JWinslow23 Posted June 12, 2013 Share Posted June 12, 2013 set kernel_options playercolors player1colors dim zombiewalk=a dim zombiewalk2=b dim zombiewalkdelay=c dim zombiewalk2delay=d dim zombiespeed=e dim ballwasshot=f CTRLPF=$21 playfield: ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ ................................ XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end player0: %1101100 %0100100 %0100100 %0100100 %0100100 %0010100 %0001000 %0001011 %1111111 %1111111 %0101010 %0011100 %0001000 %0011100 %0100010 %1000001 %1000001 %1000001 %0100010 %0011100 end player1color: $F0 $F0 $F0 $F0 $F0 $F0 $F4 $F4 $F4 $F4 $F4 $F4 $F4 $F4 $C4 $C4 $C4 $C4 $C4 $C4 end player1: %00011001 %00010010 %00010010 %00010010 %00011110 %00010000 %00011110 %10011100 %10011000 %10111101 %10111101 %10111001 %01111110 %00011100 %00011110 %00110001 %00111111 %00110101 %00111111 %00011110 end COLUBK=6 COLUPF=244 player0x=138 player0y=79 player1x=17 player1y=79 zombiespeed=20 ballheight=1 ballx=139 bally=71 ballwasshot=0 loop drawscreen player1: %00011001 %00010010 %00010010 %00010010 %00011110 %00010000 %00011110 %10011100 %10011000 %10111101 %10111101 %10111001 %01111110 %00011100 %00011110 %00110001 %00111111 %00110101 %00111111 %00011110 end if zombiewalk=1 then player1: %01100110 %01000100 %00100100 %00100100 %00011000 %00010000 %00011110 %10011100 %10111000 %10111010 %10111010 %10111010 %01111110 %00011100 %00011110 %00110001 %00111111 %00110101 %00111111 %00011110 end if switchreset then reboot if joy0left then player0x=player0x-1 if joy0right then player0x=player0x+1 if !joy0fire && !ballwasshot then ballx=player0x+1 if joy0fire then ballwasshot=1 if ballwasshot then ballx=ballx-2 if player0x>138 then player0x=138 if player0x<16 then player0x=16 if player1x>138 then player1x=138 if collision(ball,player1) then player1x=16:ballx=player0x+1:ballwasshot=0:score=score+1 zombiewalkdelay=zombiewalkdelay+1 if zombiewalkdelay=zombiespeed then zombiewalk=zombiewalk+1:zombiewalkdelay=0:player1x=player1x+1 if zombiewalk=2 then zombiewalk=0 goto loop The code was compiling and executing fine a while ago, but now, wherever I place my cursor, there is a syntax error there. Any tips? Quote Link to comment Share on other sites More sharing options...
RevEng Posted June 12, 2013 Share Posted June 12, 2013 Two things stand out. First, none of your posted code is indented. Second, you've picked two kernel options and there isn't an entry on the kernel options chart for only those two options. Pick a line from the chart, and add all the options on that line. Fix up the indenting and comment out your kernel options line (for now) and your code should compile. Quote Link to comment Share on other sites More sharing options...
JWinslow23 Posted June 12, 2013 Author Share Posted June 12, 2013 1. Funny. When I put the code in, it was indented. Should've put the .bas up for download. 2. The bB help that came with VisualbB said it could be done. I'll come up with a better code in a few days. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 12, 2013 Share Posted June 12, 2013 2. The bB help that came with VisualbB said it could be done. What help is that? Where can I find it? Quote Link to comment Share on other sites More sharing options...
