+grips03 Posted October 22, 2013 Share Posted October 22, 2013 Has anyone hacked Frogger so you don't have to press button to move? Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 22, 2013 Share Posted October 22, 2013 Yes, but the problem is that whoever did the hack didn't make it so you have to tap repeatedly in a direction to move that way. The result is that holding a direction makes the Frog run off in that direction. Normally into a car truck or the water. Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 22, 2013 Share Posted October 22, 2013 Here you go. I'd love to see it fixed so it controls like it should. (IE. A8, CV, VCS...) Frogger (no button hack).zip 1 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 22, 2013 Author Share Posted October 22, 2013 Here you go. I'd love to see it fixed so it controls like it should. (IE. A8, CV, VCS...) this works great besides 1 issue. When you put the frog in the hole at the end, a new frog appears and immediate gets hit by the car Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 22, 2013 Share Posted October 22, 2013 this works great besides 1 issue. When you put the frog in the hole at the end, a new frog appears and immediate gets hit by the car That is because of what I said above. The new frog starts so fast you are still holding up after putting the previous frog in his home. Like I said, needs to be changed to move only a single space when a direction is placed. As it is now the frog just keeps going in that direction until it hits something or you release the direction. 1 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted October 22, 2013 Author Share Posted October 22, 2013 (edited) That is because of what I said above. The new frog starts so fast you are still holding up after putting the previous frog in his home. Like I said, needs to be changed to move only a single space when a direction is placed. As it is now the frog just keeps going in that direction until it hits something or you release the direction. ok i see what you mean, it auto jumps if joystick is held in that direction. This is ok as I can time it for all the other jumps. If the frog start position was moved back one spot, behind the time line, then the first jump that it does would be only to that line vs into the road. Hopefully someone can look at it and adjust. Is there a Atari 5200 emulator for PC or mac with single step. I might be able to find the right place in the code. Another fix might be to add rapid fire to the controller, the player would hold down this button. Then the original rom / cart can be used. Edited October 22, 2013 by grips03 Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted October 22, 2013 Share Posted October 22, 2013 (edited) ok i see what you mean, it auto jumps if joystick is held in that direction. This is ok as I can time it for all the other jumps. If the frog start position was moved back one spot, behind the time line, then the first jump that it does would be only to that line vs into the road. Hopefully someone can look at it and adjust. Is there a Atari 5200 emulator for PC or mac with single step. I might be able to find the right place in the code. Another fix might be to add rapid fire to the controller, the player would hold down this button. Then the original rom / cart can be used. I think rapid fire would still make the frog go just like the hack.... In the original 5200 version you can hold a direction and tapping the button would make him jump. So rapid would just make him keep going... Also in the original 5200 versions I think you can use the keypad to move the frog. Those buttons are too clumsy for fast gaming though. Edited October 22, 2013 by Official Ninja Quote Link to comment Share on other sites More sharing options...
bohoki Posted October 27, 2013 Share Posted October 27, 2013 the only other game that moves like frogger that i can think of is qbert Quote Link to comment Share on other sites More sharing options...
myklejay Posted November 22, 2013 Share Posted November 22, 2013 Any word on an updated "no Button" rom? Love this game but hate it on the 5200. The no button hack would be perfect if it didn't jump you into the street... Quote Link to comment Share on other sites More sharing options...
+grips03 Posted November 22, 2013 Author Share Posted November 22, 2013 (edited) I made a rapid fire controller and now the standard rom/cart works fine just hold down rapid fire and release right after the last jump Edited November 22, 2013 by grips03 Quote Link to comment Share on other sites More sharing options...
myklejay Posted November 27, 2013 Share Posted November 27, 2013 Wouldn't an xe/xl conversion do the trick? As a kid I played frogger on an 800 xl with no problems and no button pushing, played just like the arcade version. Quote Link to comment Share on other sites More sharing options...
jetset Posted November 27, 2013 Share Posted November 27, 2013 You can also use the keypad. The 4 and 6 are your left and right, the 2 and 8 are up and down. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted November 27, 2013 Author Share Posted November 27, 2013 You can also use the keypad. The 4 and 6 are your left and right, the 2 and 8 are up and down. do other games on the 5200 use keypad for primary movement? Quote Link to comment Share on other sites More sharing options...
Kjmann Posted June 14, 2017 Share Posted June 14, 2017 Has anyone ever been able tofix the no button hack so you dont jump in the street after completing a run? Quote Link to comment Share on other sites More sharing options...
Dantaipan Posted July 28, 2023 Share Posted July 28, 2023 Bump. Hey, it's been six years. Any chance of a proper Frogger no-button hack happening? Quote Link to comment Share on other sites More sharing options...
BIGHMW Posted August 2, 2023 Share Posted August 2, 2023 I also, have both the Q*bert and Frogger "no button" hack and I myself use digital sticks with most of my games on my 5200 (using Redemption 5200) and am fully aware of the drawback of this hack so I use a very light touch, whenever I play Frogger with this hack I just nudge the stick as opposed to hitting it full-on, that way I don't inadvertently hop twice and get myself killed but yes we could sure as hell use a fix of this. As for the Q*bert hack, if you use a digital controller you have to be spot-on, in other words it's kinda like the diagonal hack I had done for the A8 version, you have to have BOTH directions dialed in in order to be able to move, now I myself am used to it, I like this diagonal hack because that way I don't have to hold the joystick in an awkward manner (45 degrees off to the right) as the tendency is to hit the wrong direction either way. Quote Link to comment Share on other sites More sharing options...
