ACML Posted February 23, 2014 Share Posted February 23, 2014 (edited) I have recently acquired an excellent SIO2SD/PC Combo made by "santosp". I was contemplating buying one of Lotharek's also excellent devices, but this opportunity just popped up. I have a few questions: 1) It won't work on a 48K 400 or 800. It locks up on the SIO2SD Turbo screen. I think this is solved by turning high speed off. What is the key combination to turn high speed off? 2) Can I flash the firmware from the Polish SIO2SD site or is this a special firmware load since it also can be an SIO2PC via the USB cable? 3) It has the following behaviors with the SIO2SD loaders ver 1.2) works great, has 4 on screen drives ver 2.2) works great, has 4 on screen drives ver 2.5) works great, has 8 on screen drives ver 3.0 - 3.5) Boots, has 8 drives, but does not have the familiar A-S file selection window. I get control characters (no letters). Should I also see the A-S file selections? Edited February 23, 2014 by ACML Quote Link to comment Share on other sites More sharing options...
Marius Posted February 23, 2014 Share Posted February 23, 2014 Can't answer everything, but when you reboot after the SIO2SD turboscreen it reboots without Turbo. I would love a feature too to switch the turbo boot system of, but remain High Speed. The Turboloader loads a small High Speed loader on a certain memory location, with shift or select you can chose which memory location you want to use. Perhaps the highspeed is too fast (Which causes locks up too). On my Sio2SD pressing shift 2 or 3 times fast after each other gets me in setup mode. Then with the first switch I can chose different configuration parts like the high speed pokey divisor. Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 23, 2014 Share Posted February 23, 2014 Santosp SIO2SD/PC Combo was an awesome product with a nice price. It's a standard SIO2SD device so it doesn't need special firmware. It's a recent product so I don't think you need to update firmware. V3.5 on-screen loader doesn't have the old A-S letters file selection. You can find basic intructions on my website: www.santellocco.com/atari/sio2sd.htm#english Quote Link to comment Share on other sites More sharing options...
ACML Posted February 23, 2014 Author Share Posted February 23, 2014 Santosp SIO2SD/PC Combo was an awesome product with a nice price. It's a standard SIO2SD device so it doesn't need special firmware. It's a recent product so I don't think you need to update firmware. V3.5 on-screen loader doesn't have the old A-S letters file selection. You can find basic intructions on my website: www.santellocco.com/atari/sio2sd.htm#english Thanks for the gouge. Do you happen to have instructions on how to navigate file selection using loaders 3.0+ ? It's not intuitively obvious to this SIO2SD newbie. I get A-S, but the Rosetta stone for the arrow indications eludes me. I own two SDRIVEs (NUXX and Micro), so I'm interested in doing a comparison. Thanks! Quote Link to comment Share on other sites More sharing options...
+Philsan Posted February 23, 2014 Share Posted February 23, 2014 As written on my website: ON-SCREEN LOADER INSTRUCTIONS (v3.5) ARROWS/JOYSTICK select file .xex or disk image .atr KEYS 1-8 mount selected file/image into drives 1-8 CTRL+T lets you toggle between real drives / virtual drives ESC climb directory tree X (long press) restart computer with selected images RETURN/FIRE enter directory/load file/disk image While loading programs that don't need Basic, keep pressed OPTION key for a few seconds When you leave on-screen loader, you can swap disk images from real drives to virtual drives pressing SIO2SD's SHIFT button + K3 button (grey button + Esc button on SIO2SD Micro). Quote Link to comment Share on other sites More sharing options...
