metzger130 Posted May 12, 2013 Share Posted May 12, 2013 Just got back from a Goodwill store and they had a 5200 for sale. I wanted to take a look at it to see what all came with it. It was a 4 port system, with the power, switchbox, and 1 controller.. It also came with Moon Patrol, Pac-Man, Qix, Centipede and a game without a label (appears to be Frogger from the brief time I turned it on to check the system. It does work, although there was a llot of static when I turned it on, but the controller needs some work. I couldn't get a game to start so I'm going to open it up and see if the dot trick will work along wth cleaning it up. I already had a 2 port system with 2 controllers so I just hope it works, but I still have 2 that work so no big deal if I can't get it to work. I probably just need to bend in the outer side of the part that connects to the tv, vcr in my case, so that it makes a more solid connection to get rid of the static. Total for all of this? $40! I think I got a steal. Quote Link to comment Share on other sites More sharing options...
AtariBrian Posted May 12, 2013 Share Posted May 12, 2013 Probably not a steal if it doesnt work Quote Link to comment Share on other sites More sharing options...
metzger130 Posted May 12, 2013 Author Share Posted May 12, 2013 (edited) It does work. I'm guessing that in order to get a cleaner signal I just need to put in the, ground?, of the part that goes into the VCR. So that it's a tighter fit. Edited May 12, 2013 by metzger130 Quote Link to comment Share on other sites More sharing options...
CRTGAMER Posted May 13, 2013 Share Posted May 13, 2013 Maybe one of the soldered connections inside the 4 port RF Auto Switchbox is loose. This happened to my 4 port, the RCA connector with fat insulation hanging off it caused the breakage inside. An easy resolder job. Quote Link to comment Share on other sites More sharing options...
