lisalover1 Posted May 10, 2013 Share Posted May 10, 2013 I have been trying to get my PAL Scart -> NTSC Component AV setup working for my Genesis/CD/32X combo for quite some time now, but have had mixed results, at best. On one TV, it simply will not accept the transcoded signal. On another TV, no sound comes out of the setup, and finally, on the third TV I have tried, the picture comes through clear as day, but with a very noticeable green tint. I have tried fiddling with all of the connections, and it has never gone away. It seems like it is significantly reduced if I take out the 32X, but I would like to be able to use my 32X. Any ideas on what I can do? Quote Link to comment Share on other sites More sharing options...
Game-Tech.US Posted May 10, 2013 Share Posted May 10, 2013 Most of the external converters i've played with had pots inside that needed adjusted to get it just right. Take it apart and you might see 4 or 5 pots to play with, some may do nothing, one or two may make it look much better. Quote Link to comment Share on other sites More sharing options...
lisalover1 Posted May 11, 2013 Author Share Posted May 11, 2013 Most of the external converters i've played with had pots inside that needed adjusted to get it just right. Take it apart and you might see 4 or 5 pots to play with, some may do nothing, one or two may make it look much better. Thanks for the tip; I opened it up, fiddled with some knobs, and now it's right as rain! Quote Link to comment Share on other sites More sharing options...
