chukione Posted January 19, 2014 Share Posted January 19, 2014 hi. i get a 65xe from a trash dump, when i connect to the tv, it works!. now i need to remove the dirt from the keyboard. someone know how to do it? Quote Link to comment Share on other sites More sharing options...
re-atari Posted January 19, 2014 Share Posted January 19, 2014 (edited) now i need to remove the dirt from the keyboard. someone know how to do it?Looks like you have a keyboard assembly with a folded mylar foil, as it has no conductive caps on the underside of the keys. If that's actually the case, you can remove the dirt on the top keyboard assmbly shown on your foto's by simply putting it in warm water with some dishwashing soap. Leave it there to soak in for an hour, and the dirt should wipe off easily. Alternatively you could try cleaning it in the dishwasher, but in my experience the plastic Atari used on the XE models is very soft, and will probably deform from the heat. The metal bottom plate and mylar foil are best cleaned with a damp cloth. Be careful with the foil, the electric traces are very flimsy. Only one cut trace will render the keyboard useless. re-atari Edited January 19, 2014 by re-atari Quote Link to comment Share on other sites More sharing options...
