+Gemintronic Posted November 5, 2013 Share Posted November 5, 2013 In my 4 way scrolling topics I realised I needed some way to reverse a byte (i.e. turning %0100100 into %0010010) Although SeaGtGruffs pfhscroll.asm keeps the correct byte order directly manipulating the screen vars does not. This means any 4 way scrolling demonstration I've made so far can only use symmetrical level data. The only methods I can think of is a bunch of costly bit rearranging (i.e. this{0} = that{7}) or a very big lookup table. Does anybody have any bright ideas? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 5, 2013 Share Posted November 5, 2013 Isn't the code by bogax kind of reversing bytes? bogax_ror_rol_example_2013y_11m_05d_0147t.bin bogax_ror_rol_example_2013y_11m_05d_0147t.bas Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 5, 2013 Author Share Posted November 5, 2013 It might be. It almost seems like those ror and rol are reversing the bytes in assembly. I don't really understand enough just to pick out the bit of inline assembly needed to execute those commands.. and if they really reverse the byte in the first place (it could just be shifting the bits). At least it's a lead. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 5, 2013 Share Posted November 5, 2013 It might be. It almost seems like those ror and rol are reversing the bytes in assembly. Not almost, it is assembly. Here's an example: __ __Scroll_Right asm lda var3 rol ror var0 rol var1 ror var2 rol var3 lda var7 rol ror var4 rol var5 ror var6 rol var7 lda var11 rol ror var8 rol var9 ror var10 rol var11 lda var15 rol ror var12 rol var13 ror var14 rol var15 lda var19 rol ror var16 rol var17 ror var18 rol var19 lda var23 rol ror var20 rol var21 ror var22 rol var23 lda var27 rol ror var24 rol var25 ror var26 rol var27 lda var31 rol ror var28 rol var29 ror var30 rol var31 lda var35 rol ror var32 rol var33 ror var34 rol var35 lda var39 rol ror var36 rol var37 ror var38 rol var39 lda var43 rol ror var40 rol var41 ror var42 rol var43 lda var47 rol ror var44 rol var45 ror var46 rol var47 end The playfield variables that are always reversed are dealt with for you in his asm code, so you don't have to worry about it, at least going left and right. 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 5, 2013 Author Share Posted November 5, 2013 It looks like ror and rol are bit shifting and not reversing the byte. Rotate Left through Carry 2A nzc--- 2 ROL A RCL A ;RCL A 26 nn nzc--- 5 ROL nn RCL [nn] ;RCL [nn] 36 nn nzc--- 6 ROL nn,X RCL [nn+X] ;RCL [nn+X] 2E nn nn nzc--- 6 ROL nnnn RCL [nnnn] ;RCL [nnnn] 3E nn nn nzc--- 7 ROL nnnn,X RCL [nnnn+X] ;RCL [nnnn+X] Rotate Right through Carry 6A nzc--- 2 ROR A RCR A ;RCR A 66 nn nzc--- 5 ROR nn RCR [nn] ;RCR [nn] 76 nn nzc--- 6 ROR nn,X RCR [nn+X] ;RCR [nn+X] 6E nn nn nzc--- 6 ROR nnnn RCR [nnnn] ;RCR [nnnn] 7E nn nn nzc--- 7 ROR nnnn,X RCR [nnnn+X] ;RCR [nnnn+X] SeaGtGruffs pfhscroll.asm takes care of shifting the playfield just fine. it's just when I must lay down playfield data into var0-47 that I need a byte reversing function. Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 5, 2013 Share Posted November 5, 2013 It looks like ror and rol are bit shifting and not reversing the byte. Rotate Left through Carry 2A nzc--- 2 ROL A RCL A ;RCL A 26 nn nzc--- 5 ROL nn RCL [nn] ;RCL [nn] 36 nn nzc--- 6 ROL nn,X RCL [nn+X] ;RCL [nn+X] 2E nn nn nzc--- 6 ROL nnnn RCL [nnnn] ;RCL [nnnn] 3E nn nn nzc--- 7 ROL nnnn,X RCL [nnnn+X] ;RCL [nnnn+X] Rotate Right through Carry 6A nzc--- 2 ROR A RCR A ;RCR A 66 nn nzc--- 5 ROR nn RCR [nn] ;RCR [nn] 76 nn nzc--- 6 ROR nn,X RCR [nn+X] ;RCR [nn+X] 6E nn nn nzc--- 6 ROR nnnn RCR [nnnn] ;RCR [nnnn] 7E nn nn nzc--- 7 ROR nnnn,X RCR [nnnn+X] ;RCR [nnnn+X] SeaGtGruffs pfhscroll.asm takes care of shifting the playfield just fine. it's just when I must lay down playfield data into var0-47 that I need a byte reversing function. Right, it's shifting bits from normal bytes into reversed bytes and also doing the reverse of that. If you want to plop down the whole screen with data and not feed it from one of the edges, VbB can already create data from a playfield that you draw which will contain the reversed data. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted November 5, 2013 Share Posted November 5, 2013 In my 4 way scrolling topics I realised I needed some way to reverse a byte (i.e. turning %0100100 into %0010010) Although SeaGtGruffs pfhscroll.asm keeps the correct byte order directly manipulating the screen vars does not. This means any 4 way scrolling demonstration I've made so far can only use symmetrical level data. The only methods I can think of is a bunch of costly bit rearranging (i.e. this{0} = that{7}) or a very big lookup table. Does anybody have any bright ideas? Loon, here is a reflection routine from the ASDK with another approach. To optimise it for speed I would use registers for argument REVBT and variable b, and use BIT to process the two most significant bits with fewer operations. ;--------------------------------------------------------- ; Reverse Byte Routine 1100000 in REVBT becomes 00000011 ;--------------------------------------------------------- ; Note: This routine is not used, comment it out if you need the space: ;;ReverseB ; REVBT holds byte to be reversed ;; lda #0 ;; sta b ;; lda REVBT ;; and #%10000000 ; keep just the 8th bit ;;;is the 8th bit set? ;; beq skip1 ;; ; reflect it to set bit 1 ;; lda b ;; ora #%00000001 ;; sta b ; put it back in b ;;skip1 ;; ;; lda REVBT ;; and #%0100000 ; keep just the 7th bit ;;; is the 7th bit set? ;; beq skip2 ;; ;reflect it to set bit 2 ;; lda b ;; ora #%00000010 ;; sta b ;;skip2 ;; ;; lda REVBT ;; and #%00100000 ;keep just the 6th bit ;; beq skip3 ; is the 6th bit set? ;; lda b ;; ora #%00000100; reflect to set bit 3 ;; sta b ;;skip3 ;; ;; lda REVBT ;; and #%00010000 ; keep just the 5th bit ;; beq skip4; is the 5th bit set? ;; lda b ;; ora #%00001000; reflect to set bit 4 ;; sta b ;;skip4 ;; ;; lda REVBT ;; and #%00001000 ; keep just the 4th bit ;; beq skip5; is the 4th bit set? ;; lda b ;; ora #%00010000; reflect to set bit 5 ;; sta b ;;skip5 ;; ;; lda REVBT ;; and #%00000100 ; keep just the 3rd bit ;; beq skip6; is the 3rd bit set? ;; lda b ;; ora #%00100000; reflect to set bit 6 ;; sta b ;;skip6 ;; ;; lda REVBT ;; and #%00000010 ; keep just the 2nd bit ;; beq skip7; is the 2nd bit set? ;; lda b ;; ora #%0100000; reflect to set bit 7 ;; sta b ;;skip7 ;; ;; lda REVBT ;; and #%00000001 ; keep just the 1st bit ;; beq skip8 ;; lda b ;; ora #%10000000; reflect to set bit 8 ;; sta b ;;skip8 ;; ;; lda b ;; sta REVBT ; put the reversed byte in REVBT and return ;; ;; rts ;; 1 Quote Link to comment Share on other sites More sharing options...
