Caterpiggle Posted February 1, 2014 Share Posted February 1, 2014 Hello Stephen , I need an help or guide me to find the right software either .atr or .xex or even .exe that can detected if my Indus GT actually have CP/M Card installed inside the black metal case. SO that I don't have to force to open the tough case. I know it is very tight and not very easy to put the case back ! Quote Link to comment Share on other sites More sharing options...
+Stephen Posted February 1, 2014 Share Posted February 1, 2014 Start by reading all of this info http://trub.atari8.info/index.php?ref=sramcharger_en There is a link at the bottom to a tool which will test the RAMCharger. I have attached the ATRs required to get CP/M running on the Indus, but you will have to create actual floppy discs with these. Also, the CP/M disc you create on floppy needs to be "repaired" with a utility that I believe trub wrote - this fixes the 1st 3 sectors on the disc. Indus.zip Quote Link to comment Share on other sites More sharing options...
