+Gemintronic Posted October 12, 2013 Share Posted October 12, 2013 This is a sort-of continuation of an earlier concept: http://atariage.com/forums/topic/207649-cheap-space-harrier-effect-demo/ I'm trying to get a Space Harrier effect going. The multi-sprite kernel seems to give you effectively 40x32 playfields. I'm just dumb enough not to be able to hand-draw the playfield. Any idea on how to make a 3D scrolling Space Harrier background? Here is a pic of my latest effort. Doesn't have the 3D angle lbharrier2.bas lbharrier2.bin 2 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted October 14, 2013 Author Share Posted October 14, 2013 Well, my only idea on getting a true Space Harrier effect is to make random screen captures of the real Space Harrier background. I'm trying to manually convert those screen captures to bB playfield statements. It's not going very well. If anyone has a better idea please chime in Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted October 24, 2013 Author Share Posted October 24, 2013 Still haven't found a way to come up with my own 3D animation for the Space Harrier background. I did play with an earlier attempt and got a little better result. What do people think? shair3.basshair3.bin UPDATE: For some reason it doesn't smoothly scroll. The score doesn't bounce but the playfield seems to jerk up 'n down. I tried to hide that by scrolling twice as fast. If anyone has a clue how to deal with that I'm all ears 1 Quote Link to comment Share on other sites More sharing options...
Goochman Posted October 24, 2013 Share Posted October 24, 2013 Someone was working on Ballblazer for the 2600 in the homebrew forum awhile back. The chessboard effect that was done for that was pretty good and might translate into what you are trying to do. Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted October 24, 2013 Share Posted October 24, 2013 Still haven't found a way to come up with my own 3D animation for the Space Harrier background. I did play with an earlier attempt and got a little better result. What do people think? Interesting effect but its a bit too chunky looking vertically and the way the squares move "towards you" isn't very convincing in my opinion. Have you tried computing the chequerboard pattern's positions using real 3D arithmetic and using tables instead? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted October 24, 2013 Author Share Posted October 24, 2013 Interesting effect but its a bit too chunky looking vertically and the way the squares move "towards you" isn't very convincing in my opinion. Have you tried computing the chequerboard pattern's positions using real 3D arithmetic and using tables instead? Don't have the skills or inclination to use math. Ballblazer required an assembly guru and even he had trouble sorting things out per frame. If I knew how maybe I'd use math to "render" the playfield and use the result as a static animation. The vertical chunkiness is in part because I had to use double speed scrolling to mitigate the weird shaking in the pfscroll command. I thought that was a fixed issue in bB. Maybe it was just the score shaking that was fixed. P.S. Thanks for the honest feedback. I really do appreciate it! Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted October 24, 2013 Share Posted October 24, 2013 Don't have the skills or inclination to use math. Ballblazer required an assembly guru and even he had trouble sorting things out per frame. If you have 4 player controlled directions (with acceleration and velocity) to contend with as you move over the chequerboard pattern its going to be tricky. However, forward motion at a fixed speed is just going to be a pre-computed table. If I knew how maybe I'd use math to "render" the playfield and use the result as a static animation. Probably the best approach. P.S. Thanks for the honest feedback. I really do appreciate it! No worries. Its good to see people experimenting. 1 Quote Link to comment Share on other sites More sharing options...
