Rabbit 2600 Posted October 5, 2013 Share Posted October 5, 2013 Experimenting with banks and I find them very confusing. I'm using the platformer (4k) as a base. (I'm sorry, I forgot who made it) In order to learn both platforming and banking coding. I'm having a bit of an issue as to where I should put this line of code so that the player can proceed to the next level: if player0x = 140 then q = q + 1 : player0x = 25 q is a counter. It starts at 0, and thusly the first screen is shown. When player0 reaches 140 on the x axis he is then placed at position 25 on the x axis and q is increased by 1 and then screen number 2 should show. But nothing happens. Any ideas? Source: def GRAVITY=0.05 def JUMPVELOCITY=0.9 set romsize 8kSC set smartbranching on rem set kernel_options pfcolors const pfres=22 dim yvel=a.b dim ypos=c.d dim flags=e def REFLECT=flags{3} def JUMPING=flags{4} dim count=flags rem count uses bits 5-7 of flags dim rjoy=flags rem rjoy uses bits 0-2 of flags rem if using superchip: rem variables f-z and var0-var47 are free rem superchip variables r000-r039 free player0x=20:player0y=20 missile0x = 50 missile0y = 70 player1x = 125 player1y = 31 if q = 0 then playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XXXX..XX..XXXXXXXXXXXXXXXXXXXXXX XX............................XX XX....XX......................XX XX.............................. XX....XX........................ XX.............................. XX..XXXXXXXXXX..XX..XXXXXXXXXXXX XX............................XX XX..............XX............XX XX............................XX XX..............XX............XX XX............................XX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end if q = 1 then playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX.............................. XX.............................. XX.............................. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end c=20 goto continue bank2 bank 2 rem this is located in bank 2 because pfread lives there continue drawscreen if collision(player0,missile0) then missile0x = rand : missile0y = rand if collision(missile0,playfield) then missile0x = rand : missile0y = rand if player0x = 140 then q = q + 1 : player0x = 25 if missile0x < 20 then missile0x = rand if missile0x > 135 then missile0x = rand if missile0y < 10 then missile0y = rand if missile0y > 80 then missile0y = rand count=count+32 if JUMPING then werejumping if !joy0fire then nobutton yvel=JUMPVELOCITY JUMPING=1 nobutton if !JUMPING then nojump werejumping yvel=yvel-GRAVITY ypos=ypos-yvel nojump temp1=a|b:if temp1=0 then checkfall if !a{7} then skipadd checkfall if player0x<10 || player0x>142 then keepfall rem height from XY rem 0=keep falling, 1=hit exactly, 2=hit too low, move up gosub heightread temp3=c+2 temp3=temp3&3 if temp2=0 then keepfall if temp3=1 then stopjump if temp3>1 then addandstop keepfall JUMPING=1 goto skipadd addandstop c=c-1 stopjump JUMPING=0:d=255:a=0:b=0 skipadd if c>$64 then c=0 player0y=c if count{5} then neg rjoy=(rjoy & %11111000) | (SWCHA/32) if rjoy{0} then noduck player0: %01100110 %01111110 %00011000 %01111110 %00011000 %00111100 %00111100 %00011000 0 0 end goto neg noduck if rjoy{1} then check7 REFLECT=0 temp1=blockread(player0x,c):if temp1=0 then player0x=player0x-1 if player0x<7 then player0x=player0x+1 rem goto donereadingjoy check7 if rjoy{2} then donereadingjoy REFLECT=1 temp1=player0x+7 temp1=blockread(temp1,c):if temp1=0 then player0x=player0x+1 if player0x>$91 then player0x=player0x-1 donereadingjoy if !rjoy{2} || !rjoy{1} then running player0: %01100110 %01100110 %00111100 %00011000 %00011000 %01111110 %00011000 %00111100 %00111100 %00011000 end goto neg running if count{6} then frame24 if count{7} then frame3 player0: %01100011 %01100110 %00111100 %00011000 %01111000 %01011011 %00011110 %00111000 %00111000 %00010000 end goto neg frame3 player0: %00011000 %01111000 %00111000 %00011000 %00111000 %00111100 %00011000 %00111000 %00111000 %00010000 end goto neg frame24 if !count{7} then frame2 player0: %11001100 %01101100 %00111000 %00011000 %01111000 %00111110 %00011100 %00111000 %00111000 %00010000 end goto neg frame2 player0: %00110000 %00111110 %00011100 %00011000 %00011110 %00111100 %00011000 %00111000 %00111000 %00010000 end neg f=f+1 if f = 10 then player1: %01101100 %00100100 %00000000 %00111100 %00000000 %00111100 %01010110 %01010110 %01111110 %00111100 end if f = 20 then player1: %11000110 %01000010 %00000000 %00111100 %00000000 %00111100 %01010110 %01010110 %01111110 %00111100 end if f=20 then f=0 goto continue function pfget if pfread(temp1,temp2) then temp1=1 else temp1=0 return thisbank function blockread temp1=temp1-17:temp1=temp1/4 temp2=temp2/4 rem pfpixel temp1 temp2 flip if temp1>31 then temp1=0:return thisbank temp1=pfget(temp1,temp2) return thisbank heightread temp5=c+1 temp5=temp5/4 temp3=player0x-16 temp4=temp3+1:temp4=temp4/4 temp3=temp3/4:if temp3>$3d then temp6=0:temp4=0:goto skipfirst temp6=pfget(temp3,temp5) if temp4>temp3 then temp3=pfget(temp4,temp5):temp6=temp6|temp3 temp4=temp4+1 skipfirst temp2=temp6 rem pfpixel temp4 temp5 flip if temp4<$20 then temp2=pfget(temp4,temp5):temp2=temp2|temp6 return thisbank vblank scorecolor=15 COLUPF=178 COLUP0=$34 COLUP1=$0E REFP0=flags return Quote Link to comment Share on other sites More sharing options...
bogax Posted October 5, 2013 Share Posted October 5, 2013 You have to go choose a new playfield when q changes. def GRAVITY=0.05 def JUMPVELOCITY=0.9 set romsize 8kSC set smartbranching on rem set kernel_options pfcolors const pfres=22 dim yvel=a.b dim ypos=c.d dim flags=e def REFLECT=flags{3} def JUMPING=flags{4} dim count=flags rem count uses bits 5-7 of flags dim rjoy=flags rem rjoy uses bits 0-2 of flags rem if using superchip: rem variables f-z and var0-var47 are free rem superchip variables r000-r039 free player0x=20:player0y=20 missile0x = 50 missile0y = 70 player1x = 125 player1y = 31 gosub choose_pf c=20 goto continue bank2 choose_pf if q = 0 then playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XXXX..XX..XXXXXXXXXXXXXXXXXXXXXX XX............................XX XX....XX......................XX XX.............................. XX....XX........................ XX.............................. XX..XXXXXXXXXX..XX..XXXXXXXXXXXX XX............................XX XX..............XX............XX XX............................XX XX..............XX............XX XX............................XX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end if q = 1 then playfield: XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XX.............................. XX.............................. XX.............................. XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX XX............................XX XX............................XX XX............................XX XX............................XX XX............................XX XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX end return bank 2 rem this is located in bank 2 because pfread lives there continue drawscreen if collision(player0,missile0) then missile0x = rand : missile0y = rand if collision(missile0,playfield) then missile0x = rand : missile0y = rand if player0x = 140 then q = q + 1 : gosub choose_pf bank1 : player0x = 25 if missile0x < 20 then missile0x = rand if missile0x > 135 then missile0x = rand if missile0y < 10 then missile0y = rand if missile0y > 80 then missile0y = rand count=count+32 if JUMPING then werejumping if !joy0fire then nobutton yvel=JUMPVELOCITY JUMPING=1 nobutton if !JUMPING then nojump werejumping yvel=yvel-GRAVITY ypos=ypos-yvel nojump temp1=a|b:if temp1=0 then checkfall if !a{7} then skipadd checkfall if player0x<10 || player0x>142 then keepfall rem height from XY rem 0=keep falling, 1=hit exactly, 2=hit too low, move up gosub heightread temp3=c+2 temp3=temp3&3 if temp2=0 then keepfall if temp3=1 then stopjump if temp3>1 then addandstop keepfall JUMPING=1 goto skipadd addandstop c=c-1 stopjump JUMPING=0:d=255:a=0:b=0 skipadd if c>$64 then c=0 player0y=c if count{5} then neg rjoy=(rjoy & %11111000) | (SWCHA/32) if rjoy{0} then noduck player0: %01100110 %01111110 %00011000 %01111110 %00011000 %00111100 %00111100 %00011000 0 0 end goto neg noduck if rjoy{1} then check7 REFLECT=0 temp1=blockread(player0x,c):if temp1=0 then player0x=player0x-1 if player0x<7 then player0x=player0x+1 rem goto donereadingjoy check7 if rjoy{2} then donereadingjoy REFLECT=1 temp1=player0x+7 temp1=blockread(temp1,c):if temp1=0 then player0x=player0x+1 if player0x>$91 then player0x=player0x-1 donereadingjoy if !rjoy{2} || !rjoy{1} then running player0: %01100110 %01100110 %00111100 %00011000 %00011000 %01111110 %00011000 %00111100 %00111100 %00011000 end goto neg running if count{6} then frame24 if count{7} then frame3 player0: %01100011 %01100110 %00111100 %00011000 %01111000 %01011011 %00011110 %00111000 %00111000 %00010000 end goto neg frame3 player0: %00011000 %01111000 %00111000 %00011000 %00111000 %00111100 %00011000 %00111000 %00111000 %00010000 end goto neg frame24 if !count{7} then frame2 player0: %11001100 %01101100 %00111000 %00011000 %01111000 %00111110 %00011100 %00111000 %00111000 %00010000 end goto neg frame2 player0: %00110000 %00111110 %00011100 %00011000 %00011110 %00111100 %00011000 %00111000 %00111000 %00010000 end neg f=f+1 if f = 10 then player1: %01101100 %00100100 %00000000 %00111100 %00000000 %00111100 %01010110 %01010110 %01111110 %00111100 end if f = 20 then player1: %11000110 %01000010 %00000000 %00111100 %00000000 %00111100 %01010110 %01010110 %01111110 %00111100 end if f=20 then f=0 goto continue function pfget if pfread(temp1,temp2) then temp1=1 else temp1=0 return thisbank function blockread temp1=temp1-17:temp1=temp1/4 temp2=temp2/4 rem pfpixel temp1 temp2 flip if temp1>31 then temp1=0:return thisbank temp1=pfget(temp1,temp2) return thisbank heightread temp5=c+1 temp5=temp5/4 temp3=player0x-16 temp4=temp3+1:temp4=temp4/4 temp3=temp3/4:if temp3>$3d then temp6=0:temp4=0:goto skipfirst temp6=pfget(temp3,temp5) if temp4>temp3 then temp3=pfget(temp4,temp5):temp6=temp6|temp3 temp4=temp4+1 skipfirst temp2=temp6 rem pfpixel temp4 temp5 flip if temp4<$20 then temp2=pfget(temp4,temp5):temp2=temp2|temp6 return thisbank vblank scorecolor=15 COLUPF=178 COLUP0=$34 COLUP1=$0E REFP0=flags return Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted October 5, 2013 Author Share Posted October 5, 2013 Ooooh, cheers! Quote Link to comment Share on other sites More sharing options...
AtariLeaf Posted October 6, 2013 Share Posted October 6, 2013 I know right? I walked into CIBC and all the talk about mortgages, lines of credit, and RSP's was enough to make my head spin. 1 Quote Link to comment Share on other sites More sharing options...
