+rockdoc2010 Posted February 3, 2014 Share Posted February 3, 2014 I am trying to connect to a standard centronics 8 bit parallel printer thru a MPP-1150 but I don't have instructions for the MPP interface and I haven't been on the atari since 1987. The other printer requires a strobe signal in order to init and time each other in addition to 47k pull ups to half the connections. I can deal with that within the wiring connectors but I don't have a clue as to set up the connection. It seems like I would set it up like a modem and It makes sense. Anyone that may have a direction to push me that would be great.. Thanks Douglas Quote Link to comment Share on other sites More sharing options...
+David_P Posted February 4, 2014 Share Posted February 4, 2014 What Atari are you running? As I recall, the 1200xl won't support powering peripherals on the SIO bus. See also http://www.cyberroach.com/analog/an22/printer_interfaces.htm Quote Link to comment Share on other sites More sharing options...
