+JAC! Posted March 2, 2014 Share Posted March 2, 2014 Hi, I've installed an U1MB in my 800 XL. he computer works fine on power-up, config menu etc. but it refuses to perform an disk I/O. AspectQT does not output anything during boot (it does for a reference 800 XL with the same cables & hand shake). I have swapped POKEY and PIA already. The result is that the ones from the non working board work fine in another board. I've checked the connections from CB2 (COMMAND), SIO/SOD/ACLK/BCLK to the SIO connector and they look fine (all 100 Ohm). [in fact I had incidentially cut 2 of these traces when I installed the 1UMB, but I fixed them, see above]. Now I'm clueless where/how to search next? Any ideas? Cheers, Peter/JAC! Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted March 2, 2014 Share Posted March 2, 2014 Have you tried other SIO choices .... Like a disk drive or sio2sd. anything other than SIO2PC.. I have occasional problems also with SIO2PC.. Mostly USB related... If I reboot the PC I can get the SIO2PC working again.. Quote Link to comment Share on other sites More sharing options...
Marius Posted March 2, 2014 Share Posted March 2, 2014 Perhaps a very dumb question from me, but are you sure the installed OS's in U1MB slots are 100% ok? Problem is with all OS's (also Qmeg?) Quote Link to comment Share on other sites More sharing options...
atari8warez Posted March 2, 2014 Share Posted March 2, 2014 (edited) Peter, check the voltage levels on SIO3, SIO5 and especially SIO7 pins, they should read close to 5v. I had cases where an Atari drive worked fine but SIO2PC did not work when connected to the same Atari, when I measured voltages I found that SIO7 pin was around 2-2.5v. You said you already swapped POKEY and PIA and they work in another machine, that to me means there is some other problem with the mainboard or some other component, but check to see what are the voltage levels first. EDIT: You could also run a serial port monitor program on your PC to see if you are getting any activity on the DSR line (or CTS/RI depending on your SIO2PC hardware). Edited March 2, 2014 by atari8warez Quote Link to comment Share on other sites More sharing options...
+JAC! Posted March 2, 2014 Author Share Posted March 2, 2014 (edited) Priceless: After checking all of the above (with no result), finding a working serial sniffer and seeing $31 .... correctly appearing, I realized that now it's simply working. So I happily re-soldered the SIO connector pins (just in case they were to balme...), tested and it's fine. .... except for the U1MB which I now see is mounted in a way, so I simply cannot close the case anymore .... aaargh - time for going to bed :-) Thanks for your tips, guys! Edited March 2, 2014 by JAC! Quote Link to comment Share on other sites More sharing options...
ZarK Posted March 3, 2014 Share Posted March 3, 2014 (edited) Cut a hole in the CASE! JK, Don't do that! The proper solution is to whittle down the pcb untill it fits, or use a variable swing press. if any traces break, use crazy CRAZY glue to fix! Seriously, don't do that either! Post some pictures, lets see the Atari 400 naked ;D Edited March 3, 2014 by ZarK Quote Link to comment Share on other sites More sharing options...
atari8warez Posted March 4, 2014 Share Posted March 4, 2014 Cut a hole in the CASE! JK, Don't do that! The proper solution is to whittle down the pcb untill it fits, or use a variable swing press. if any traces break, use crazy CRAZY glue to fix! Seriously, don't do that either! Post some pictures, lets see the Atari 400 naked ;D I know it must be bloody cold up in NWT but alcohol does not prevent hypothermia, it just makes you say things that doesn't make sense , JAC is talking about a 800XL not a 400......and I pitty you if the best thing you can see naked is a an atari 400 Quote Link to comment Share on other sites More sharing options...
ZarK Posted March 5, 2014 Share Posted March 5, 2014 (edited) I know it must be bloody cold up in NWT but alcohol does not prevent hypothermia, it just makes you say things that doesn't make sense , JAC is talking about a 800XL not a 400......and I pitty you if the best thing you can see naked is a an atari 400 Haha! yeah... Frozen brained comes to mind. Gotta keep busy and outta trouble, so vintage computing and gaming comes in. That and a '70 pickup, but not as fun working on it in a snow bank, Still post some pictures of the 800xl! and found some neekid 400 keyboard post with pictures instead of the parka covered uhm, ladies Edited March 5, 2014 by ZarK Quote Link to comment Share on other sites More sharing options...
