Level42 Posted January 29, 2014 Share Posted January 29, 2014 (edited) I am the lucky owner of a pretty extensive Fluke 9100 set. Has anyone ever used a Fluke 9010 or 9100 to test A8 machines ? My first question is if the 6502 pod would work, because I know the A8 used a slightly enhanced 6502 processor. Maybe any scripts available ? Edited January 29, 2014 by Level42 Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 30, 2014 Share Posted January 30, 2014 (edited) Pinout is slightly different to mainstream 6502, particular concern would be R/W line. Main difference of course is /HALT which you'd probably want to monitor as well as /RDY. There will still be visible address/data bus activity when these are active but they will be Antic generated accesses, not from the CPU. Actually, /RDY is a tricky one in itself since there can be up to 3 cycles where it's active but the 6502 is still accessing the bus. Edited January 30, 2014 by Rybags Quote Link to comment Share on other sites More sharing options...
