ataridave Posted August 29, 2013 Share Posted August 29, 2013 By "type", I mean whether or not it's USB 2.0 I use a 2004 Sony Viao, if that helps. And if I don't have USB 2.0, will a device that uses it work on this PC? Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted August 30, 2013 Share Posted August 30, 2013 I would guess they'd be 2.0 That would have been the standard in 2004 (came out in 2000 IIRC) Quote Link to comment Share on other sites More sharing options...
ataridave Posted August 30, 2013 Author Share Posted August 30, 2013 I would guess they'd be 2.0 That would have been the standard in 2004 (came out in 2000 IIRC) Thanks AtariLeaf! Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted August 30, 2013 Share Posted August 30, 2013 Glad to help (hopefully) Quote Link to comment Share on other sites More sharing options...
Rex Dart Posted August 30, 2013 Share Posted August 30, 2013 Aww I was going to tell him to taste them. 1 Quote Link to comment Share on other sites More sharing options...
Osgeld Posted August 30, 2013 Share Posted August 30, 2013 (edited) I would guess they'd be 2.0 That would have been the standard in 2004 (came out in 2000 IIRC) should have been, I have a HP laptop thats ~2005 vintage with USB1.0 ports, once its in your hands its pretty easy to tell, you plug something in, windows will fuss that "this device would work faster on a 2.0 port, click here to see available 2.0 ports" down by the clock, and the resulting list will be empty. course if you have the exact model number it should be trival to look up (its on the bottom of the computer) honestly though I was quite surprised, as I have had many machines down to pentium III's with usb 2.0 onboard. now usb 1,2 and 3 are all backwards compatible, and it may not make that much of a difference, slower transfers from flash drives and a HD webcam that would not work in 720 are the only two things that pop in mind. option B is they made USB 2.0 cardbus cards, and I have one which works really good. Edited August 30, 2013 by Osgeld Quote Link to comment Share on other sites More sharing options...
ataridave Posted August 31, 2013 Author Share Posted August 31, 2013 (edited) should have been, I have a HP laptop thats ~2005 vintage with USB1.0 ports, once its in your hands its pretty easy to tell, you plug something in, windows will fuss that "this device would work faster on a 2.0 port, click here to see available 2.0 ports" down by the clock, and the resulting list will be empty. course if you have the exact model number it should be trival to look up (its on the bottom of the computer) honestly though I was quite surprised, as I have had many machines down to pentium III's with usb 2.0 onboard. now usb 1,2 and 3 are all backwards compatible, and it may not make that much of a difference, slower transfers from flash drives and a HD webcam that would not work in 720 are the only two things that pop in mind. option B is they made USB 2.0 cardbus cards, and I have one which works really good. I didn't know about USB 2.0 cardbus cards; thanks for the info! I wouldn't be using this for anything like a webcam, so a slower speed wouldn't bother me. Edited August 31, 2013 by ataridave Quote Link to comment Share on other sites More sharing options...
Osgeld Posted August 31, 2013 Share Posted August 31, 2013 (edited) I cant find mine off hand, but its a HP model card, I gave a song and a dance for it when comp-usa shut down. Its pretty nice 2 usb 2.0 ports and it came with a 2 amp wall wart you can plug in if you need to drive a hard drive from it. Usually use it with my 150Mhz pentium MMX dos game laptop to transfer files (though 98) quick scan on ebay pulled up a no name chi-co 4 port for like less than 10 bucks shipped Edited August 31, 2013 by Osgeld Quote Link to comment Share on other sites More sharing options...
+wood_jl Posted August 31, 2013 Share Posted August 31, 2013 I had a Toshiba laptop that I bought in around 2003 that had USB 1.1. I bought a Cardbus USB 2.0 adaptor, and while it was am improvement, it was *definitely* slower than a laptop with built-in USB 2.0. I was still glad to have it, and it served me well. But large disc-copies were noticeably faster with the next machine I bought that had 2.0 built-in. Quote Link to comment Share on other sites More sharing options...
Keatah Posted August 31, 2013 Share Posted August 31, 2013 http://www.everythingusb.com/hi-speed-usb.html#5 Quote Link to comment Share on other sites More sharing options...
