing MSB PFIN0C MOVB *R1,R0 ;get current char to R0 for CASEUP BL @CASEUP ;char to uppercase (code in low RAM) MOVB R0,*R1+ ;store possibly converted char..inc to next char DEC R2 ;done? JNE PFIN0C ;not yet PFIND1 MOV R4,R1 ;not top of dictionary..copy nfa to R1 MOV R5,R3 ;str buffer addr ptr to R3 MOVB *R1+,W ;copy nfa count byte to W; inc R1 to 1st char ANDI W,>3F00 ;mask out non-count bits, except smudge bit CB W,*R3+ ;compare char counts; inc R3 to 1st str char JNE PFIND3 ;counts the same? SWPB W ;yes..get count to LSB PFIND2 CB *R1+,*R3+ ;compare chars, incrementing nfa and str JEQ PFIN2C ;we have a match *++ "JMP PFIN2B" /must/ be same distance as "JMP PFIND1"!!! PFIN2A X R7 ;jump to PFIN2B if case-sensitive..else NOP *++ Case-insensitive comparison CLR R0 ;insure LSB is >00 for CASEUP MOVB @-1(R1),R0 ;re-get character from name field BL @CASEUP ;convert case (code in low RAM) MOVB @-1(R3),R6 ;re-get character from string buffer CB R0,R6 ;compare the two characters PFIN2B JNE PFIND3 ;if not equal then check next dict entry *++ We have a match PFIN2C DEC W ;decrememnt char count JNE PFIND2 ; if not 0 then check next character INC R1 ;all chars match!..insure address.. ANDI R1,>FFFE ;..is on a word boundary *++ R1 now points at cfa in RAM or pfa ptr in ROM INCT R1 ; increment R1 to pfa in RAM or pfa ptr+2 in ROM *++ Change to accommodate headers not in bank 2 (pfa ptr in R0) MOV R1,R0 ;for GETPFA BL @GETPFA ;check for ptr in ROM MOV R0,@2(SP) ;leave pfa on stack at same position as addr CLR *SP ;clear top stack position MOVB *R4,@1(SP) ;copy length byte to right byte of top of stack DECT SP ;make room on stack for 3rd cell MOV @CON01,*SP ;put >0001 on stack (true) JMP PFINDX ;return to inner interpreter PFIND3 MOV @-2(R4),R4 ;not = or counts different; get prev word's nfa JNE PFIND1 ;if not top of dictionary, try again PFIND4 INCT SP ;no match; top of dictionary; pop top of stack CLR *SP ;return false on top of stack PFINDX B @RTNEXT ;return to inner interpreter ;]* *++ <<<<<<<<<In low RAM >>>>>>>>>> *++ Convert lowercase character to uppercase *++ Input: R0 MSB = character to test *++ Output: R0 MSB = uppercase character CASEUP CI R0,>6100 ;compare to 'a' JLT CASEXT ;if < 'a', it's not a lowercase char CI R0,>7A00 ;else compare to z JGT CASEXT ;if > 'z', it's not a lowercase char ANDI R0,>DF00 ;to uppercase CASEXT RT ;return with char in uppercase ...lee 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted February 15 Share Posted February 15 How do we enable/disable case insensitivity? I see the CASENS flag in the code but it's not a variable name. Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted February 15 Author Share Posted February 15 4 minutes ago, TheBF said: How do we enable/disable case insensitivity? I see the CASENS flag in the code but it's not a variable name. New word CSEN (short for “Case SENsitivity”: 0 CSEN \ sets case sensitivity OFF 1 CSEN \ sets case sensitivity ON (this is the default) The value for “Case Sensitivity ON” can be any non-zero value. ...lee 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 1 Author Share Posted March 1 While working on my new DSRLNK, I had improved (I think) VRAM reads to use fewer instructions than I had used previously, so I thought I should review other ALC in the fbForth kernel for the same improvements. While doing so, I discovered a bug I had introduced into SPRGET while trying to fix a previous bug related to how a sprite’s y value is stored in the Sprite Attribute Table. The bugs and their ultimate fix are described in the excerpt from my fbForth 3.0 TODO list in the spoiler: Spoiler ++Fixed bug in SPRGET discovered while making changes to SPDST and SPDISTXY . If y=0, the value in SATR is >FF. After retrieving it and a logical 8-bit right shift, the value became >00FF (255). Incrementing by 1 to correct it to actual screen position, which for >FF should be 0, obviously gives the wrong position! **First solution created another bug!!: SRA R0,8 ;to right byte, clearing left byte unless negative INC R0 ;increment y --Works for >FF (-1): >FFFF + 1 = 0. --Fails miserably for >80..