crash Posted August 22, 2013 Share Posted August 22, 2013 Hi, I have a 7800 with an 8bitdomain S-Video modification installed. If connected directly to the big TV, the top right portion of the screen is dark or discolored. I used to get around this by running the video through the old receiver, which didn't have this problem. The old receiver had an S-Video pass through to the TV while the new receiver has only HDMI and Component video, so S-Video is re-scaled and converted to display if it passes through that way. The converter does not function properly with the S-Video output, and either displays static, blank screen, flashes, or shows very dark incorrect, blurry colors. I have tried every combination of scaler settings and none seem to work properly. I am wondering if anyone knows if there is something non-standard about the S-Video signal or if you have any other suggestions. I tried the 7800 on a different LCD TV which displays the image correctly, so I'm not sure that the 7800 or video board are the problem. Thanks Quote Link to comment Share on other sites More sharing options...
crash Posted August 23, 2013 Author Share Posted August 23, 2013 Edit - I plugged in an Atari 130XE via S-Video, directly to the TV, and get the same darkening at the top of the screen, so the 7800 is most likely not the problem. I was able to get a picture with the 130XE through the receiver using the converter/scaler to HDMI 1080p/24 movie mode. The 7800 with the same settings shows a very dark picture, sometimes with missing elements. From what I can tell, the TV is not compatible with the S-Video signal, and the receiver's converter/scaler is mostly incompatible. Perhaps I need to ask for recommendations on either an S-Video signal stablizer/cleaner, or an S-Video to HDMI converter scaler? Thanks Quote Link to comment Share on other sites More sharing options...
crash Posted August 31, 2013 Author Share Posted August 31, 2013 I got a Kramer Electronics 103YCB S-Video amplifier, which resolved the major problems. My 7800 must have a weak signal. This is on a 60 inch tv. Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted September 1, 2013 Share Posted September 1, 2013 I wonder if a simple amplifying transistor on the luma (and maybe also chroma) line would've helped in the same way... Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted September 3, 2013 Share Posted September 3, 2013 My 7800 must have a weak signal. This is on a 60 inch tv.Not really, modern TVs usually don't play nice with older game consoles and the 7800 isn't an exception. Quote Link to comment Share on other sites More sharing options...
