aftyde Posted September 28, 2013 Share Posted September 28, 2013 Hi All, I have a P-GRAM+ card that I've just revived and was wondering if anyone has been able to get RXB working with it and how? When I use the P-Gram+ software to save a cart, it saves up to 5 files GRAM 3 GRAM 4 GRAM 5 GRAM 6 GRAM 7 and up to two RAM banks... RAM Bank 1 RAM Bank 2 So, if I try to load Extended Basic, it loads.... (in this order) RAM Bank 2 RAM Bank 1 GRAM 6 GRAM 5 GRAM 4 GRAM 3 I've looked at the P-Gram+ docs here but seem to lack the TI expertise to figure out which RXB files to map to which PGRAM files. The PGRAM files are unhelpfully organized... for example, extended basic saves (meaning, I used PGRAM to save the cart to disk) as... EB EB1 EB2 EB3 EB4 EB5 All are 9K files. Frustrating... 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted September 28, 2013 Share Posted September 28, 2013 (edited) A alternate method is to compile RXB from scratch using the Source files I included in RXB 2012. My GPLHOW2 demos show how to use all the tools I use. And some of the Youtube videos I have posted explain how to run each one individually. http://www.youtube.com/watch?v=-V2s_nL9NyI I should have added this also: http://www.youtube.com/watch?v=MaO_GRoaDV4 Edited September 28, 2013 by RXB Quote Link to comment Share on other sites More sharing options...
Gazoo Posted September 29, 2013 Share Posted September 29, 2013 Hi All, I have a P-GRAM+ card that I've just revived and was wondering if anyone has been able to get RXB working with it and how? When I use the P-Gram+ software to save a cart, it saves up to 5 files GRAM 3 GRAM 4 GRAM 5 GRAM 6 GRAM 7 and up to two RAM banks... RAM Bank 1 RAM Bank 2 So, if I try to load Extended Basic, it loads.... (in this order) RAM Bank 2 RAM Bank 1 GRAM 6 GRAM 5 GRAM 4 GRAM 3 I've looked at the P-Gram+ docs here but seem to lack the TI expertise to figure out which RXB files to map to which PGRAM files. The PGRAM files are unhelpfully organized... for example, extended basic saves (meaning, I used PGRAM to save the cart to disk) as... EB EB1 EB2 EB3 EB4 EB5 All are 9K files. Frustrating... It's not real clear what exactly the problem is you're having. The files should load as-is. Do the files you have not have the proper headers? If that's the case, look at the Pgram manual pages 31 and 32. Add the proper headers if they're not there. Gazoo Quote Link to comment Share on other sites More sharing options...
aftyde Posted September 29, 2013 Author Share Posted September 29, 2013 Apologies - I don't know which RXB files to load, or how to load them. I'm hoping someone who has RXB working on a P-GRAM+ card can respond and tell me how they did it. I am familiar with that section of the manual but lack the skills to know how to modify the RXB binaries. It's been 32 years since I was down and dirty with the TI - and even then I was limited to Extended Basic and some compiling / basic assembly. Even if I were able to compile it - loading it in the context of the P-GRAM card is way beyond my abilities. (at the moment) Cheers, Arthur... It's not real clear what exactly the problem is you're having. The files should load as-is. Do the files you have not have the proper headers? If that's the case, look at the Pgram manual pages 31 and 32. Add the proper headers if they're not there. Gazoo Quote Link to comment Share on other sites More sharing options...
RXB Posted September 30, 2013 Share Posted September 30, 2013 (edited) As Gazoo said and the videos on Youtube I posted shows other ways to check the header and how to edit them. The file order that RXB loads are: Address = Filename --------------------------------- ROM Page 0 = RXB ROM page 1 = RXB1 GRAM bank 7 = RXB2 GRAM bank 6 = RXB3 GRAM bank 5 = RXB4 GRAM bank 4 = RXB5 GRAM bank 3 = RXB6 I am including a copy of RXB with the ROMs and GROMs that load in the order you see above. (works for all GRAM devices ever made as all use the GRAM Kracker format) Rich RXB ZIP.zip Edited September 30, 2013 by RXB Quote Link to comment Share on other sites More sharing options...
