Rabbit 2600 Posted October 19, 2013 Share Posted October 19, 2013 I have almost gotten multisprite collision working the old fashioned way without DPC+ but I hit a small snag. The collision between missile0 and player1 and player2 works and they dissapear when the missile is at the same x position as them. But it dosn't work so well with player3 and player4. When missile0 collides with either player3 or player4 both of them dissapears. if collision(missile0, player1) && missile0x = player1x then player1y = 255 if collision(missile0, player1) && missile0x = player2x then player2y = 255 if collision(missile0, player1) && missile0x = player3x then player3y = 255 if collision(missile0, player1) && missile0x = player4x then player4y = 255 Entire Code: rem Generated 2013-10-19 17:39:33 by Visual bB Version 1.0.0.554 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** set kernel multisprite set smartbranching on dim _P1_L_R = player1x.a dim _P1_U_D = player1y.b dim _P0_L_R = player0x.c dim _P0_U_D = player0y.d dim _player0a = e dim _player0b = f player1x = 110 : player1y = 70 player2x = 130 : player2y = 20 player3x = 30 : player3y = 20 player4x = 30 : player4y = 70 player0x = 50 : player0y = 50 missile0x = 200 : missile0y = 200 BATTLEFIELD player0: %00011111 %11111111 %00111110 %11111111 %00011111 end player1: %00011111 %11111111 %00111110 %11111111 %00011111 end player2: %00011111 %11111111 %00111110 %11111111 %00011111 end player3: %00011111 %11111111 %00111110 %11111111 %00011111 end player4: %00011111 %11111111 %00111110 %11111111 %00011111 end _COLUP1 = $0E COLUP2 = $40 COLUP3 = $D4 COLUP4 = $64 COLUP0 = $1E COLUPF = $0E playfield: ................ ................ ................ ................ ................ XXXXXXXXXXXXXXXX X............... X............... X............... X............... XXXXXXXXXXXXXXXX end scorecolor = $0E drawscreen if joy0right then _P0_L_R = _P0_L_R + 0.30 if joy0left then _P0_L_R = _P0_L_R - 0.30 if joy0up then _P0_U_D = _P0_U_D + 0.30 if joy0down then _P0_U_D = _P0_U_D - 0.30 if joy0left && joy0fire then missile0x=player0x : missile0y = player0y : goto MISSILELEFT if collision(missile0, player1) && missile0x = player1x then player1y = 255 if collision(missile0, player1) && missile0x = player2x then player2y = 255 if collision(missile0, player1) && missile0x = player3x then player3y = 255 if collision(missile0, player1) && missile0x = player4x then player4y = 255 MISSILELEFT missile0x = missile0x - 1 goto BATTLEFIELD Quote Link to comment Share on other sites More sharing options...
Rabbit 2600 Posted October 19, 2013 Author Share Posted October 19, 2013 Okay, I managed to fix the issue with the missile collision. But, I'm having issues with movement with player2-4. Movement in player1 works fine. Any thoughts? if _P1_L_R < _P0_L_R then _P1_L_R = _P1_L_R + 0.10 if _P1_L_R > _P0_L_R then _P1_L_R = _P1_L_R - 0.10 if _P1_U_D < _P0_U_D then _P1_U_D = _P1_U_D + 0.10 if _P1_U_D > _P0_U_D then _P1_U_D = _P1_U_D - 0.10 if _P2_L_R < _P0_L_R then _P2_L_R = _P2_L_R + 0.10 if _P2_L_R > _P0_L_R then _P2_L_R = _P2_L_R - 0.10 if _P2_U_D < _P0_U_D then _P2_U_D = _P2_U_D + 0.10 if _P2_U_D > _P0_U_D then _P2_U_D = _P2_U_D - 0.10 Source: rem Generated 2013-10-19 17:39:33 by Visual bB Version 1.0.0.554 rem ********************************** rem *<filename> * rem *<description> * rem *<author> * rem *<contact info> * rem *<license> * rem ********************************** set kernel multisprite set smartbranching on dim _P1_L_R = player1x.a dim _P1_U_D = player1y.b dim _P0_L_R = player0x.c dim _P0_U_D = player0y.d dim _P2_L_R = player0x.i dim _P2_U_D = player0y.j dim _player0a = e dim _player0b = f player1x = 110 : player1y = 70 player2x = 130 : player2y = 20 player3x = 30 : player3y = 20 player4x = 30 : player4y = 70 player0x = 50 : player0y = 50 missile0x = 200 : missile0y = 200 AUDV0=0 AUDV1=0 BATTLEFIELD g=g+1 rem POSSIBLY INEFFICIENT CODE, SEPARATE COLOR INFO FOR EACH FRAME... if g = 10 then player0: %00000000 %00000000 %00000000 %11111111 %11111111 %00000000 %00000000 %00000000 end if g = 20 then player0: %00000000 %00000000 %11111111 %00000000 %00000000 %11111111 %00000000 %00000000 end if g = 30 then player0: %00000000 %11111111 %00000000 %00000000 %00000000 %00000000 %11111111 %00000000 end if g = 40 then player0: %11111111 %00000000 %00000000 %00000000 %00000000 %00000000 %00000000 %11111111 end if g = 50 then player0: %00100100 %00100100 %00011000 %00011000 %01111110 %00000000 %00011000 %00011000 end player1: %00001000 %00000000 %01011101 %01011101 %00011100 %01100011 %00011100 %00011100 end player2: %00001000 %00000000 %01011101 %01011101 %00011100 %01100011 %00011100 %00011100 end player3: %00001000 %00000000 %01011101 %01011101 %00011100 %01100011 %00011100 %00011100 end player4: %00001000 %00000000 %01011101 %01011101 %00011100 %01100011 %00011100 %00011100 end _COLUP1 = $0E COLUP2 = $40 COLUP3 = $D4 COLUP4 = $64 COLUP0 = $1E COLUPF = $0E playfield: ................ ................ ................ ................ ................ XXXXXXXXXXXXXXXX X............... X............... X............... X............... XXXXXXXXXXXXXXXX end scorecolor = $0E drawscreen if g > 50 && joy0right then _P0_L_R = _P0_L_R + 0.30 if g > 50 && joy0left then _P0_L_R = _P0_L_R - 0.30 if g > 50 && joy0up then _P0_U_D = _P0_U_D + 0.30 if g > 40 && joy0down then _P0_U_D = _P0_U_D - 0.30 if _P1_L_R < _P0_L_R then _P1_L_R = _P1_L_R + 0.10 if _P1_L_R > _P0_L_R then _P1_L_R = _P1_L_R - 0.10 if _P1_U_D < _P0_U_D then _P1_U_D = _P1_U_D + 0.10 if _P1_U_D > _P0_U_D then _P1_U_D = _P1_U_D - 0.10 if _P2_L_R < _P0_L_R then _P2_L_R = _P2_L_R + 0.10 if _P2_L_R > _P0_L_R then _P2_L_R = _P2_L_R - 0.10 if _P2_U_D < _P0_U_D then _P2_U_D = _P2_U_D + 0.10 if _P2_U_D > _P0_U_D then _P2_U_D = _P2_U_D - 0.10 if joy0left && joy0fire then missile0x=player0x : missile0y = player0y : goto MISSILELEFT if collision(missile0, player1) && missile0x = player1x then n = 11: player1y = 255 : score = score + 10 if collision(missile0, player1) && missile0x = player2x then n = 11: player2y = 255 : score = score + 10 if collision(missile0, player1) && missile0y = player3y then n = 11: player3y = 255 : score = score + 10 if collision(missile0, player1) && missile0y = player4y then n = 11: player4y = 255 : score = score + 10 if n > 0 then AUDV0 = 15 : AUDC0 = 8 : AUDF0 = 20 : n = n - 1: if n = 0 then AUDV0 = 0 if collision(missile0,playfield) then missile0x = 255 : missile0y = 255 MISSILELEFT missile0x = missile0x - 1 goto BATTLEFIELD Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted October 20, 2013 Share Posted October 20, 2013 Not an answer. I'm not snubbing you. You're reaching my limits of knowledge with fractional numbers and collision detection with the multi sprite kernel. I hope someone smarter comes along because pretty soon I'll have to deal with the same issues Quote Link to comment Share on other sites More sharing options...
bogax Posted October 20, 2013 Share Posted October 20, 2013 Okay, I managed to fix the issue with the missile collision. But, I'm having issues with movement with player2-4. Movement in player1 works fine. Any thoughts? What issues? Quote Link to comment Share on other sites More sharing options...
