Arcade Posted May 11, 2013 Author Share Posted May 11, 2013 I think I'm more confused now Does using xprevious and yprevious allow for collision along walls/playfield objects? Also, will this help allow a character to move to another playfield without using code to have 100% playfield collision? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted May 11, 2013 Share Posted May 11, 2013 I think I'm more confused now Does using xprevious and yprevious allow for collision along walls/playfield objects? Also, will this help allow a character to move to another playfield without using code to have 100% playfield collision? For reference here is the example again: http://atariage.com/forums/topic/211997-wallobject-collision-and-multiple-screen-help/#entry2749964 It's something I carried over from Game Maker on the PC. They have built in variables for the previous x/y coordinates of objects. In this case I simulate that by using up two variables and name them xprevious and yprevious. At the start of our main loop I put the players x and y coordinate into xprevious/yprevious. Immediately after the drawscreen command I check for collisions and put the player back to his last collision-free coordinates. That example does not have any code to transition from one screen to another. That would be a different example. Note that Random Terrain doesn't like this example because the player doesn't "slide" off walls. You collide with the playfield and stay there until you back out. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted May 11, 2013 Share Posted May 11, 2013 Here is an uncommented "example" of changing rooms using ON GOTO statements. Basically, when the player reaches the bounry of the screen you set which direction he should pass (left, right, up down) and then go to the change_room routine. check_boundaries if player0x = 0 then player0x = 152 : direction = _left : goto change_room if player0x = 153 then player0x = 1 : direction = _right : goto change_room if player0y = 17 then player0y = 87 : direction = _up : goto change_room if player0y = 88 then player0y = 18 : direction = _down : goto change_room The change_room routine checks to see what room you are currently in and jumps to that specific section of code. change_room on current_room goto room0 room1 room2 room3 room4 room5 room6 room7 room8 Each rooms code now has a section that decides which room to change to based on the direction you exited the current room. room0 on direction goto draw_room0 draw_room2 draw_room1 draw_room6 draw_room3 Finally, we set the current room and draw it. draw_room0 current_room = 0 pfcolors: $0E $0C $0A $08 $0E $08 $0C $0A $0E $0A $08 end playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX X..............X................ X............XXX................ X...........X..X................ X..............X................ X..............X................ X..............X................ X..............X................ X..............X................ X...........XXXXXX.............. X............................... end goto after_check_boundaries roomchange.bas Quote Link to comment Share on other sites More sharing options...
bogax Posted May 11, 2013 Share Posted May 11, 2013 (edited) Look up tables are easy and fun look up your room: check_boundaries if player0x = 0 then player0x = 152 : direction = _left : goto change_room if player0x = 153 then player0x = 1 : direction = _right : goto change_room if player0y = 17 then player0y = 87 : direction = _up : goto change_room if player0y = 88 then player0y = 18 : direction = _down : goto change_room after_check_boundaries if counter{4} then REFP0 = 8 drawscreen goto main change_room current_room = current_room * 4 + direction - 1 current_room = room_data[current_room] on current_room gosub drw_rm0 drw_rm1 drw_rm2 drw_rm3 drw_rm4 drw_rm5 drw_rm6 drw_rm7 drw_rm8 goto after_check_boundaries rem rows are rooms columns are directions data room_data 2, 1, 6, 3 0, 2, 7, 4 1, 0, 8, 5 5, 4, 0, 6 3, 5, 1, 7 4, 3, 2, 8 8, 7, 3, 0 6, 8, 4, 1 7, 6, 5, 2 end compute room: check_boundaries if player0x = 0 then player0x = 152 : room_col = sub[room_col] : goto change_room if player0x = 153 then player0x = 1 : room_col = add[room_col] : goto change_room if player0y = 17 then player0y = 87 : room_row = sub[room_row] : goto change_room if player0y = 88 then player0y = 18 : room_row = add[room_row] : goto change_room after_check_boundaries if counter{4} then REFP0 = 8 drawscreen goto main change_room current_room = room_row * 2 + room_row + room_col on current_room gosub drw_rm0 drw_rm1 drw_rm2 drw_rm3 drw_rm4 drw_rm5 drw_rm6 drw_rm7 drw_rm8 goto after_check_boundaries data sub 2, 0, 1 end data add 1, 2, 0 end lookup_room.bas compute_room.bas edit: the returns should have been return thisbank (now fixed) another edit: another option check_boundaries if player0x = 0 then player0x = 152 : current_room = subc[current_room] : goto change_room if player0x = 153 then player0x = 1 : current_room = addc[current_room] : goto change_room if player0y = 17 then player0y = 87 : current_room = subr[current_room] : goto change_room if player0y = 88 then player0y = 18 : current_room = addr[current_room] : goto change_room after_check_boundaries if counter{4} then REFP0 = 8 drawscreen goto main data subc 2, 0, 1 5, 3, 4 8, 6, 7 end data addc 1, 2, 0 4, 5, 3 7, 8, 6 end data subr 6, 7, 8 0, 1, 2 3, 4, 5 end data addr 3, 4, 5 6, 7, 8 0, 1, 2 end change_room on current_room gosub drw_rm0 drw_rm1 drw_rm2 drw_rm3 drw_rm4 drw_rm5 drw_rm6 drw_rm7 drw_rm8 goto after_check_boundaries direct_lookup.bas Edited May 12, 2013 by bogax 1 Quote Link to comment Share on other sites More sharing options...
