Aking Posted August 22, 2013 Share Posted August 22, 2013 HI Just got and installed the great combo on my XEGS ! just one question: can i flash osb instead of diagnostics? was not able to maybe because its 10k and not 16 as expected... used ultimate rom generator, last version if it can be done , can anyone here post an Atr with up to date pbi,spartados and last v2 rom for "L" support on side loader but with osb instead of diagnostics? Quote Link to comment Share on other sites More sharing options...
candle Posted August 22, 2013 Share Posted August 22, 2013 you need to padd it to full 16k, just add 6kbytes of anything in front of OSB and you're good to go Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 23, 2013 Share Posted August 23, 2013 This can also be accomplished by using "The ROM Generator" http://www.fiftyonefiftysystems.com/Atari/TheRomGenerator/Dwnld.html 1. Load your 512k U1MB.ROM first, then load the 10k 800 OS in the Diagnostic Slot. 2. When prompted to OPEN the OS ROM, then: 2a. Click once on your 800.rom file. 2b. Select "Object File (*.obj)" in the "Files of type:" Selector/Drop-Down List. 3. Now Click the [Open] Button. 4. The Custom Fill Dialog will be shown. 5. Enter 6144 in the Code Starting Position textbox. 6. Click OK... The 10k 800 OS will now be copied to the proper position 1 Quote Link to comment Share on other sites More sharing options...
Aking Posted August 23, 2013 Author Share Posted August 23, 2013 (edited) This can also be accomplished by using "The ROM Generator" http://www.fiftyonef...ator/Dwnld.html 1. Load your 512k U1MB.ROM first, then load the 10k 800 OS in the Diagnostic Slot. 2. When prompted to OPEN the OS ROM, then: 2a. Click once on your 800.rom file. 2b. Select "Object File (*.obj)" in the "Files of type:" Selector/Drop-Down List. 3. Now Click the [Open] Button. 4. The Custom Fill Dialog will be shown. 5. Enter 6144 in the Code Starting Position textbox. 6. Click OK... The 10k 800 OS will now be copied to the proper position had to rename the rom to .obj to get the menu then the it showed... but after flashing ok ....got a black screen on osb slot... Edited August 23, 2013 by Aking Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted August 24, 2013 Share Posted August 24, 2013 had to rename the rom to .obj to get the menu then the it showed... but after flashing ok ....got a black screen on osb slot... Fixed and verified it on my 800xl See http://atariage.com/forums/topic/201854-the-rom-generator/?do=findComment&comment=2816575 Quote Link to comment Share on other sites More sharing options...
Aking Posted August 24, 2013 Author Share Posted August 24, 2013 Fixed and verified it on my 800xl See http://atariage.com/forums/topic/201854-the-rom-generator/?do=findComment&comment=2816575 NOW we're talking OSb working great Quote Link to comment Share on other sites More sharing options...
