bogax Posted September 19, 2013 Share Posted September 19, 2013 I've rearranged SeaGtGruff's DPC+code for pushing the playfield.(this is for iesposta's game)It counts through the playfield linespushing the four bytes of a line fromtables.Just pushing the lines should takearound 40 cycles per line.176 lines * 40 = 7040 cycles.I think it's more like twice that.But Stella reports nary a bobble inthe line count.What accounts for that? push dptr = dptr + dbase DF4PUSH = ddat0[dptr] DF5PUSH = ddat1[dptr] DF6PUSH = ddat2[dptr] DF7PUSH = ddat3[dptr] return thisbank skip DF4LOW = 184 : DF5LOW = 184 : DF6LOW = 184 : DF7LOW = 184 DF4HI = 6 : DF5HI = 7 : DF6HI = 8 : DF7HI = 9 dbase = $00 crow = 90 decompress_loop crow = crow - 1 if !sdat[crow] then crow = crow - 1 : dbase = sdat[crow] : goto decompress_loop dptr = sdat[crow] & $0F : gosub push dptr = sdat[crow] / 16 : gosub push if crow then decompress_loop Quote Link to comment Share on other sites More sharing options...
iesposta Posted September 20, 2013 Share Posted September 20, 2013 I think it is because that is mostly ARM functions where the Atari is given NOP, no operations, so Stella isn't seeing anything happening? In another game I need a routine to push 5 lines (rows). It doesn't have to be compressed data. Where I would just give a scanline number and it would push the 5 lines. Or better yet, if not cycle intensive, give an X and a Y playfield position and PUSH a 5 by 5 PF chunk. The problem there being crossing over PF1, PF2 in the data streams 4, 5, 6 or 7. On the other hand, these kinds of things may already be there in pfvline, pfhline, and pfpixel. There might not be any cycle savings doing it with push. The playfield as data with compression - that saves rom space and DPC+ "graphics bank" space to have more sprites and playfields! Quote Link to comment Share on other sites More sharing options...
+stephena Posted September 20, 2013 Share Posted September 20, 2013 I can't say for sure what is happening here, but there is one big deficiency in the ARM emulation in Stella: the cycles between the two systems aren't synchronized. For example, no matter how long the ARM would take to run code, Stella would essentially see it as taking zero 6502 time. Hence, anything that ran too long and would screw up the timing on a real console would not be properly emulated by Stella at all. I want to get this fixed, probably by swapping out the current ARM emulation code with something from a NintendoDS emulator (which has an ARM CPU). I haven't done much research on this, and in any event don't have the time to look into it before the end of this year. If anyone is willing to step up and help in this regard, it would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
