pacgreg Posted August 16, 2013 Share Posted August 16, 2013 Whenever I try to compile, There is an error on the line containing the pfheights:? Sorry for making two posts about this, i think everyone saw the first one and thought I was asking them to make it for me, but my problem is that I cannot find a fix that works for me. set kernel_options pfheights set kernel_options pfcolors pfheights: 8 8 8 8 8 3 3 3 3 3 3 3 3 3 3 3 3 3 3 12 end pfcolors: $E4 $E4 $E4 $E4 $E4 $E4 $E4 $E4 $E4 $08 $06 $04 $02 $28 $28 $26 $26 $24 $24 $E4 end playfield: ................................. ................................. ................................. ................................. ................................. ................................. ................................. ................................. ................................. .......................XX........ .......................XXX....... ........................XXX...... .........................XXX..... ........................X.XXX.... ........................X..XX.... ........................X..XX.... .........................X.XX.... ..........................XXXX... ...........................XXXX.. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end COLUBK = $00 COLUPF = $E4 COLUP1=$0E mainloop drawscreen goto mainloop Quote Link to comment Share on other sites More sharing options...
pacgreg Posted August 16, 2013 Author Share Posted August 16, 2013 Oh wait I got it, unless there's a way to have more an 11 rows at once. Quote Link to comment Share on other sites More sharing options...
bogax Posted August 16, 2013 Share Posted August 16, 2013 I'm no expert I think if you want more than 11 lines you need to use the mutisprite kernel and then you can't use pfcolors and the playfield is mirrored I don't know what DPC does Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted August 17, 2013 Share Posted August 17, 2013 Go to the chart, find what you want, left click on it, then the code appears at the top. Copy the code and paste it into your program: randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernelopchart Everything is supposed to be on the same line like this: set kernel_options pfcolors pfheights Not like this: set kernel_options pfheights set kernel_options pfcolors To use more than 11 rows, you can use the mutisprite kernel, the DPC+ kernel, or Superchip RAM. Quote Link to comment Share on other sites More sharing options...
