+Gemintronic Posted April 11, 2013 Share Posted April 11, 2013 I'm trying to write a byte-code interpreter in bB. It'd be nice if I could use on .. goto but I seem to remember a limit of 12. Is this correct? If so, why haven't I seen this on R.T.s reference page? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted April 11, 2013 Share Posted April 11, 2013 I don't know the exact limit, but the bB page says this: If you have too many jumps to put comfortably in a single on … goto statement, you can break it up into multiple on … goto statements. Example: if x < 4 then on x goto 100 200 300 400 y = x - 4 : if y < 4 then on y goto 500 600 700 800 y = x - 8 : if y < 4 then on y goto 900 1000 1100 1200 Quote Link to comment Share on other sites More sharing options...
bogax Posted April 11, 2013 Share Posted April 11, 2013 (edited) I think the limit is the line length. bB doesn't seem to like lines over about 190 characters. (I can get it to compile for 44 labels) edit: I can't get it to do more than 45 labels even with a shorter line I believe when I asked about parameters I was told 46 was the limit, don't know if that's related Edited April 11, 2013 by bogax 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 12, 2013 Author Share Posted April 12, 2013 I think the limit is the line length. bB doesn't seem to like lines over about 190 characters. (I can get it to compile for 44 labels) edit: I can't get it to do more than 45 labels even with a shorter line I believe when I asked about parameters I was told 46 was the limit, don't know if that's related This would be good info to keep beside the sections on on .. goto/gosub R.T. we BASIC enthusiasts like to bang up against the compilers limits. Dimes to dollars this question will come up again Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted April 12, 2013 Share Posted April 12, 2013 How is this first attempt: randomterrain.com/atari-2600-memories-batari-basic-commands.html#limitations Then if you guys find other limitations, they can be put there too. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 12, 2013 Author Share Posted April 12, 2013 This looks good. I'm trying to think of other gotchas/limitations. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 29, 2013 Author Share Posted April 29, 2013 As a side I am currently able to use this line in a recent game without issue: on room goto A B C D E F G H I J K L M N O P Q R S T U V W X Y It sucks that the labels must be so terse but with R.T.s technique of using layers of on .. goto or on .. gosub it's passable. Quote Link to comment Share on other sites More sharing options...
bogax Posted April 29, 2013 Share Posted April 29, 2013 (edited) If you're going to need more than one if statement to break things up, on goto will be faster and shorter and constant time rem on i goto j = i / 8 : k = i & 7 on j goto slice0 slice1 slice2 slice3 slice0 on k goto lbl_00 lbl_01 lbl_02 lbl_03 lbl_04 lbl_05 lbl_06 lbl_07 slice1 on k goto lbl_08 lbl_09 lbl_10 lbl_11 lbl_12 lbl_13 lbl_14 lbl_15 slice2 on k goto lbl_16 lbl_17 lbl_18 lbl_19 lbl_20 lbl_21 lbl_22 lbl_23 slice3 on k goto lbl_24 lbl_25 lbl_26 lbl_27 lbl_28 lbl_29 lbl_30 lbl_31 for on gosub just gosub to the on goto(s) ( the lbl_xx will be the subroutines ) (which will require moving the on gotos out of the way) rem on i gosub gosub select . . select j = i / 8 : k = i & 7 on j goto slice0 slice1 slice2 slice3 slice0 on k goto lbl_00 lbl_01 lbl_02 lbl_03 lbl_04 lbl_05 lbl_06 lbl_07 slice1 on k goto lbl_08 lbl_09 lbl_10 lbl_11 lbl_12 lbl_13 lbl_14 lbl_15 slice2 on k goto lbl_16 lbl_17 lbl_18 lbl_19 lbl_20 lbl_21 lbl_22 lbl_23 slice3 on k goto lbl_24 lbl_25 lbl_26 lbl_27 lbl_28 lbl_29 lbl_30 lbl_31 Edited April 29, 2013 by bogax 1 Quote Link to comment Share on other sites More sharing options...