>FE (128..254): ::>FF80 + 1 = >FF81 (-127) [should be >0081 (129)] ::>FFFE + 1 = >FFFF (-1) [should be >00FF (255)] **Solution that works: AI R0,>0100 ;increment y before shift to handle possible -1 SRL R0,8 ;move to LSB, clearing MSB Here is the latest beta with the fix: fbForth300_8_Ka.bin <<< Happy now, Bob (@atrax27407)? >>> ...lee 1 2 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 1 Share Posted March 1 You're getting there! The "Wizard of Forth" strikes again. Busy putting the HSGPL version together. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 22 Author Share Posted March 22 OK... I now have the new DSRLNK working for all words/functions (blocks I/O, FILES word, Font Editor) except the high-level File words (Chapter 8 of the manual) and the alternate keyboard/display I/O. If you want to try it out, here is the beta: fbForth300_8La.bin Oh...I should add that current free space is down to bank 0: 116 bytes bank 1: 92 bytes bank 2: 172 bytes bank 3: 118 bytes ...lee 2 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 23 Share Posted March 23 I haven't been able to uncover any gross errors so far. 1 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 23 Share Posted March 23 Couple of things I just noticed but I may have an old version of FBLOCKS I do 6 LOAD. The compile flag EDT in block 12. I changed it to EDIT and it seems fine. Also the menu says "64 column editor" Is the 64 column editor supposed to be the one in TEXT mode? I always thought the 64 column editor was the one in SPLIT mode. Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 23 Share Posted March 23 (edited) There seems to be a problem with the latest FBLOCKS and the latest DSRLNK. I get errors when loading some of the BLOCKS (i.e., DIR) and some (but not all) others. I will have to go through the BLOCKS one by one to see which ones have load errors with the new DSRLNK. Edited March 23 by atrax27407 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 23 Author Share Posted March 23 On 3/23/2024 at 10:44 AM, TheBF said: Couple of things I just noticed but I may have an old version of FBLOCKS The current version of FBLOCKS is 17LUL2023 and definitely not up to date. I have to update any blocks that use DSRLNK. On 3/23/2024 at 10:44 AM, TheBF said: I do 6 LOAD. The compile flag EDT in block 12. I changed it to EDIT and it seems fine. EDT is the main word in the 64-column editor. EDIT is redefined to run EDT in the EDITOR2 vocabulary. On 3/23/2024 at 10:44 AM, TheBF said: Also the menu says "64 column editor" Is the 64 column editor supposed to be the one in TEXT mode? I always thought the 64 column editor was the one in SPLIT mode. It does, indeed, run in SPLIT mode. ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 23 Author Share Posted March 23 5 minutes ago, atrax27407 said: There seems to be a problem with the latest FBLOCKS and the latest DSRLNK. I get errors when loading some of the BLOCKS (i.e., DIR) and some (but not all) others. Yeah...any blocks with DSRLNK calls must be updated before they will run properly. I am nearly done with DSRLNK updates to the fbForth 3.0 cartridge. I will then get after FBLOCKS. Thanks to you and @TheBF for your tests! ...lee Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 26 Author Share Posted March 26 On 3/23/2024 at 11:39 AM, Lee Stewart said: Yeah...any blocks with DSRLNK calls must be updated before they will run properly. I am nearly done with DSRLNK updates to the fbForth 3.0 cartridge. I will then get after FBLOCKS. Thanks to you and @TheBF for your tests! OK...I am pretty much done with the Chapter-8 File I/O changes for the new DSRLNK. I also have working DIR and CAT utilities for the new FBLOCKS. I have been puzzling over what broke the 64-column editor and am reasonably sure it has to do with graphics mode switching and blocks I/O code. I did make changes to both and undoubtedly broke something. I did discover that, if I switch to Split mode before invoking the 64-column editor, it works. Exiting the editor shows issues, as well. I need to work through the mode-changing and blocks I/O code to shake out the bugs—too many balls in the air at once, I’m afraid! Aside from bug fixing (may not get done until after return from Florida next week) and managing the DSRLNK changes for Alternate I/O (RS232 card) for KEY and EMIT (easy) , I am nearly done with the cartridge code for fbForth 3.0. After I run down the bugs in recent code changes exposed by the 64-column editor, I will start knocking