bogax Posted November 5, 2013 Share Posted November 5, 2013 It looks like ror and rol are bit shifting and not reversing the byte. If you shift the bits out one direction and shift them in in the other direction they end up reversed. That will give you the shortest code but it's slow sec rol LOOP ror temp asl bne LOOP Fastest would be a straight table look up. but takes a big table. A reasonable compromise is to do a nybble at a time. A bB function (from the smooth 4 way scrolling thread) function rev() temp2 = temp1 & $0F temp1 = temp1 / 16 temp1 = revhi[temp2] | revlo[temp1] return data revhi $00, $80, $40, $C0, $20, $A0, $60, $E0 $10, $90, $50, $D0, $30, $B0, $70, $F0 end data revlo $00, $08, $04, $0C, $02, $0A, $06, $0E $01, $09, $05, $0D, $03, $0B, $07, $0F end a variation in asm (tables not shown. start,end with the byte in a) tax and #$0F tay txa lsr lsr lsr lsr tax lda hi_tbl,y ora lo_tbl,x 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 5, 2013 Author Share Posted November 5, 2013 I also found what I *think* is the nasty big lookup table on the Internets. here is the "ready for bB" version: data reverse $00, $80, $40, $c0, $20, $a0, $60, $e0 $10, $90, $50, $d0, $30, $b0, $70, $f0 $08, $88, $48, $c8, $28, $a8, $68, $e8 $18, $98, $58, $d8, $38, $b8, $78, $f8 $04, $84, $44, $c4, $24, $a4, $64, $e4 $14, $94, $54, $d4, $34, $b4, $74, $f4 $0c, $8c, $4c, $cc, $2c, $ac, $6c, $ec $1c, $9c, $5c, $dc, $3c, $bc, $7c, $fc $02, $82, $42, $c2, $22, $a2, $62, $e2 $12, $92, $52, $d2, $32, $b2, $72, $f2 $0a, $8a, $4a, $ca, $2a, $aa, $6a, $ea $1a, $9a, $5a, $da, $3a, $ba, $7a, $fa $06, $86, $46, $c6, $26, $a6, $66, $e6 $16, $96, $56, $d6, $36, $b6, $76, $f6 $0e, $8e, $4e, $ce, $2e, $ae, $6e, $ee $1e, $9e, $5e, $de, $3e, $be, $7e, $fe $01, $81, $41, $c1, $21, $a1, $61, $e1 $11, $91, $51, $d1, $31, $b1, $71, $f1 $09, $89, $49, $c9, $29, $a9, $69, $e9 $19, $99, $59, $d9, $39, $b9, $79, $f9 $05, $85, $45, $c5, $25, $a5, $65, $e5 $15, $95, $55, $d5, $35, $b5, $75, $f5 $0d, $8d, $4d, $cd, $2d, $ad, $6d, $ed $1d, $9d, $5d, $dd, $3d, $bd, $7d, $fd $03, $83, $43, $c3, $23, $a3, $63, $e3 $13, $93, $53, $d3, $33, $b3, $73, $f3 $0b, $8b, $4b, $cb, $2b, $ab, $6b, $eb $1b, $9b, $5b, $db, $3b, $bb, $7b, $fb $07, $87, $47, $c7, $27, $a7, $67, $e7 $17, $97, $57, $d7, $37, $b7, $77, $f7 $0f, $8f, $4f, $cf, $2f, $af, $6f, $ef $1f, $9f, $5f, $df, $3f, $bf, $7f, $ff end Quote Link to comment Share on other sites More sharing options...
danwinslow Posted November 5, 2013 Share Posted November 5, 2013 http://mirrors.apple2.org.za/ground.icaen.uiowa.edu/MiscInfo/Programming/reverse.bits Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 6, 2013 Author Share Posted November 6, 2013 The routines presented here have been REALLY useful. Even though I've seen these floating around I guess it's all about context and sometimes a kind soul to repeat what they tried to explain before How would I use these assembly routines in a bB program? My hunch is using the asm .. end asm ldx #47 lda #0 playfieldclear sta playfield,x dex bne playfieldclear end But how do I feed a routine the proper variables? Mr SQLs code uses something called REVBT but I don't know how that maps to bB variables. Quote Link to comment Share on other sites More sharing options...
Mr SQL Posted November 6, 2013 Share Posted November 6, 2013 The routines presented here have been REALLY useful. Even though I've seen these floating around I guess it's all about context and sometimes a kind soul to repeat what they tried to explain before How would I use these assembly routines in a bB program? My hunch is using the asm .. end asm ldx #47 lda #0 playfieldclear sta playfield,x dex bne playfieldclear end But how do I feed a routine the proper variables? Mr SQLs code uses something called REVBT but I don't know how that maps to bB variables. Loon, you could alias a variable in bB to REVBT: dim REVBT = i Aliasing makes both variables point to the same memory location. 1 Quote Link to comment Share on other sites More sharing options...
