chickenxhat Posted August 4, 2013 Share Posted August 4, 2013 (edited) so i've been working on this one for a couple days, and have poured over both the code and forums and just can't figure out why it works sometimes but not all the time. maybe someone can check it out. i've got routines that check if collision && if coordinates belong to each virtual sprite, and i'd like 4 out of 5 of them to be player-killing collisions, and the 5th to be point-adding collisions. i dont have the routine that adds points yet, just moving the 5th sprite to a random location on collision. i also have a routine that causes a shield to appear on joy0fire that causes the score to stop rolling up and will block the falling rocks. still working on that, but its coming together. what actually occurs is that sometimes the 4 out of 5 sprites (falling rocks) don't actually return as a collision, and sometimes collisions with the 5th (a collectable rock) hurt the player. it seems that my routines are faulty, but the math makes sense to me. it should work! i don't understand why it doesn't! before i seek out another way to handle multiple sprites in my game i'd like to determine if there's a better way to do this. if i can't get it to work, i can't get this game to work either. i think i did a decent job of adding comments on this .bas so it should be obvious what does what. any help or guidance or suggestions or revisions would be helpful. edit: also, sometimes the collectible rock disappears and the only way to make it come back (even though it should have never disappeared) is to walk the length of playfield and it will show back up. weird. unintentional. Moon.bas Edited August 4, 2013 by chickenxhat Quote Link to comment Share on other sites More sharing options...
chickenxhat Posted August 5, 2013 Author Share Posted August 5, 2013 (edited) well, seeing as no one is weighing in, i'm going to double-post with my findings. here's the excerpt of code that handles collision detection with the player character and the 4 falling rocks in my game. i could use variables and clean it up and maybe some a couple bytes, but as i'm still learning vbB it helps me to actually see the objects written out. rem player collisions if collision(player0, player1) then pfscore2 = pfscore2/4 : goto __Start_Select if collision(player0, player1) && player0y = player2y && player0x = player2x then pfscore2 = pfscore2/4 : goto __Start_Select if collision(player0, player1) && player0y = player3y && player0x = player3x then pfscore2 = pfscore2/4 : goto __Start_Select if collision(player0, player1) && player0y = player4y && player0x = player4x then pfscore2 = pfscore2/4 : goto __Start_Select this code works sucks! originally player0,player1 collisions included an x/y check as well. apparently the virtual sprites are also player1, because the real player1's x and y weren't returning on those collisions, never registered as collisions. so.. hope this helps someone in the future. edit: well.. no. now this code doesn't differentiate between players 1-4 and player5. all sprite collisions are lethal. bah! Edited August 5, 2013 by chickenxhat Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 5, 2013 Share Posted August 5, 2013 There are two or three people who have used the multisprite kernel enough to understand it, so hopefully one of them will post later today. 1 Quote Link to comment Share on other sites More sharing options...
bogax Posted August 5, 2013 Share Posted August 5, 2013 players 1-5 are player 1 the positions for players 1-5 are different from player0 that is, put one of the virtual sprites at some x, y and player0 at the same x, y and they wont be in the same place if player0 is eight wide and player1 is eight wide that gives you a range of 15 possible x positions which would cause a collision 1 15 00000000 00000000 11111111 Quote Link to comment Share on other sites More sharing options...
chickenxhat Posted August 5, 2013 Author Share Posted August 5, 2013 i will absorb that information, and do thank you for it, but i feel as though i have not garnered a solution from your post. in the mean time, i'm exploring using the ball object instead of a separate virtual sprite, as differentiating between them is proving difficult or impossible for me. Quote Link to comment Share on other sites More sharing options...
bogax Posted August 5, 2013 Share Posted August 5, 2013 iirc the virtual sprites are offset by 8 from player0 in the x direction and by -2 in the y direction so 0, 2 for player0 is 8, 0 for the virtual sprites (I may have the sign wrong ie I may have the players swapped) so you'd do something like x = player1x - 8 - player0x : y = player1y + 2 - player0y if x<15 && y<15 then collision for both player0 and player1 being 8x8 sprites Quote Link to comment Share on other sites More sharing options...
chickenxhat Posted August 5, 2013 Author Share Posted August 5, 2013 thanks bogax. i'll explore that as well. new question: what all standard collision arguments work in multisprite? i've got (player0,player1) working and (missile0,player1) working, but no other combinations. i know that (player?,player2-5) won't work, but why not combinations of missiles? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted August 5, 2013 Share Posted August 5, 2013 players2-5 are not real in a hardware sense. They are just player1 copied to another vertical location on-screen. Unfortunately, the built-in collision function does no checking beyond the usual. You must use software collision checking instead. Sucks. Quote Link to comment Share on other sites More sharing options...
Fothlyrdrag Posted August 7, 2013 Share Posted August 7, 2013 here is my primitive multi collision detection that waists variables but it was the only way i could make it a for sure thing b=player1x+1 g=player1x-3 i=player1y+1 l=player1y-7 n=player2x+1 o=player2x-3 q=player2y+1 r=player2y-7 u=player3x+1 y=player3x-3 w=player3y+1 h=player3y-7 if missile0x>g && missile0x<b && missile0y>l && missile0y<i then z=1 if missile0x>o && missile0x<n && missile0y>r && missile0y<q then z=2 if missile0x>y && missile0x<u && missile0y>h && missile0y<w then z=3 if z=1 then player1x=rand&150 : player1y=rand&90 : score=score+10 : p=p+1 : AUDV0=8 : AUDC0=8 : AUDF0=9 if z=2 then player2x=rand&90 : player2y=95 : score=score+10 : p=p+1 : AUDV0=8 : AUDC0=8 : AUDF0=9 if z=3 then player3x=rand&90 : player3y=0 : score=score+10 : p=p+1 : AUDV0=8 : AUDC0=8 : AUDF0=9 z=0 1 Quote Link to comment Share on other sites More sharing options...
Cybearg Posted August 7, 2013 Share Posted August 7, 2013 Use temp card instead to save memory. You have 7 of them. Should be enough. Quote Link to comment Share on other sites More sharing options...
donnerkuh Posted October 28, 2014 Share Posted October 28, 2014 Thank you Fothlyrdrag. Your collision detection works fine and helped me to solve my multisprite problem. but i only need 4 variables! use gosub! ok, now you have to do 2 gosubs for every multisprite player, but i need variables Here is the listing. You will need it for player2, player3,4,5... too. If a collision happens, the ball/missile and player disapear. gosub detectpl1 gosub detectpl1detail gosub detectpl2 gosub detectpl2detail detectpl1 u=player1x+1 v=player1x-7 w=player1y+1 x=player1y-7 return detectpl1detail if missile0x>v && missile0x<u && missile0y>x && missile0y<w then f = 0 : g = 0 : missile0x = 0 : missile0y = 0 if ballx>v && ballx<u && bally>x && bally<w then f = 0 : g = 0 : ballx = 0 : bally = 0 detectpl2 u=player2x+1 v=player2x-7 w=player2y+1 x=player2y-7 return detectpl2detail if missile0x>v && missile0x<u && missile0y>x && missile0y<w then j = 0 : k = 0 : missile0x = 0 : missile0y = 0 if ballx>v && ballx<u && bally>x && bally<w then j = 0 : k = 0 : ballx = 0 : bally = 0 return Quote Link to comment Share on other sites More sharing options...
