Serious Posted June 23, 2013 Share Posted June 23, 2013 I just acquired my first 5200 track ball, and I have a few questions. When using it, it bites my fingers if I get them near the edge. There is a small gap between the cover and the lower half of the ball. Is this normal? You can see the gap towards the bottom of this photo. Also, when rolling the ball, it is quite noisy (as if rolling the ball is generating some kind of friction). Is this normal? The unit itself is unusual. I assumed it was a modded unit when I bought it (the seller didn't know), but after having a closer look at it, I am wondering if it may be something else? S/N is "001045 EP 183". Quote Link to comment Share on other sites More sharing options...
jetset Posted June 23, 2013 Share Posted June 23, 2013 Definitely some kind of mod with those big yellow buttons. 1 Quote Link to comment Share on other sites More sharing options...
RangerG Posted June 23, 2013 Share Posted June 23, 2013 Yup, that's a pretty common mod (and a good one). I have a similar one, but just one arcade button. The trackball is pretty easy to disassemble, I'd check it out. By the way, it is a qball in there, so you can replace it if needed: http://atariage.com/forums/topic/198408-is-the-5200-trackball-just-a-cue-ball/ 1 Quote Link to comment Share on other sites More sharing options...
bohoki Posted June 23, 2013 Share Posted June 23, 2013 someone modded it with some arcade buttons take out the 6 screws on the bottom and oil and clean the idler bearing 1 Quote Link to comment Share on other sites More sharing options...
Serious Posted June 23, 2013 Author Share Posted June 23, 2013 Definitely some kind of mod with those big yellow buttons. I don't think those buttons were yellow, originally. The plastic on them is showing some age. someone modded it with some arcade buttons take out the 6 screws on the bottom and oil and clean the idler bearing Thanks for the tip on the bearing. Any suggestions on what kind of oil to use? The trackball is pretty easy to disassemble, I'd check it out. By the way, it is a qball in there, so you can replace it if needed: Thanks for letting me know about the cue ball. I think I will look for a more attractive replacement. I will probably disassemble it soon to clean it, anyway. Hopefully, I'll find a way to eliminate that gap at the bottom when I take it apart. Or I guess I'll have to learn to use it in a way that it doesn't keep pinching me when I use it. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 23, 2013 Share Posted June 23, 2013 The gap could be caused by worn rollers. If you want a replacement trakball I have several spares to sell and colors to choose from. I have white, black, gray, clear, orange/black swirl and probably a couple others I'm forgetting. If you want one they are $10 each plus shipping except the white ones are $7 each plus shipping. Mitch Quote Link to comment Share on other sites More sharing options...
jetset Posted June 23, 2013 Share Posted June 23, 2013 I don't think those buttons were yellow, originally. The plastic on them is showing some age. Yeah I should have said formerly white. They have that SNES nicotine-yellow coating going on there don't they? Quote Link to comment Share on other sites More sharing options...
Serious Posted June 23, 2013 Author Share Posted June 23, 2013 If you want a replacement trakball I have several spares to sell and colors to choose from. I have white, black, gray, clear, orange/black swirl and probably a couple others I'm forgetting. If you want one they are $10 each plus shipping except the white ones are $7 each plus shipping. I am interested.. Can you post a photo, or point me to one? Thanks Quote Link to comment Share on other sites More sharing options...
Serious Posted June 23, 2013 Author Share Posted June 23, 2013 Yeah I should have said formerly white. They have that SNES nicotine-yellow coating going on there don't they? Yep. I might look to replace them in the future. Quote Link to comment Share on other sites More sharing options...
7800 Posted June 23, 2013 Share Posted June 23, 2013 Perhaps the two halves of the unit shell aren't screwed down all the way, which might explain the gap that is pinching you when you use it.First thing I would do is take it apart and clean the rollers with fine steel wool, oil the bearings if need be by soaking them in some kind of multi purpose oil, Give the ball a good cleaning with soap and water. Then put it back together nice and tight. While it's apart, you may as well clean the button contacts with a pencil eraser. The start button is the most common to get real dirty. 1 Quote Link to comment Share on other sites More sharing options...
CRTGAMER Posted June 23, 2013 Share Posted June 23, 2013 (edited) Also, when rolling the ball, it is quite noisy (as if rolling the ball is generating some kind of friction). Is this normal? Nice mod with the Arcade style buttons! The noise is the ball going "against the grain" of the rollers underneath. The brass rollers get gunk buildup and the third roller is steel and likely has some corrosion. This causes the biggest drag with that scraping sound. Have care when you take it apart for cleaning, I wrote a guide on this. 5200 Trakball Cleaning - http://www.racketboy...=726298#p726298 Edited June 23, 2013 by CRTGAMER 1 Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 24, 2013 Share Posted June 24, 2013 Here's a pic. I am out of the green and purple trakballs though. Mitch Quote Link to comment Share on other sites More sharing options...
Serious Posted June 25, 2013 Author Share Posted June 25, 2013 Here's a pic. I am out of the green and purple trakballs though. Cool. I will PM you to work out the purchase. Quote Link to comment Share on other sites More sharing options...
Serious Posted June 25, 2013 Author Share Posted June 25, 2013 Have care when you take it apart for cleaning, I wrote a guide on this. 5200 Trakball Cleaning - http://www.racketboy...=726298#p726298 Great guide. I especially appreciate the tip on getting rid of the stray voltage. That would have been a nasty surprise. Quote Link to comment Share on other sites More sharing options...
