Drakon Posted June 28, 2013 Share Posted June 28, 2013 Same hardware as version 2, I just rebuilt the case. This thing will hold me over until someone makes a proper gameboy / gameboy color cart that reads games from a sd card. My devcart supports games all the way up to 64 mbit. The main socket you can burn, drop and play eproms up to 8mbit without any rewiring. The toggle switch on the top is to switch between regular eprom and eprom compatible flashchips. The 3 pin header on the top is the extra address lines for 16, 32 and 64 mbit adapters. This cart uses the mbc5 chip so it can play the entire gb / gbc library. This cart also has the largest possible size save ram chip running on a socketed battery. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted June 28, 2013 Share Posted June 28, 2013 How easy (for you) was this project? Do you think the average joe can put together their own gameboy homebrew with similar techniques? Quote Link to comment Share on other sites More sharing options...
Drakon Posted June 28, 2013 Author Share Posted June 28, 2013 (edited) How easy (for you) was this project? Do you think the average joe can put together their own gameboy homebrew with similar techniques? For me this wasn't too bad but for the average guy I'd recommend hiring someone who knows their stuff. You're working with a lot of surface mount building this. Casework is also very important if you cut the wrong part of the case it won't close and you'll need to get another. The back of the eprom socket box must be flush with the case back otherwise it would get in the way of things on your systems. Edited June 28, 2013 by Drakon 1 Quote Link to comment Share on other sites More sharing options...