Arcade Posted May 12, 2013 Author Share Posted May 12, 2013 Ah thank you both so much! I'll def have to try those out! Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 13, 2013 Share Posted May 13, 2013 Ah thank you both so much! I'll def have to try those out! You can also look at a demo I posted a while back called "move_around_rooms.bas"-- you should be able to find it in this forum by searching for that program name. It's sort of like bogax's "lookup_room.bas" except each direction has its own data matrix so you can have up to 256 rooms if you want. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted May 13, 2013 Share Posted May 13, 2013 You can also look at a demo I posted a while back called "move_around_rooms.bas"-- you should be able to find it in this forum by searching for that program name. It's sort of like bogax's "lookup_room.bas" except each direction has its own data matrix so you can have up to 256 rooms if you want. Here's the link: atariage.com/forums/topic/95820-adventure-type-game/#entry1162741 So far, the room code posted by you and bogax is way over my head. Are any of your examples similar to how it was done in Adventure? I know that Adventure was programmed using assembly language, but there must be a BASIC equivalent that we could come up with that we could put on the batari Basic page. A no_blank_lines Adventure-style batari Basic program with room data that can be easily adjusted by new users that also has items that can be picked up and dropped and bad guys doing bad guy things. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted May 13, 2013 Share Posted May 13, 2013 Here's the link: atariage.com/forums/topic/95820-adventure-type-game/#entry1162741 So far, the room code posted by you and bogax is way over my head. Are any of your examples similar to how it was done in Adventure? I know that Adventure was programmed using assembly language, but there must be a BASIC equivalent that we could come up with that we could put on the batari Basic page. A no_blank_lines Adventure-style batari Basic program with room data that can be easily adjusted by new users that also has items that can be picked up and dropped and bad guys doing bad guy things. I *think* whats going on is that subc/addc is for moving between rooms horizontally whilst subr/addr is vertically. I guess the DATA arrays could be named moveleftfrom, moverightfrom, moveupfrom, movedownfrom. Quote Link to comment Share on other sites More sharing options...
Arcade Posted May 13, 2013 Author Share Posted May 13, 2013 Thanks a lot! I will have to look more in to that in the future when I'm done working on my current project! Quote Link to comment Share on other sites More sharing options...
bogax Posted May 13, 2013 Share Posted May 13, 2013 (edited) I *think* whats going on is that subc/addc is for moving between rooms horizontally whilst subr/addr is vertically. I guess the DATA arrays could be named moveleftfrom, moverightfrom, moveupfrom, movedownfrom. I guess this merits some comment. Contrary to SeaGtGruff's comment, I think the third bit "direct_lookup" is closer to his. I debated whether to do it that way to begin with but I was trying to shoehorn a table into your code with minimum changes. eg you don't use direction for anything there, other than choosing the room, but you might want to. After thinking about it a bit I decided it was silly to advocate lookup tables and not demonstrate building the calculations into the table. so I added the direct_lookup bit. I debated whether to call the tables by the directions but opted for add and sub(tract) to emphasize that that was built into the table. I arranged the tables 3 x 3 because that's how you had the rooms arranged and I was trying to make the correspondence easy to see. But the tables make it easy to do arbitraty connections between rooms. Going right from a to b need not mean that going left from b will take you to a The rooms don't have to be in a two dimensional grid they could be three or four or what ever dimensions. Or nothing like a grid. Edited May 13, 2013 by bogax Quote Link to comment Share on other sites More sharing options...
