Cybearg Posted June 17, 2013 Share Posted June 17, 2013 I'm working on a game that switches between two scores that are kept in memory, so I have to handle the splitting and incrementing of these "virtual" scores by hand. The problem is that one of two things happens: 1. If I set decimal mode, the numbers don't increment from the tens place to the hundreds place or from the thousands place to the ten-thousands place. 2. If I don't set decimal mode, the score gets corrupted I made a simple example (attached, and below) so everyone who is willing can experiment with the set/clear decimal modes if it would help to figure out how it needs to be done in order to work. rem batari Basic Program rem created 6/17/2013 5:15:11 PM by Visual bB Version 1.0.0.566 dim p0sc1 = l dim p0sc2 = m dim p0sc3 = n dim p1sc1 = o dim p1sc2 = p dim p1sc3 = q rem set up score bytes for reading/writing dim sc1=score dim sc2=score+1 dim sc3=score+2 def scoreshow = a{0} scorecolor = $0E main rem handles moving values to the hundreds and ten-thousands places if p0sc3 > $99 then p0sc2 = p0sc2 + $01: p0sc3 = $00 if p0sc2 > $99 then p0sc1 = p0sc1 + $01: p0sc2 = $00 if p1sc3 > $99 then p1sc2 = p1sc2 + $01: p1sc3 = $00 if p1sc2 > $99 then p1sc1 = p1sc1 + $01: p1sc2 = $00 rem handles adding to the score per frame rem NOTE: if statement is unnecessary in this context, but kept because it is used in another context, just in case it matters somehow if !player0y then p0sc3 = p0sc3 + $10 if !player1y then p1sc3 = p1sc3 + $10 rem copies stored value to the score rem NOTE: the scoreshow option is unnecessary in this context, but kept because it is is used in another context, just in case it matters somehow if !scoreshow then sc1 = p0sc1: sc2 = p0sc2: sc3 = p0sc3 else sc1 = p1sc1: sc2 = p1sc2: sc3 = p1sc3 drawscreen goto main Hopefully someone figures out what I couldn't. scoretest.bas scoretest.bas.bin scoretest.bas.asm Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted June 17, 2013 Share Posted June 17, 2013 If you are using an adapted version of this, you should have no problems: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#savehighscore Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted June 18, 2013 Share Posted June 18, 2013 I'm working on a game that switches between two scores that are kept in memory, so I have to handle the splitting and incrementing of these "virtual" scores by hand. The problem is that one of two things happens: I think the corruption is happening because you aren't checking the digits individually. Plus, you aren't adjusting the digits for overflow until after you've already moved them to the score. And finally, this would all be easier if you used assembly. Based on your ifs I take it that p?sc3 is the lo byte, p?sc1 is the hi byte, and p?sc2 is the middle byte. So I'd suggest something like this: if !player0y then gosub increment_p0score if !player1y then gosub increment_p1score rem etc. goto main increment_p0score asm SED LDA p0sc3 CLC ADC #$10 ; or whatever you need to add STA p0sc3 LDA p0sc2 ADC #0 STA p0sc2 LDA p0sc1 ADC #0 STA p0sc1 CLD RTS end increment_p1score asm SED LDA p1sc3 CLC ADC #$10 ; or whatever you need to add STA p1sc3 LDA p1sc2 ADC #0 STA p1sc2 LDA p1sc1 ADC #0 STA p1sc1 CLD RTS end scoretest.bas scoretest.bas.bin Quote Link to comment Share on other sites More sharing options...
Cybearg Posted June 18, 2013 Author Share Posted June 18, 2013 If you are using an adapted version of this, you should have no problems: http://www.randomter...l#savehighscore What I'm doing isn't really like that at all. The problem comes from the adding and shifting values between variables and the score. Some kind of corruption happens with the BCD-compliant values, either in the way the score is displayed or in the way the numbers are handled. Comparing values and saving them works just fine. Quote Link to comment Share on other sites More sharing options...
Cybearg Posted June 18, 2013 Author Share Posted June 18, 2013 I think the corruption is happening because you aren't checking the digits individually. Plus, you aren't adjusting the digits for overflow until after you've already moved them to the score. And finally, this would all be easier if you used assembly. Based on your ifs I take it that p?sc3 is the lo byte, p?sc1 is the hi byte, and p?sc2 is the middle byte. So I'd suggest something like this: if !player0y then gosub increment_p0score if !player1y then gosub increment_p1score rem etc. goto main increment_p0score asm SED LDA p0sc3 CLC ADC #$10 ; or whatever you need to add STA p0sc3 LDA p0sc2 ADC #0 STA p0sc2 LDA p0sc1 ADC #0 STA p0sc1 CLD RTS end increment_p1score asm SED LDA p1sc3 CLC ADC #$10 ; or whatever you need to add STA p1sc3 LDA p1sc2 ADC #0 STA p1sc2 LDA p1sc1 ADC #0 STA p1sc1 CLD RTS end I'll give that a shot! It certainly seems to work in the context of this demo, anyway. So by the look of it, you set decimal mode, load the value, add to it, then use the carry bit to increment further numbers, is that it? Quote Link to comment Share on other sites More sharing options...
SeaGtGruff Posted June 18, 2013 Share Posted June 18, 2013 (edited) So by the look of it, you set decimal mode, load the value, add to it, then use the carry bit to increment further numbers, is that it? Yes, if you do it in assembly then adding to the lo byte with decimal mode set will take care of any overflow from the lo nibble to the hi nibble for you-- and if the hi nibble overflows (rolls over) then the carry will be set, so you just add 0 to the next byte without clearing the carry first. And if the middle byte overflows then the carry will be set again, so adding 0 to the hi byte will automatically bump it up as well. Basically, the decimal mode and the carry bit take care of everything for you. Edit: PS, if you want to make the two subroutines more generic, you can put the value you want to add to score in a variable, then when you do the first ADC you would use ADC VARIABLE (whatever the variable is), rather than using immediate mode. Edited June 18, 2013 by SeaGtGruff Quote Link to comment Share on other sites More sharing options...
Cybearg Posted June 18, 2013 Author Share Posted June 18, 2013 Works perfectly. Thanks much, SeaGt! Quote Link to comment Share on other sites More sharing options...