down the updates for FBLOCKS. Meanwhile, here is the current beta: fbForth300_8_Ma.bin Current remaining cartridge space (some improvement! ) bank 0: 162 bytes bank 1: 102 bytes bank 2: 184 bytes bank 3: 118 bytes ...lee 3 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted March 27 Share Posted March 27 22 minutes ago, Lee Stewart said: OK...I am pretty much done with the Chapter-8 File I/O changes for the new DSRLNK. I also have working DIR and CAT utilities for the new FBLOCKS. I have been puzzling over what broke the 64-column editor and am reasonably sure it has to do with graphics mode switching and blocks I/O code. I did make changes to both and undoubtedly broke something. I did discover that, if I switch to Split mode before invoking the 64-column editor, it works. Exiting the editor shows issues, as well. I need to work through the mode-changing and blocks I/O code to shake out the bugs—too many balls in the air at once, I’m afraid! Aside from bug fixing (may not get done until after return from Florida next week) and managing the DSRLNK changes for Alternate I/O (RS232 card) for KEY and EMIT (easy) , I am nearly done with the cartridge code for fbForth 3.0. After I run down the bugs in recent code changes exposed by the 64-column editor, I will start knocking down the updates for FBLOCKS. Meanwhile, here is the current beta: fbForth300_8_Ma.bin 32 kB · 2 downloads Current remaining cartridge space (some improvement! ) bank 0: 162 bytes bank 1: 102 bytes bank 2: 184 bytes bank 3: 118 bytes ...lee Enjoy your Florida trip, it's a bit rainy in this neck of the woods, but nice other wise. 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 27 Share Posted March 27 Downloaded, HSGPL-modified, and installed (and waiting for the next update 😁) Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 27 Author Share Posted March 27 12 hours ago, RickyDean said: Enjoy your Florida trip, it's a bit rainy in this neck of the woods, but nice other wise. We have enjoyed it since December 1. Returning to Maryland to, likely, rain April 2. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 28 Author Share Posted March 28 The problem with invoking the 64-column editor does, indeed, involve graphics mode switching. When the graphics mode is switched from non-bitmap modes (TEXT,TEXT80,GRAPHICS,MULTI) to bitmap modes (GRAPHICS2,SPLIT,SPLIT2) or vice versa, the system PABs (1user font file, 2 blocks files) are moved. The problem with the move is that the VRAM buffer address in each PAB does not get updated, so all hell breaks loose when the EDIT word is invoked with no intervening USEBFL (Use Blocks File). There may be one other VRAM location change that needs to be made, as well. I may be able to split COLD into more than one routine such that a part could be invoked by the mode change code to make everything better without too much code bloat. We’ll see .... ...lee 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 29 Author Share Posted March 29 Wow! This took a bit of head scratching and code wizardry(?). Everything related to graphics mode switching seems to be working now. The 64-column editor also works fine. Here is the current beta: fbForth300_8_Na.bin Gettin’ tighter!: bank 0: 162 bytes bank 1: 112 bytes bank 2: 118 bytes bank 3: 118 bytes ...lee fbForth300_8.bin 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 29 Share Posted March 29 Could you fire over your most recent FBLOCKS file as well? Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 29 Share Posted March 29 OK. Once again downloaded, HSGPL-modified, installed and awaiting the corrected FBLOCKS file. Will the individual applications reside on the same block #'s? Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 29 Author Share Posted March 29 14 hours ago, TheBF said: Could you fire over your most recent FBLOCKS file as well? 11 hours ago, atrax27407 said: OK. Once again downloaded, HSGPL-modified, installed and awaiting the corrected FBLOCKS file. Will the individual applications reside on the same block #'s? OK ... Here is a partially updated FBLOCKS: FBLOCKS The utilities marked “...OK..” just before the block# on the menu have either been updated or shown to work with the current beta. ...lee 1 Quote Link to comment Share on other sites More sharing options...
