jcleverly Posted August 20, 2013 Share Posted August 20, 2013 So in the process of replacing the 15 pin cable on my wico keypad I realized the 5200 joystick doesn't use +5 volts (pin 12) at all. Any reason why? For some reason the wico keypad works fine without 5 volts. Just curious why the 5200 joystick doesn't. Is pot common 5 volts? I assume the only reason it is on the wico keypad is that it's there in case you use a trakball? Quote Link to comment Share on other sites More sharing options...
Blue Azure Posted August 23, 2013 Share Posted August 23, 2013 There is only a switch matrix in the cx52 joystick; there's no active logic, so no power is required. Usually it's a cost savings to have fewer wires in cables. Hopefully this helps to answer your question. ///blueman/// Quote Link to comment Share on other sites More sharing options...
bohoki Posted August 24, 2013 Share Posted August 24, 2013 the 5200 joystick scheme is very simple technically there is 5 volts at pin 9 but it is used in the rc charging circuit of the x and y i know this because i use certain joysticks that have autofire and they are powered via that pin although dont try to charge your phone or use any power from it in my exploration the pin 12 5 volts is used in conjunction with the x and y telling the system it is hooked to a trackball Quote Link to comment Share on other sites More sharing options...
