bbking67 Posted January 20, 2014 Author Share Posted January 20, 2014 Lotharek, no worries, I know how busy you are. Yes, I did open it after the unit on a different Atari (the first unit was a stock 130XE and now I have tried it on a stock 800XL). Once thing I didn't consider is that I used the same power supply. I have two more, so I can try one of those. I'll be hacking the connector off one soon to use with a modern power supply. I won't play with the fuse bits. I have worked with various jtag and ISP devices and I am reasonably experienced, so I won't do anything dumb. Sorry for opening it up... I just assumed that was cool because programming the flash is something people would want to do. Well if I screw it up it's on me. Is there a way to test my Ataris to verify the voltage/current on the SIO port? Quote Link to comment Share on other sites More sharing options...
BillC Posted January 20, 2014 Share Posted January 20, 2014 Is there a way to test my Ataris to verify the voltage/current on the SIO port? Pin 10 of the SIO port is the +5V/READY signal. Quote Link to comment Share on other sites More sharing options...
lotharek Posted January 20, 2014 Share Posted January 20, 2014 we must solve this issue :-) and together will be much easier. i can flash Your sio2sd remotly :-) or... if all fails - i will send another one box . Quote Link to comment Share on other sites More sharing options...
bbking67 Posted January 20, 2014 Author Share Posted January 20, 2014 (edited) Lotharek, I was successful with the reflash and the unit is now working with my 800XL (and I am very excited to play around with it!!!). I have not yet tried it on the 130XE, so if the theory that the Atari was not supplying enough current/voltage holds water, my 130XE could be the culprit. It's a near-mint 130XE that has been working perfectly. The 130XE that used to be a daily driver for me has now got bad RAM... I do remember that back in the day some 130XE machines had issues with bus-powered devices (I've never experienced problems myself, but the only bus-powered devices I ever used were the XM301 modem and the ICD P:R: Connection). I am going to cannibalize an ingot power supply for the connector... maybe with a nice 2.0A power supply the 130XE will play nice. Thanks again for your help Lotharek (and to all from AA who offered help!) If I have some time this week I'll make a demo video and post it to Youtube, G+ and AtariAge (I did a quick unboxing video the day I received the unit). /bbking67 Edited January 20, 2014 by bbking67 Quote Link to comment Share on other sites More sharing options...
bbking67 Posted January 20, 2014 Author Share Posted January 20, 2014 The software I used to flash the Atmel is the Extreme Burner: http://extremeelectronics.co.in/avr-tutorials/gui-software-for-usbasp-based-usb-avr-programmers/ I initially read the flash and captured the screen with the fuse bits (very important) before doing anything. I also triple checked the pinout. My the programmer I used I did not have to power the device using the Atari. The programmer I borrowed is a fairly generic USB model bought at a hacker convention. Worked perfectly. Plugged in the pins I needed based on the schematic and held them in contact with the points on the board. This is a two man job folks--one guy to hold the pins in place and the other to flash. The only issue I had was that the software was .bin and not recognized by the flashing software. Other software didn't like Windows 7 or the flashing device. In the end, Lotharek kindly supplied me with a HEX file, which if he permits me to I can post here for future use. /bbking67 Quote Link to comment Share on other sites More sharing options...
knusperfisch Posted January 21, 2014 Share Posted January 21, 2014 Too bad the SIO2SD pcb does not have the standard 3x2 AVR ISP header, to flash with USBtinyISP. Quote Link to comment Share on other sites More sharing options...
bbking67 Posted January 21, 2014 Author Share Posted January 21, 2014 the 10 pin header J2 is some kind of standard as it directly corresponded to the programmer I used. I verified it against the schematic and then again with a multimeter. Quote Link to comment Share on other sites More sharing options...