Cybearg Posted April 29, 2013 Share Posted April 29, 2013 But stacking on...goto statements wastes cycles. It would be better to just use some Assembly. It's pretty simple, since it's basically just an array. on temp1 goto go1 go2 go3 go4 translates to: LDX temp1 LDA .L03jumptablehi,x PHA LDA .L03jumptablelo,x PHA RTS .L03jumptablehi .byte >(.go1-1) .byte >(.go2-1) .byte >(.go3-1) .byte >(.go4-1) .L03jumptablelo .byte <(.go1-1) .byte <(.go2-1) .byte <(.go3-1) .byte <(.go4-1) So, to use your example: asm LDX room LDA .roomjumptablehi,x PHA LDA .roomjumptablelo,x PHA RTS end That'll handle the actual jump, so put that where you want the on...goto statement to execute, then somewhere in the file (probably at the end of your game) put the tables it points to: asm .roomjumptablehi .byte >(.A-1) .byte >(.B-1) .byte >(.C-1) .byte >(.D-1) .byte >(.E-1) .byte >(.F-1) .byte >(.G-1) .byte >(.H-1) .byte >(.I-1) .byte >(.J-1) .byte >(.K-1) .byte >(.L-1) .byte >(.M-1) .byte >(.N-1) .byte >(.O-1) .byte >(.P-1) .byte >(.Q-1) .byte >(.R-1) .byte >(.S-1) .byte >(.T-1) .byte >(.U-1) .byte >(.V-1) .byte >(.W-1) .byte >(.X-1) .byte >(.Y-1) .byte >(.Z-1) .roomjumptablelo .byte <(.A-1) .byte <(.B-1) .byte <(.C-1) .byte <(.D-1) .byte <(.E-1) .byte <(.F-1) .byte <(.G-1) .byte <(.H-1) .byte <(.I-1) .byte <(.J-1) .byte <(.K-1) .byte <(.L-1) .byte <(.M-1) .byte <(.N-1) .byte <(.O-1) .byte <(.P-1) .byte <(.Q-1) .byte <(.R-1) .byte <(.S-1) .byte <(.T-1) .byte <(.U-1) .byte <(.V-1) .byte <(.W-1) .byte <(.X-1) .byte <(.Y-1) .byte <(.Z-1) end ... So you're doing exactly what bB would do, but you're just cutting out the batariBasic middle-man. And the nice thing is that these tables can have up to 256 entries (maybe more?): far more than you could hope for with a list in bB itself. Just make sure to make two table entries for each jump: one for the high (>) and one for the low (<) 1 Quote Link to comment Share on other sites More sharing options...
bogax Posted April 29, 2013 Share Posted April 29, 2013 But stacking on...goto statements wastes cycles. It would be better to just use some Assembly. It's pretty simple, since it's basically just an array. That's cheating (I don't think RT is doing assembly) Quote Link to comment Share on other sites More sharing options...
bogax Posted April 29, 2013 Share Posted April 29, 2013 You can put the labels into a table in bB You need to add a period to the beginning of the label(s) because that's what bB does The label, "label" is actually ".label" in the asm bB produces So (with a minimum of asm trickery ) you can do (something like) this rem on i goto temp1 = lbls_lo[i] : temp2 = lbls_hi[i] asm jmp (temp1) end data lbls_lo <.lbl_00, <.lbl_01, <.lbl_02, <.lbl_03 end data lbls_hi >.lbl_00, >.lbl_01, >.lbl_02, >.lbl_03 end This uses 2 more cycles and eight more bytes than Cybearg's (and two temp variables) Cybearg's label tables in bB rem on room goto asm LDX room LDA lbls_hi,x PHA LDA lbls_lo,x PHA RTS end data lbls_hi <(.lbl_00-1), <(.lbl_01-1), <(.lbl_02-1), <(.lbl_03-1) end data lbls_hi >(.lbl_00-1), >(.lbl_01-1), >(.lbl_02-1), >(.lbl_03-1) end 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted April 29, 2013 Author Share Posted April 29, 2013 @Cybearg: Frankenpooching asm into bB isn't for the standard user. At best canned libraries and routines are suitable. We have a pretty good idea how the title screen kernel works and interacts with other code whereas custom labels like the ones suggested above are proprietary to a single game and thus cannot build a common base of knowledge. Quote Link to comment Share on other sites More sharing options...
Omegamatrix Posted April 29, 2013 Share Posted April 29, 2013 But stacking on...goto statements wastes cycles. It would be better to just use some Assembly. It's pretty simple, since it's basically just an array. Very good! And yes, you can do up to 256 entries that way. If all of the jumps are within the same page you don't need a look up table for the high address, just manually add it after, i.e.: asm LDX room LDA #>(.A) PHA LDA .roomjumptablelo,x PHA RTS end Now if that won't work because the jumps could be to anywhere, then you could also write the lookup table as shown below. This is only good for 128 entries, but using "word" instead of "byte" is easier to maintain because the label is in a single table (and not split into two). It doesn't save you any bytes in the rom... you are just using a neater way of writing the label. asm LDX room LDA .roomjumptable+1,x PHA LDA .roomjumptable,x PHA RTS end asm .roomjumptable .word (.A-1) .word (.B-1) .word (.C-1) .word (.D-1) .word (.E-1) .word (.F-1) .word (.G-1) .word (.H-1) .word (.I-1) .word (.J-1) .word (.K-1) .word (.L-1) .word (.M-1) .word (.N-1) .word (.O-1) .word (.P-1) .word (.Q-1) .word (.R-1) .word (.S-1) .word (.T-1) .word (.U-1) .word (.V-1) .word (.W-1) .word (.X-1) .word (.Y-1) .word (.Z-1) end Finally, you may also lay the table horizontally to take up less space is your .bas or asm file: asm .word (.A-1),(.B-1),(.C-1),(.D-1),(.E-1),(.F-1),(.G-1),(.H-1),(.I-1) .word (.J-1),(.K-1),(.L-1),(.M-1),(.N-1),(.O-1),(.P-1),(.Q-1),(.R-1) .word (.S-1),(.T-1),(.U-1),(.V-1),(.W-1),(.X-1),(.Y-1),(.Z-1) end So yeah, not to hard at all, and you can do many labels. Quote Link to comment Share on other sites More sharing options...
