XEGS: What does this mod do?
Marius
The XEGS I bought today is missing a MOBO switch (see other topic) but I also saw a modification on the sound amplifier.
What is that thingy doing there?
The only thing that I can think of is that this diode prevents damage in case of incoming sound on the cinch connectors of the computer.
But I guess someone else might know it.
I had to break the warranty seal so I guess this was a factory-mod
Look at the amount of resin flux on the PCB, Atari's 'betere bak- en braadwerk'...
The diode is probably used to improve the 555's stability.
re-atari
Edited by re-atari
Whaha yes. I call that also 'bakken' (of metselen).
But to compensate things, judging by the lousy state of the solder joints it looks like the Tramiels cut back on the amount of solder used at assembly. I can see a resistor that is just barely soldered in. Look after the pennies and the pounds will look after themselves, right?
Thank God Atari did not use leadfree solder back then, production would have had just about 100% DOA. Even nowadays leadfree solder is a real pig to work with (speaking from experience).
re-atari
Edited by re-atari
Judging by the flux mess, I very much doubt it's OEM - looks like something someone has done at a later point. Probably just before getting a phone call and rushing off somewhere and leaving it to sit for the remainder of the weekend.
I agree it looks like very homebrew, but the factory seal would have been damaged when opened by (one of the) previous owner(s). I guess it's possible to remove the warranty seal without entirely breaking it, but you'd still be able to tell it was peeled off (again speaking from own experience).
BTW, after checking the 555's datasheet, it looks like the diode has to be a zener type, used to protect its TRIG input. And ultimately improve stability (as I mentioned).
re-atari
Yes. It was perfectly sealed. The seal did look like factory-new. It is a Rev. 3 motherboard of the XEGS by the way. I have a few more XEGS's floating around here, and the others all do have a Rev. 1 motherboard. In the REV. 1 motherboard there are more chips on socket, but the diode is not there.
I love the XEGS. It's a nice computer. The keyboard quality s*cks bigtime. From all XE keyboards, the XEGS keyboards give the most terrible typing-experience EVER. But I replaced one now with a better one, and it's really cool.
My 5 year old daughter loves the colorful buttons, and I love the default video output quality.
Goes to show that after a few decades old stuff gets 'hot' again, even the 'Miami Vice' colors Atari used on the XEGS's buttons ;-)
re-atari
