atrax27407 Posted March 29 Share Posted March 29 (edited) Muchas gracias, Amigo! I have, however, found "a fly in the ointment". Blocks 70 and 71 BLK>file and FILE>BLK result in an error message and don't work properly. Edited March 29 by atrax27407 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 29 Author Share Posted March 29 5 hours ago, atrax27407 said: Muchas gracias, Amigo! I have, however, found "a fly in the ointment". Blocks 70 and 71 BLK>file and FILE>BLK result in an error message and don't work properly. My apologies! I actually have those working but forgot to compact and copy them to FBLOCKS. It will take me a little time to do that. In the meantime, here are the scripts: b2fexp.fbf f2bimp.fbf ...lee 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 30 Author Share Posted March 30 And.... Here is the updated FBLOCKS: FBLOCKS ...lee 1 Quote Link to comment Share on other sites More sharing options...
atrax27407 Posted March 30 Share Posted March 30 Quick response!!! 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 30 Share Posted March 30 4 hours ago, Lee Stewart said: And.... Here is the updated FBLOCKS: FBLOCKS ...lee I like having the 64 column editor drop down into the bottom window. Thanks! I am having flashbacks to 1984. I believe that editor was first developed by Dr. C. H. Ting, who passed away just last year. It's a damned clever hack. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 31 Author Share Posted March 31 (edited) 5 hours ago, TheBF said: I like having the 64 column editor drop down into the bottom window. Thanks! The next version of FBLOCKS will also allow exiting the old way, but with CTRL+9: Future exits from 64-column editor: FCTN+9: Exit editor to SPLIT2 SPLIT Text window CTRL+9: Exit editor to mode from which editor invoked ...lee Edited March 31 by Lee Stewart CORRECTION 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted March 31 Author Share Posted March 31 I know I mentioned this before, but I am thinking seriously of booting up fbForth 3.0 without enabling the fbForth ISR. It is enabled in fbForth 2.0. Besides enabling execution of user ISRs, the only reason to have it enabled is to use the fbForth speech and sound engines. This does not affect the BEEP and HONK words. Of course, you can always do sound lists per the E/A manual, with or without the fbForth ISR. And, you can always re-enable the ISR by jamming the contents of user variable INTLNK into >83C4. The fbForth ISR does not take a lot of time, but it is not nothing. If you don’t need it, it slows the system a touch. Of course, you can always disable it by storing 0 at >83C4. What do you think? ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted March 31 Share Posted March 31 Since its simple to install it I don't see a downside to leaving it out at boot time. Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 3 Share Posted April 3 Over on comp.lang.forth sjack has been playing with Fig Forth and presented these little tools. They seem to work perfectly on FbForth. Edit. Fixed some case issues from the original text. \ by: sjack - Wed, 3 Apr 2024 03:59 \ Put aside all my extensions and explored using FigForth core \ words only. Here are three of several things I found interesting: Fig-Forth 1.0.A ( Example #1, Stash data stack items) 2 CONSTANT CELL : XX S0 @ SP! ; : S0! S0 ! ; : !S0 TIB @ S0! ; : .S S0 @ BEGIN CELL - SP@ OVER < WHILE DUP ? REPEAT DROP ; ( some stack items.............) 1 2 3 4 5 .S 1 2 3 4 5 ( stash them...................) SP@ S0! ( use the stack................) 666 777 888 .S 666 777 888 ( restore stashed items........) XX !s0 .S 1 2 3 4 5 ( Example #2, Input counted string _directly_ into given storage area) : CREATE: <BUILDS DOES> ; : := DP @ SWAP DP ! 1 WORD DP ! ; CREATE: FOO 64 ALLOT ( storage area for counted string FOO) FOO := Hello Chuck! FOO COUNT CR TYPE Hello Chuck! I didn't test this one. ** Be careful it will edit disk block 60 which you don't want to do ** ( Example #3, Easily edit block screen without editor) 0 60 (LINE) DROP 1024 BLANKS 0 60 (LINE) EXPECT ( FOO BAR ) 1 60 (LINE) EXPECT : FOO ." foo " ; 2 60 (LINE) EXPECT : BAR ." bar " ; UPDATE FLUSH 60 LIST SCR # 60 0 ( FOO BAR ) 1 : FOO ." foo " ; 2 : BAR ." bar " ; 3 4 2 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 4 Author Share Posted April 4 7 hours ago, TheBF said: Over on comp.lang.forth sjack has been playing with Fig Forth and presented these little tools. They seem to work perfectly on FbForth. Edit. Fixed some case issues from the original text. \ by: sjack - Wed, 3 Apr 2024 03:59 \ Put aside all my extensions and explored using FigForth core \ words only. Here are three of several things I found interesting: Fig-Forth 1.0.A ( Example #1, Stash data stack items) 2 CONSTANT CELL : XX S0 @ SP! ; : S0! S0 ! ; : !S0 TIB @ S0! ; : .S S0 @ BEGIN CELL - SP@ OVER < WHILE DUP ? REPEAT DROP ; ( some stack items.............) 