+playsoft Posted March 22, 2014 Share Posted March 22, 2014 Another of my old magazine games converted for the 5200. hm.bin hm_source.zip I had to create a bigger dead-zone than normal on the analogue stick to make it easier to stop moving. I suspect this will play better with a digital stick. Amazingly Scalak and therealbountybob were able to complete the 8-bit version of this when they played it as a bonus game in the HSC. Scalak has a good level map available here: http://atariage.com/forums/topic/199594-hsc9-round-10-crystal-castles/?p=2555405 Page 6 Magazine Issue 33 May/June 1988 HEAVY METAL Thirty five screens, evil ball bearings, slime and muchmore in this machine code extravanganza by Paul Lay Your mission is to recover the seven lost jewels which have been scattered throughout the deadly mazeworld of rooms that you inhabit. You control a spinning ball-bearing with a joystick in port 1. Move the joystick in the appropriate direction you wish to move. You may climb walls that are low enough and you may also fall off walls, although you'll die if you fall too far! Hold the trigger to put the brakes on and stop your ball-bearing from moving. In each room there may be a number of teleports which will transport you to another location. These are marked by a diamond floor pattern. Simply stop on the transporter then press and release the trigger to energize! In your quest you will encounter a stomping boot, an evil black ball-bearing and a nasty piece of slime. Contact with any of these is fatal. To collect a jewel simply move over it. You have a certain amount of time and your game is over when you run out of time. Getting killed simply costs you time and you'll start that room again. Use START to begin a game at the first location. Use * to begin a game from the last location visited, however you lose any jewels previously collected and so you'll have to go back for them. Use PAUSE to pause, then any key to resume. Use RESET to abort a game in case you get stuck somewhere! 1 Quote Link to comment Share on other sites More sharing options...
funknflow5200 Posted April 22, 2014 Share Posted April 22, 2014 This game is incredible!! Thanks again! 1 Quote Link to comment Share on other sites More sharing options...
