Mister-VCS Posted June 24, 2013 Share Posted June 24, 2013 Same problem with both games: graphic glitches and flickering at the beginning of a new game -and then both game crashes! What is going on here? Both cartridges look clean and my PAL 7800 works fine with Asteroids and Galaga.... Both games are from the UK (PAL). Xevious (locked up) Quote Link to comment Share on other sites More sharing options...
+Mitch Posted June 24, 2013 Share Posted June 24, 2013 Do they have the "P" sticker on the back? They could be NTSC carts that someone sold you. Mitch Quote Link to comment Share on other sites More sharing options...
Mister-VCS Posted June 25, 2013 Author Share Posted June 25, 2013 Do they have the "P" sticker on the back? Mitch Yes- very sad, because especially Xevious should be a fun game... Quote Link to comment Share on other sites More sharing options...
Blue Azure Posted June 26, 2013 Share Posted June 26, 2013 Check the edge connector with the fingers on it (not necessary to open the cart). Use a cotton swab with alcohol and sweep across the fingers and leave cart to dry for a while. Re-insert and, et voila, 95% sure this will fix the problem. Quote Link to comment Share on other sites More sharing options...
Mister-VCS Posted June 26, 2013 Author Share Posted June 26, 2013 Check the edge connector with the fingers on it (not necessary to open the cart). Use a cotton swab with alcohol and sweep across the fingers and leave cart to dry for a while. Re-insert and, et voila, 95% sure this will fix the problem. Thanks- but my carts are in the 5% zone... Quote Link to comment Share on other sites More sharing options...
Blue Azure Posted June 26, 2013 Share Posted June 26, 2013 That's what I kinda thought. Strange looking graphics I've never seen before. But it is these specific carts as the others are working, so it sounds like your 7800 machine is working right. Are these EPROM-based carts (do the cart labels look "normal" or homebrew?)? Maybe try opening one (there's a screw under the label if there is a label), and then reseat the chip, if possible. May need a soldering iron for this one. Quote Link to comment Share on other sites More sharing options...
Mister-VCS Posted July 5, 2013 Author Share Posted July 5, 2013 Ok - tried another Xevious-cartridge- same effect. Could it be a RAM-defect in 7800 mode? Could I switch RAM from a NTSC 7800 into my PAL 7800? How to identify the bad RAM? What to do?? Quote Link to comment Share on other sites More sharing options...