1 2 3 4 5 .S 1 2 3 4 5 ( stash them...................) SP@ S0! ( use the stack................) 666 777 888 .S 666 777 888 ( restore stashed items........) XX !s0 .S 1 2 3 4 5 ( Example #2, Input counted string _directly_ into given storage area) : CREATE: <BUILDS DOES> ; : := DP @ SWAP DP ! 1 WORD DP ! ; CREATE: FOO 64 ALLOT ( storage area for counted string FOO) FOO := Hello Chuck! FOO COUNT CR TYPE Hello Chuck! I didn't test this one. ** Be careful it will edit disk block 60 which you don't want to do ** ( Example #3, Easily edit block screen without editor) 0 60 (LINE) DROP 1024 BLANKS 0 60 (LINE) EXPECT ( FOO BAR ) 1 60 (LINE) EXPECT : FOO ." foo " ; 2 60 (LINE) EXPECT : BAR ." bar " ; UPDATE FLUSH 60 LIST SCR # 60 0 ( FOO BAR ) 1 : FOO ." foo " ; 2 : BAR ." bar " ; 3 4 #1 works, but XX is superfluous. SP! is already defined to clear the stack by storing the contents of S0 in the stack pointer. XX pushes the contents of S0 and SP! wipes it out, i.e., does not use it—so no harm done. Also, .S , though not in figFORTH, is defined in fbForth (from TI Forth) and I like it better because it shows the stack as unsigned numbers. I do like your BEGIN...WHILE...REPEAT instead of the DO...LOOP of fbForth because it looks shorter. #2 certainly works as written and, I must say, I like it a lot. I think, though, that I would define := as : := DUP 1 WORD C@ 1+ + =CELLS DP ! ; to make the string only as long as necessary. Of course, neither form is protected against a second invocation of := for the same string with a length beyond the original. #3 does not work properly for 2 reasons: (1) EXPECT must be executed (last word on the line) before typing the text following it, i.e., nothing happens until <enter> is tapped at the end of the line, so the typed string is ignored while EXPECT awaits input. (2) EXPECT stores 2 nulls after the string is entered. ...lee 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 4 Author Share Posted April 4 1 hour ago, Lee Stewart said: I do like your BEGIN...WHILE...REPEAT instead of the DO...LOOP of fbForth because it looks shorter. With a couple of changes (“ CELL - ” to “ 2- ” and “ ? ” to “ @ U. ”), the following code is, indeed, shorter—16 bytes less!: : .S ( -- ) CR ." | " S0 @ BEGIN 2- SP@ OVER < WHILE DUP @ U. REPEAT DROP ; ...lee 3 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 4 Share Posted April 4 10 hours ago, Lee Stewart said: #1 works, but XX is superfluous. SP! is already defined to clear the stack by storing the contents of S0 in the stack pointer. XX pushes the contents of S0 and SP! wipes it out, i.e., does not use it—so no harm done. Also, .S , though not in figFORTH, is defined in fbForth (from TI Forth) and I like it better because it shows the stack as unsigned numbers. I do like your BEGIN...WHILE...REPEAT instead of the DO...LOOP of fbForth because it looks shorter. #2 certainly works as written and, I must say, I like it a lot. I think, though, that I would define := as : := DUP 1 WORD C@ 1+ + =CELLS DP ! ; to make the string only as long as necessary. Of course, neither form is protected against a second invocation of := for the same string with a length beyond the original. #3 does not work properly for 2 reasons: (1) EXPECT must be executed (last word on the line) before typing the text following it, i.e., nothing happens until <enter> is tapped at the end of the line, so the typed string is ignored while EXPECT awaits input. (2) EXPECT stores 2 nulls after the string is entered. ...lee With number three you could make it work like the old "line" editing commands by adding a CR I think. : CLS 0 60 (LINE) DROP 1024 BLANKS ; : P ( n-- ) 60 (LINE) CR EXPECT ; Then edit away CLS 0 P ( THIS WILL GO TO THE TOP LINE ) 2 P : HELLO CR ." HELLO WORLD" ; ( tiniest editor ever) 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 