bogax Posted May 14, 2013 Share Posted May 14, 2013 Here's the link: atariage.com/forums/topic/95820-adventure-type-game/#entry1162741 So far, the room code posted by you and bogax is way over my head. The loons code has directions 1-4 he does an on goto based on the room you're currently in which takes you to an on goto for that room that selects a new room based on the direction you're going. The one I called lookup_room is simlar except I took out the on gotos and put the target rooms in a table. There's a row for each room and the four columns are the four directions. Since the rows/rooms are every fourth direction the current room is multiplied by four to get the row and then the direction is added to get the column for the index into the table. Then on gosub to select the drawing code for that room. The one I called compute_room assumes the rooms are in a 3 x 3 grid. if you want to go right you add one to the column address of the room and if you want to go down you add one to the row address. Simliar for left or up except you subtract. row / column numbers have to wrap so that eg 0 is after 2, that's built into the table. So you just look up the result of adding or subtracting in the appropriate table. Similar to forming the table address for lookup_room, since there's 3 columns of rooms the row number is multiplied by 3 and the column number is added to get the room number then on gosub is used to go to the room drawing code for that room. The direct_lookup code has a table for each direction and an entry in each table for each room. You just look up the new room for a particular dirction based on the room you're in now. Then on gosub to draw that room. SeaGtGruff's move_around_rooms is similar except he goes to a subroutine for each direction that does the table look up for that direction then uses the room to look up a room shape (and a room color) then uses a bunch of if statements instead of on goto (and why in the world.. ;P ) to select the correct room shape drawing code for the room. (so different rooms can have same shapes with different colors) Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 14, 2013 Share Posted May 14, 2013 SeaGtGruff's move_around_rooms is similar except he goes to a subroutine for each direction that does the table look up for that direction then uses the room to look up a room shape (and a room color) then uses a bunch of if statements instead of on goto (and why in the world.. ;P ) to select the correct room shape drawing code for the room. (so different rooms can have same shapes with different colors) Well, it was written about 6.5 years ago, so I don't really remember why in the world I did it that way. I'm not sure when on-goto was added to batari Basic, but I don't think the no_blank_lines option was available yet, otherwise I'm pretty sure I would have used it in that example. On Random Terrain's page it says "The original beta version [of batari Basic] was released in 2005. Version 1.0 was released in 2007." I thought the first versions of batari Basic were released before 2005, but if I remember correctly Fred considered the 0.99 release to be the first true "beta" release, so maybe that's what 2005 is referring to? Anyway, my example was just a quickie demo to suggest what *could* be done, not anything I spent a lot of time trying to optimize, and I hadn't meant it to be an example of how something *should* be done. I only mentioned it because using a separate array for each direction allows up to 256 rooms. To break the 256-room barrier you could use sdata statements, or split the game into multiple "lands" and have separate sets of data statements for each land, allowing up to 256 rooms in each land, etc. But yeah-- if I were doing it today, I'd do it differently than how I did it back in 2006. Quote Link to comment Share on other sites More sharing options...
bogax Posted May 14, 2013 Share Posted May 14, 2013 (edited) Just for the hell of it I rewrote SeaGtGruff's code with more tables. This saved about 200 bytes, but it's probably slower. It's certainly not as easy to understand. Most of the savings is just replacing the string of if statments with on goto. For the rest, it's probably not the new tables but rearranging the old ones so that seperate routines are not needed. Mostly I was interested in how one might replace long strings of arbitrary if statements with looping through tables. In this case it saves nothing and no doubt takes longer. (but this wasn't a long string of if statements) move_around_rooms_with_more_tables.bas Edited May 14, 2013 by bogax Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted May 15, 2013 Share Posted May 15, 2013 On Random Terrain's page it says "The original beta version [of batari Basic] was released in 2005. Version 1.0 was released in 2007." I thought the first versions of batari Basic were released before 2005, but if I remember correctly Fred considered the 0.99 release to be the first true "beta" release, so maybe that's what 2005 is referring to? Is there a batari Basic thread earlier than the one below from July 7, 2005? atariage.com/forums/topic/72428-atari-2600-basic-compiler-is-here/ I'm probably going to get a mix of praise and criticism for this. Anyway, I've written a BASIC compiler for the Atari 2600. Yes, you read that right. This is not a joke! The thread below where I was asking for someone to make a BASIC-like language that will allow the average person to make Atari 2600 games is from September 16, 2004: atariage.com/forums/topic/57543-someone-please-make-a-basic-language-update-batari-did-it/ As I said in another thread, someone should make a BASIC-like language that will allow the average person to make Atari 2600 games from scratch. Besides allowing people to save their work, it should have a built-in compiler that converts the BASIC into a BIN file that will be ready to play using an emulator. Imagine regular people making Atari 2600 games fairly easily with a BASIC language! Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted May 15, 2013 Share Posted May 15, 2013 Is there a batari Basic thread earlier than the one below from July 7, 2005? I couldn't remember if version 0.1 was released in 2005 or 2004, or maybe even before 2004-- and I was too tired at the time to go look it up! I do remember that the first four versions (0.1, 0.2, 0.3, and 0.35) were released pretty close to each other, then there was a "pause" before 0.99 was released. Anyway, I was thinking that "on-goto" might not have been added to batari Basic yet when I wrote that "move_around_rooms.bas" example. Quote Link to comment Share on other sites More sharing options...