9 Author Share Posted April 9 Regarding booting up fbForth with its ISR disabled, I will have PLAY , STREAM , SAY check for a cleared ISR hook (>83C4) and, upon seeing it cleared, exit the routine immediately. Do you think I should include a message such as, “ISR not active!” or just fail quietly? ...lee Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 9 Share Posted April 9 1 hour ago, Lee Stewart said: Regarding booting up fbForth with its ISR disabled, I will have PLAY , STREAM , SAY check for a cleared ISR hook (>83C4) and, upon seeing it cleared, exit the routine immediately. Do you think I should include a message such as, “ISR not active!” or just fail quietly? ...lee There is some S/W principle I have read that is something like "Do the expected thing". So I think a message is order since it will happen at run-time no? You could save a couple of bytes with "ISR missing" or "Bad ISR" ?? 2 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 9 Author Share Posted April 9 5 hours ago, Lee Stewart said: Regarding booting up fbForth with its ISR disabled, I will have PLAY , STREAM , SAY check for a cleared ISR hook (>83C4) and, upon seeing it cleared, exit the routine immediately. Do you think I should include a message such as, “ISR not active!” or just fail quietly? ...lee 4 hours ago, TheBF said: There is some S/W principle I have read that is something like "Do the expected thing". So I think a message is order since it will happen at run-time no? You could save a couple of bytes with "ISR missing" or "Bad ISR" ?? I added a routine to check for the ISR hook and, if not there, to call the fbForth ERROR word with the proper error message number to print “ISR?” after the usual “ERROR ?” and abort. While adding the new message, I took the opportunity to shorten many of the messages. Now, even after adding the ISR checking routine to bank#0 and the code to call it to 3 words in the same bank, there are 256 bytes free! I should add that the free-space increase is due not only to message size reduction but also to some other changes such as the redefinition of .S and shortening of a handful of words to use newly added words. There is still a little work before release. Here is the current state of the TODO list: fbForth300_TODO.txt ...lee 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 10 Author Share Posted April 10 One of my TODOs is to possibly change BRANCH and 0BRANCH to use absolute addresses (per @Willsy’s TurboForth) instead of an offset (per figFORTH/TI Forth/fbForth), but I really do not see the advantage except, possibly, at compile time, which does not seem that important. The difference at execution time is MOV *IP,IP <---IP is a register versus A *IP,IP <---IP is a register which take exactly the same amount of time, as far as I can tell. So, unless someone (@Willsy? @Tursi? @matthew180? @jedimatt42? @apersson850? @TheBF? ??) can show me a significant difference in execution time, I am inclined to leave sleeping dogs lie—the mod would be significant! ...lee 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted April 10 Share Posted April 10 Unless there's some other possibility to save in execution time, that opens up as a result of the change, it does indeed not look like any saving from that only thing you show in the post. 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 10 Share Posted April 10 12 hours ago, Lee Stewart said: One of my TODOs is to possibly change BRANCH and 0BRANCH to use absolute addresses (per @Willsy’s TurboForth) instead of an offset (per figFORTH/TI Forth/fbForth), but I really do not see the advantage except, possibly, at compile time, which does not seem that important. The difference at execution time is MOV *IP,IP <---IP is a register versus A *IP,IP <---IP is a register which take exactly the same amount of time, as far as I can tell. So, unless someone (@Willsy? @Tursi? @matthew180? @jedimatt42? @apersson850? @TheBF? ??) can show me a significant difference in execution time, I am inclined to leave sleeping dogs lie—the mod would be significant! ...lee I did a similar study a while back and saw no advantage to changing to absolute addresses and in fact if you wanted to relocate binary images of Forth code it's one less thing to worry about when you use relative branching. 2 Quote Link to comment Share on other sites More sharing options...
Willsy Posted April 15 Share Posted April 15 Been racking my brains to remember why I did it, but came up short. I *thought* I may have done it because it produced faster code, but as Lee has pointed out, it doesn't. Unless I did it under the mistaken assumption that the produced code was faster. The only other thing I can think of is perhaps it made the internal words that calculate jumps (that would be (IF) (THEN) and friends) a little bit shorter? I remember literally scouring the code base looking for ways to save single instructions here and there in order to fit some new word/feature into the 16K ROM space. 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 15 Author Share Posted April 15 3 hours ago, Willsy said: Been racking my brains to remember why I did it, but came up short. I *thought* I may have done it because it produced faster code, but as Lee has pointed out, it doesn't. Unless I did it under the mistaken assumption that the produced code was faster. The only other thing I can think of is perhaps it made the internal words that calculate jumps (that would be (IF) (THEN) and friends) a little bit shorter? I remember literally scouring the code base looking for ways to save single instructions here and there in order to fit some new word/feature into the 16K ROM space. It does save 4 bytes where the jump calculation is performed in ENDIF and BACK , and obviates the need for BACK , which saves 18 bytes for a total savings in the resident dictionary of 26 bytes. It also saves 2 trips through the inner interpreter in compiling LOOP +LOOP UNTIL AGAIN because “ , ” replaces BACK (defined as “ HERE - , ”), but time savings while compiling are not usually that important. ...lee 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 15 Share Posted April 15 5 hours ago, Willsy said: Been racking my brains to remember why I did it, but came up short. I *thought* I may have done it because it produced faster code, but as Lee has pointed out, it doesn't. Unless I did it under the mistaken assumption that the produced code was faster. The only other thing I can think of is perhaps it made the internal words that calculate jumps (that would be (IF) (THEN) and friends) a little bit shorter? I remember literally scouring the code base looking for ways to save single instructions here and there in order to fit some new word/feature into the 16K ROM space. Nice to see you back Mark. I suspect life has gotten in the way of the serious job of playing with Forth on a 40 year old machine. 3 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted April 20 Author Share Posted April 20 (edited) Nearly finished with updating FBLOCKS. I need to burn an EPROM with the latest beta so I can test my revised Compact Flash utilities. Actually, the only one I had to modify was CFPMOUNT , which is the word that writes the mounted DSK volume to the compact flash so that the mount persists past power-down. The change was necessitated by the new DSRLNK described a few posts back and here. ...lee Edited April 20 by Lee Stewart more information 3 Quote Link to comment Share on other sites More sharing options...
Willsy Posted April 21 Share Posted April 21 On 4/15/2024 at 2:54 PM, TheBF said: Nice to see you back Mark. I suspect life has gotten in the way of the serious job of playing with Forth on a 40 year old machine. Yeah, I'm lurking and post the odd drive-by here and there! Doing a lot of embedded electronics and C++ these days, and that's not even my main job! For my main job I've been developing a comms driver in C# to talk to legacy RTUs are that used over the entire length and breadth of the UK (controlling railway switching) - so pressure then :-) 2 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted April 21 Share Posted April 21 1 hour ago, Willsy said: Yeah, I'm lurking and post the odd drive-by here and there! Doing a lot of embedded electronics and C++ these days, and that's not even my main job! For my main job I've been developing a comms driver in C# to talk to legacy RTUs are that used over the entire length and breadth of the UK (controlling railway switching) - so pressure then :-) Wow that's important stuff. Bravo. There was a guy in the 90's in the UK who was doing railway systems in Forth. He had developed a method of proving the code was safe I believe which was a specification requirement. His name is escaping my old brain at the moment. Did some googling. It's Paul Bennet. https://wiki.forth-ev.de/lib/exe/fetch.php/en:projects:a-start-with-forth:certifyingforthsource_004_.pdf But nobody would begin to believe you can do anything well in Forth in the 21st century. I mean really, how could you, the compiler is not even 1MB. 1 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted May 7 Author Share Posted May 7 The current beta (fbForth 3.0:P) has the following changes: R@ as a synonym for R fbForth ISR disabled at bootup (enable by storing contents of INTLNK at >83C4, the console ISR hook) PLAY , STREAM , SAY will display “ISR?” if fbForth ISR is disabled Shortened system error messages (made more room in bank 0) Low expansion memory lowest available RAM address is stored at >837E by COLD (>837E is safe because it is only used by GPL routines that modify the screen) Here are the current beta and FBLOCKS: fbForth300_8_Pa.bin FBLOCKS Remove “_Pa” from the file name if you need to run with the ROM type as the last character, e.g., Classic99 with no entry in the INI file. I also opted not to try to include my ALC translation of XB’s RND and RANDOMIZE because they are way too large at 738 bytes. Current free space in the cartridge: bank 0: 266 bytes (more space from shorter error messages) bank 1: 106 bytes bank 2: 104 bytes bank 3: 118 bytes ...lee 2 Quote Link to comment Share on other sites More sharing options...
